Question about Goodman CKL36AR36 Air Conditioner
Goldstar Air conditioner
My Air conditioner blows out water and leaks water INSIDE MY HOUSE!. It get my floor really REALLY WET! Is it suppose to do that? What is wrong?
  • michelleandh Jul 17, 2008
    my air conditioner is leaking all over my floor, why is this??
    Prodigy:
    An expert who has answered 500 questions.
  • 540 Answers
How old is this unit cause the drain pan back in the day , was made of metal and rust. also most of the time, the drain line get full of slime-bacterias -mold pluggs the line . Find the drain line tapp on this to unlodge sludge. If this is pvc pipe,try to introduce bleach into the system to kill the nasty(#$!@*&$'s) Thank-you- very -much!
Posted on Aug 23, 2008
Just got mine and its doing the same thing water everywhere I think im returning this asap
Posted on Aug 08, 2008
Same problem with a GE Window A/C....dripping water inside the house. I shut it off for 15 minutes, mopped up the mess and turned it back on....so far so good.
Posted on Aug 07, 2008
  • 1,420 Answers
Tilt the unit toward the window opening and clear the drain holes in the back and bottom of the unit from debris.
Posted on Jun 09, 2008
Water leaking in the inside of home.
Air conditioners take the moisture out of the air. When the air passes through the coils on the evaporator, they are cold. This causes the air to condense and water to form on the coils. It then drips off into a pan. When the pan is full if it is not drained, you will have an overflow and things get wet. How much water the unit collects depends on how much humidity is in the air, how much air you are moving through the coils and the temp of the coils.
Jul 22, 2013 | Royal Sovereign White 1200 BTU/12,500...
Air conditioner isn't blowing cold air like it should
Hello, usually this can be caused by either a dirty filter, evaporator coil or low refrigerant charge.
May 22, 2012 | Goldstar Heating & Cooling
Where is the drain hole on goldstar window ac my ac keeps dripping water inside the house
Hello, make sure the unit is tilted toward the outside a bit, if it is level the condensate will collect in the front and start dripping inside the house. Also, if the unit has a drain make sure it is clean so the water can drain out properly.
Jun 07, 2011 | Goldstar KG6000R Window Air Conditioner
How do you get the ac to stop leaking water inside the window?
The a/c could be slightly leaning toward the inside letting the water drip in or the drain hole which allows the water to drip outside could be stopped up. Find the hole and blow through it with compressed air to unstop it.
Jul 25, 2010 | Goldstar GW-HD5000 Window Air Conditioner
Leaking water
mcdevito75 here, The portion of the a/c unit that goes outside the window is the evaporator and suppose to leak water, check the drain hole in the unit floor on the outside portion of the unit, reach this drain hole thru another window or have your local a/c repair shop look at it, they come to the house.
Jun 21, 2010 | Samsung AW0893L Air Conditioner
Driping water inside house, blocked pipe? Mike
Take a wet/dry shop vac and find the drain line. Pull a vacuum on the drain line to dislodge any blockage. Worst case, blow into the pipe but cover everything inside because it will get wet!
Mar 13, 2010 | LG Art Cool LA121HNP Split System Air...
Water leaking inside house
Your problem is there is debris inside of the casing blocking the drain hole in the back of the unit.. Go outside and look under the unit and you will see several holes throughout. These holes allow the condensation to drain out from the bottom of the unit. The best way to clean the unit is to remove the unit from the sleeve take the unit outside and you can wash out the system with a water house as long as you make sure that you don't wet any of the fan motors. The metal thing you refer to is the evaporator coil. If you go to the home improvement store you can purchase a can of coil cleaner. This cleaner is sprayed into the coil at which time it foams up like shaving cream. Let it sit on the coils as directed on the can. Once the time has elapsed rinse the coils well remembering not to get any electrical parts wet (I suggest purchasing a pump up garden sprayer for this because it is easy to control where the water will go) After this is done let the unit sit until the water has disappated then reinstall into its sleeve. The dust by the fan can be removed with a brush and a vacuum (wet Vac). Good luck on repairs
Dave
Sep 01, 2009 | Goldstar M5200R Air Conditioner
Goodman CKL36AR36 Air Conditioner Logo
179 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
