Question about ATI RADEON 9600XT 128MB AGP (Retail) Graphic Card
Graphics Card My Gateway PC screen is completely black;it says that there is no signal.My computer is running perfectly;it's just the monitor.I followed the owner's manual to a "T" but still had no results.I phoned Gateway support and was told that the issue is most likely a graphics card problem.They said for a fee they could mail me out one and verbally guide me via phone as to how to connect the card to my pc.Question's:Any suggestions where I can purchase a graphics card besides Gateway?They want to charge me 70$ plus shipping.I have no clue if that is a fair price.And how would I go about how to connect the card myself?Any online tutorials?Thanks! Driver
  • 655 Answers
Helenak,
  • First you should check your connection from your monitor to your computer, generally it will be at the back of CPU (Computer Cabinet).
See the image: Graphics Card - 7fe1438.jpg This will be connected to your PC Video out port:
  • After connecting again try out. If no luck then you shoud buy a PCI VGA card, its easy to installed in your PC, just remove the cover and you will see a slot with white color, try to insert gentlly it will be fixed.
  • Regarding rate there are too many products, you can search at net for your need.
Thanks & Good Luck
Iqbal
Posted on Jun 09, 2008
Gateway GT5040 Graphics Card
This model Gateway desktop computer has a built-in video card.
Connect the monitor to the Gateway motherboard video port and the boot up and go into the BIOS and select disable the built-in video.
Shut down then connect the monitor to the 8800GTX video card and boot up the Gateway computer. The video should then appear in the monitor.
Feb 14, 2013 | Gateway GT5040 PC Desktop
Emachine ET1850 model when turn on no display picture.
Check ALL monitor cables, reseat connections. Have you done any hardware or software updates? Graphics Updates? Do you get anything at boot? Just no signal? It sound like a hardware issue, Graphics. Support for your machine can be found here: http://support.gateway.com/us/en/emac/product/default.aspx?modelId=2064 You could buy a PCI e x16 Graphic Card . Better ,faster Graphics. First, check VGA connections, reseat, check for bent pins. Try another cable and monitor, to verify.
Jan 02, 2013 | E-Machines eMachines Desktop PC
I was playing solitaire on our home PC and the power went off and the screen went black. Before it went black it said "no input signal go to power save" Everytime I try to turn the computer on...
It means that your monitor is not getting a signal from your PC. Your monitor is fine though. You will need to plug the video cable from your monitor into the onboard video if you are using a graphics card. If you are not using a graphics card then you will probebly need to get a PC technition to diagnose the problem with your motherboard.
Feb 21, 2011 | Vision Computer (2U-A2200K) (2UA2200K)...
Turns on fan runs but no info to the monitor doesnt seem to boot
If the Monitor is displaying no infomation at all, your display signal from the PC to the monitor has failed.
1: Check the cable between the monitor and PC
2: If you are using onboard graphics then that display port is faulty.
3: If you are using a graphics card then remove it and try the onboard graphics.
4: Your monitor maybe faulty aswell so test it on another computer to be safe.
Its more likely to be option 2
Jan 15, 2010 | Gateway GT5220 PC Desktop
Turned on computer screen had black background with yellow lines.Then turned off turned on said no signal
certainly graphics card related, and usually means that the graphics card has become unreponsive. Likely causes include:
- Overheating.
- Overclocking.
- Insufficient Power
- Hardware failure. .
Nov 10, 2009 | Gateway GT5220 PC Desktop
Computer Does not work correctly with Radeon 9250 Graphics Card
Hmm? Everything except replacing the motherboard, sometimes it does not get any better, but...go into your BIOS and turn off the Gateway splash screen. It will be an option in maybe the first or second menu choice. Make sure your on board video device is disabled and save your options when exiting. Good luck and let me know how it turns out.
Jul 02, 2009 | MSI MS-5185 Motherboard
Monitors wont work
It appears that you have a faulty graphics card.
If the graphics card is integrated with the motherboard then it cannot be repaired. Just purchase a new AGP graphics card, insert it into the AGP slot and connect your monitor to this card.
You may need to go to the BIOS setup to disable the on-board graphics card.
If you don't have an integrated graphics card, then buy a replacement graphics card.
You will need to install the new graphics drivers after installing the graphics card.
Nov 13, 2008 | Gateway 310 S PC Desktop
MONITOR WONT STAY IN DVI MODE
Did you try the card in your friends machine? That would be the next step. The card could be going bad.
Feb 29, 2008 | Gateway FPD1975W 19" LCD Monitor
Computer turns on, but there is no display on monitor.
The builtin video card is probably bad. Yes, you can get a PCI video card.
Dec 28, 2007 | Dell Dimension 2300 PC Desktop
Graphics Card
It's a fair price for a general graphics card just to get a display back on your computer, and that's not too bad considering it includes shipping, but the prices of different models vary a lot. There'll be plenty of online tutorials such as this: http://reviews.cnet.com/4520-3118_7-5023982-1.html But before you do so, sometimes you don't get a display output because your monitor is plugged into the wrong VGA port. Look at the back and see if there is another of the same port located below where it is currently plugged in, if there is one - plug it in there and try again.
Sep 07, 2007 | Computers & Internet
Computers & Internet Logo
80 people viewed this question
Top ATI Computers & Internet Experts
David
David
Computer Links
Alun Cox
Are you an ATI Computer and Internet Expert? Answer questions, earn points and help others
