Question about Hotpoint Aquarius WD640 Front Load Washer/Dryer
H20 error messages
H20 errors while washing or drying
Did you resolve this problem ? If so, can you let me know how ?
  • 66 Answers
H20 is normally a water valve problem please check these regards jason
Posted on Jun 14, 2008
Problem with a hotpoint wmf760 aquarius + error code h20 coming up
You may have soap & grease in the pipe that leads to the pressure switch. Remove and flush through and/or replace. dry before refitting.
Thus constant high would give pump faults (thinks machine still contains water). Constant low may cause over filling. If you have a plug that suddenly moves, that can cause the above errors.
Jan 02, 2013 | Hotpoint Ultima WF860 Front Load Washer
When putting the machine on no water going in and then error message H20 appearing on display
H20 means lack of or no water going into washer.
Check inlet hose/s for restriction or kinks.
Ensure water is turned on to the washer, and that there is enough water pressure to open the valve/s.
Check filters in inlet valves, if every thing o/k, then could be a faulty inlet valve/s.
Feb 06, 2011 | Hotpoint Washing Machines
H20 ERROR SPIN DRYING
The error indicates a problem with the incoming water supply.
Check for restricted or kinked inlet hose/s, check that tap/s are fully turned on and that you have adequate water pressure.
Mar 27, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
Error code H20...My washing machine, a hotpoint wt740 is showing the warning light H20...does anybody know what this means? thanks
Well error H20 does indicate no fill.
Make sure that that there is an adequate supply pressure to washer, check that there are no kinks or restrictions in hose. To be certain if you have an adequate supply turn off water valve to washer, disconnect hose and hold the hose into the sink or a bucket, turn the water back on, and see what the pressure is like..
If ti is too low, then the valve will not operate properly.
If you think it is ok then it is quite likely a valve fault, also check the filter built into the valve inlet.
Please post comments if further you have the same problem or you need more help or information........
Good Luck!!
Thanks
Dec 24, 2009 | Washing Machines
H20 error
Hello
I used to get this when i lived with my mum & dad and i can honestly say that it was the water pressure with this machine only a small drop in pressure makes the H20 error code appear you can always add additional water when it comes on so that the cycle can continue. You could find out from your water board if the drop in pressure is a leak in your area?
I hope this helps i had to persist with this problem for 18 months untill a leak around the corner was eventually found and fixed.
Regards
Wendy
May 27, 2009 | Hotpoint Ultima WF860 Front Load Washer
How to resolve 'Dust on Drum' error on Brother DCP 7020?
"Drum error" is because there is dust or any thing like ink on the drum.
After I filled the toner with a other brand dry ink, I got this message.
I carefully checked the drum, I found there was some ink on the drum. So took off the toner part, washed the drum kit with the tap water. wait it dry. There is a rubber roller inside, it will take time to dry.
after the drum kit dry, I rolled the drum, there still something on the drum, I use a tissue paper cleared it.
put the toner back, insert it back to the printer. It is fixed.
Nov 25, 2008 | Brother DCP-7020 All-In-One Laser Printer
Error code h20
hi sounds like a faulty fill valve easy fix
Sep 17, 2008 | Hotpoint Ultima WF860 Front Load Washer
H20 errors on Hotpoint WD640
this is normally a water valve problem
Jun 09, 2008 | Hotpoint Aquarius WD640 Front Load...
H20 f-08
the machine is sensing a flood you need to get it dryed out remove the front panel and dry out the bottom plate then press pause/cancel twice to clear Fault
May 28, 2008 | Hotpoint WF645 Front Load Washer
Hotpoint Aquarius WD640 Front Load Washer/Dryer Logo
1,305 people viewed this question
Top Hotpoint Washing Machines Experts
hungoverrr
Level 1 Expert
puggy666
Level 1 Expert
gbob59
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
