Hello - I own the LCD TV/DVD Combo (REGZA) and the DVD is jammed. During the playback it simply froze and will not eject.
    Brigadier General:
  • 6,966 Answers
Hi again,
Any developments with your concern? Should the reset trick work, you may also want to use a CD cleaner similar to those used in PC CD ROM and readily available from most computer shoppes.
Cheers.
Posted on Jun 09, 2008
Cd wont eject out of t_v
Disc loading mechanism fault. Contact any service technician. The mechanism should take out from the TV; either for repair, or replacement. If you wish to get some details; check the site linked here. Pull up older posts.Surf the site with patience.http://electronicshelponline.blogspot.com/
Sep 21, 2014 | Televison & Video
Dvd won't eject from RCA tv/Dvd combo
While hitting the eject button use a small flat screwdriver or butter knife to ease door open, probably the rubberband like belt broke or the gears jammed up!
Jun 17, 2012 | RCA 22LA45RQD 22-Inches 720p LCD TV -Black
I have Toshiba Regza 32 with DVD and the disk got struck. It doesnt play or eject. But you can hear the DVD is on, is working. The TV works no problem. How I can ejects the disc from the DVD. Please help!...
Hello
As you feel DVD is woking, that is spinning inside, and there is no picture at all, the fault will be with its defective Laser Pickup Unit. It is a common fault , that this unit bcome damaged. No special rason can be pointed out for that. Just put a cleaning disc into the player, and play it for two or three times. If the fault is due to dust or dirt accumulation to its pick up lens, it will be alright after this procedure. If it does not help, there is no other way than replacing the Laser Picup Unit, with same type and number. OK.
Apr 06, 2011 | Toshiba Regza 32LV67U 32 in. LCD HDTV
Our Toshiba 23HLV87 combo TV won't eject the DVD. We've had the TV 2.5 years and about a year ago, this problem would occasionally happen. Eventually we could get the disk to come out with patience and...
Hello Friend,
A small belt that connects the motor and the DVD tray is worn out or lost its elasticity, ask your nearest authorized service provider to visit and replace it.
Good Luck.
Dec 20, 2010 | Toshiba 23HLV87 23 in. LCD Television
How do you retrieve a DVD that will not eject? When we use the eject button, we hear a grinding noise. Can we open up the DVD exchanger to retrieve the DVD?
1st. turn off dvd and tv
2nd there is a small hole in the front of the dvd case,,usually close to the eject button.
3rd use a straight ,,slowly insert and you should feel a lever that will open the door. i,portant to so this slowly...
May 28, 2010 | Toshiba Regza 37HL17 37 in. LCD TV
Dvd is stuck in player - won't play and won't eject
open cabinet of your dvd you will find out a lock open that pick up your disk during proseeing that is stucked
Mar 05, 2010 | Mintek DTV-263 26 in. TV/DVD Combo
Toshiba Regza 32 inch with DVD player - won't eject
Disconnect cable from DVD to TV, press play, and then press stop, try to push eject button to get the disk out. If all could not have, you have to open the DVD cover then get the disk out.
Aug 18, 2009 | Toshiba Regza 32LV67U 32 in. LCD HDTV
The DVD player is in constant eject mode - discs will not stay in to play. It has worked perfectly for years. Tonight I was watching a disc, finished, ejected it and put in another and the player just...
Two possible scenarios: First the optical pick up assembly that read the disc has malfunctioned or the eject button is faulty. Either way it is just cheaper to replace the DVD player with a standalone dvd player connected to one the tv input(s). Too expensive to repair just the dvd player if it is tv/dvd combo. The cost for labor and parts is more expensive these days to repair tvs or dvd player. For around $30 you can just replace...much more cost effective.
Aug 15, 2009 | Sylvania 6620LDF 20 in. EDTV-Ready LCD...
Sunia LTD-1720 17" Color LCD TV and DVD Player Combo with Remote
i have a sunia tv anddvd combo need a remote and programming instruction for it. the remote model is rc518n than you
Apr 26, 2008 | Televison & Video
Televison & Video Logo
Top Televison & Video Experts
