Question about Miele Washing Machines
Miele G638sc plus Inlet/outlet light is coming on. I've isolated everything and all I can think of is that it is the waterproofing system as there was a flood in the kitchen the day before. Trying to dry everything out with a fan, any other suggestions
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 210 Answers
There is a float switch on the bottom panel of the unit. If the panel is full of water the drain pump will run and will override everything.
Sgt 48
Posted on Jun 09, 2008
Dishwasher is not working. The red 'Inlet/Outlet' light is flashing. Any advice please Thank you
There are a few things you can check. First set the washer cycle to Stop and turn off the unit. Next make sure that the stopcock on the inlet valve is fully open. Then close the stopcock/valve and disconnect the inlet hose. Remove the seal and then the filter (use pliers). Clean this inlet filter with running water. Replace the filter and seal and reconnect the hose to your inlet valve. Reopen the valve (check for leaks from threading problems). Make sure the valve is fully open when you try to restart the dishwasher. Check your incoming water pressure at this valve as well - low water pressure will also trigger the inlet error. Make sure the hose is not kinked.
If the washer did any parts of the wash cycle, then try cleaning the outlet side of the system.
Next clean the combination filter, drain pump and non-return valve. For the filter (near the lower spray arm), turn the handle counter-clockwise. Lift the filter out and remove all debris. Rinse under running water and use a nylon bristle brush to get stubborn stuff out. Pull back the yellow clip and open the filter flap. Clean the underside of the filter with running water again.
Remove the water from the cabinet with any container that works. Raise the locking clamp for the non-return valve. Lift up the valve and clean it under running water. Carefully check the drain pump (now visible with the non-return valve out) and remove any debris. Sharp objects may be present. Move the impellers and completely check the pump for foreign objects and remove them. Replace the non-return valve and secure it with the locking clamp. Replace the combination filter so that it lays flat and secure it with the handle. Make sure that the drain hose is not kinked.
If neither of these solve the problem, you need to call for service. The Waterproof safety system has been triggered and water got into the electrical system of the unit.
Many Miele appliance manuals are here: http://www.miele.co.uk/customer/OperatingInstructions.aspx . The manual for the Miele G641 is here: http://www.miele.co.uk/Resources/OperatingInstructions/G%20641%20and%20G%20841%20Plus.pdf . See this manual for pictures of the filters and drain pump area.
I hope this helps.
Sep 14, 2011 | Miele 24 in. Novotronic G641 Plus Built-In...
Anavei zu-ablaouf se opoia plysi kai an to vazoume gia to plyntyrio piaton G601SCI PLUS. PERIMENO ODIGIES EYXARISTO
Symfona me to manual i einai kleisti i vrysi, i to filtro nerou sto inlet exei voulosei, i antedrase to systima waterproof (se ayti tin periptosi leei pos prepei na miliseis me tin miele).
Dec 10, 2010 | Miele 18 in. G601SC Plus Slim-Line...
Hi My dishwasher Miele G692 SC has the inlet/drain light illuminated. I have cleared the inlet and tap connection..... Any other suggestions before I ring Miele?
Have you checked the drain? On mine a small piece of broken glass had got past all the filters and had blocked the paddles of the pump - you have to release the spring clip and take off the top of the pump housing. Miele's seem very fussy about any blockages to the water outlet system.
You then have to hold down the start button to force a restart (cost me a call out to learn that) - but it is stated, sort of, in the problem fixing manual.
Nov 01, 2010 | Miele Dishwashers
Water staying at the bottom of the washer.When i close the washer an press start the inlet/drain light comes on and nothing else happens.Miele G 692 SC PLUS
Your drain outlet is blocked , pull all the filters out and then check nothing is stopping the impeller from turning. You have to bucket out all the water first of course. It can be a toothpick or just some gunk,
Mar 25, 2010 | Miele 24 in. G692SC Plus SS Free-standing...
Outlet/inlet light flashing on miele dishwasher G674SC
Usually indicates a intake or drain fault - could be a plugged drain line at the garbage disposal or insufficient water coming into the unit
Sep 22, 2009 | Miele Dishwashers
MIele waterproof system reacted
That means that there is a leak that passed throught the waterproof system, and the water protection system had reacted putting the machine on error mode, as the water can damage electric parts, and cause serious hazard.
Sometimes you can reset the error by unplugging power cord, however you should call immediately a technician, as using the appliance when there is a problem with the waterproof system, you can be seriously injured by electric shock.
Operating instructions for Washing machine W 3923 WPS
Nov 16, 2008 | Washing Machines
Miele g 646 sc (not plus)
check the inlet where it joins onto the tap as mine has a fine filter and debris from the fresh water builds up. Simply remove the pipe from the tap and **** ,this should remove /dislodge any scale etc that could be causing the inlet light to come on. Make sure you spit out the water that comes back from the machine!
Apr 20, 2008 | Miele 24 in. G646SC Plus Free-Standing...
Inlet/outlet light comes on
Machine is possibly not filling with correct amount of water if this light comes on early in the cycle
Aug 15, 2007 | Miele 24 in. G646SC Plus Free-Standing...
Inlet/Outlet light flashing
check your overflow level switch wich is located behind front kickplate on right hand side
Jul 11, 2007 | Miele 24 in. G646SC Plus Free-Standing...
Washing Machines Logo
378 people viewed this question
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
