Question about Hotpoint Aquarius WD640 Front Load Washer/Dryer
H20 errors on Hotpoint WD640
Get H20 errors while washing or drying. Using Y connector and can confirm water is getting into machine
  • 1 more comment
  • Siadwell Jun 18, 2008
    Got a Hotpoint engineer out, they have to replace some modules, including an e-prom
  • ajmear Jul 02, 2008
    Just as described the h20 symbol comes on during the wash. the problem goes away if machine left off long enough
  • Anonymous Mar 15, 2014
    Had H20 flash for a brief second or so when 43 mins left.Checked on here about water pressure and pipes. Wiggled pipes to make sure not kinked now timer gone up to 53 mins
  • 66 Answers
This is normally a water valve problem
Posted on Jun 16, 2008
Problem with a hotpoint wmf760 aquarius + error code h20 coming up
You may have soap & grease in the pipe that leads to the pressure switch. Remove and flush through and/or replace. dry before refitting.
Thus constant high would give pump faults (thinks machine still contains water). Constant low may cause over filling. If you have a plug that suddenly moves, that can cause the above errors.
Jan 02, 2013 | Hotpoint Ultima WF860 Front Load Washer
H20 is flashing on my hotpoint washing machine
H20 indicates a problem with water supply.
Check the inlet hose/s for blockage or restriction, make sure the water supply is o/k, and the pressure is good, also check the inlet valve/s filters.
Apr 02, 2011 | Hotpoint Aquarius WD640 Front Load...
H20
Dec 17, 2010 | Hotpoint Aquarius WD640 Front Load...
H20 ERROR SPIN DRYING
The error indicates a problem with the incoming water supply.
Check for restricted or kinked inlet hose/s, check that tap/s are fully turned on and that you have adequate water pressure.
Mar 27, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
H20 fault is flashing on my hotpoint washing machine all connections are correct but still the machine will not fill with water?
H20 does indicate no fill.
Make sure that that there is an adequate supply pressure to washer, check that there are no kinks or restrictions in hose/s.
To be certain if you have an adequate supply turn off water valve to washer, disconnect hose and hold the hose into the sink or a bucket, turn the water back on, and see what the pressure is like..
If ti is too low, thjn the valve will not operate properly..
If you are satisfied it is o/k then it is quite likely a valve fault, also check the filter built into the valve inlet.
Dec 08, 2009 | Hotpoint Aquarius WD640 Front Load...
My hotpoint aquarius washing machine wd 640 is showing the fault h2o
The code h20 indicates means (not filling)
check the tap/s, hoses, and water inlet valve/s.
Please leave feedback.
Thanks.
Nov 12, 2009 | Hotpoint Aquarius WD640 Front Load...
Code h120
I think you mean code H20, if so it means no water coming in, check water turned on ,check hose(s), check filter in inlet valve is clean, check water pressure is sufficient.
Plz rate my solution.
Thanks.
Dec 28, 2008 | Hotpoint Aquarius WD640 Front Load...
Hotpoint
Here is the link to you washer. unfortunatly i can not find the error code you are seeing. you can contact them and have them let you know what the code means and what to do to fix it.
you will need to copy and paste this into your browser.
http://www.hotpoint.co.uk/macro/product.d2w/report?typeref=&prnbr=WD640
please do not forget to rate and comment about your experience with fixya today.
Aug 18, 2008 | Hotpoint Aquarius WD640 Front Load...
INTERMITANT FAULT
This is a plumbing error and not a machine error. H20 means "water turned off or valve faulty"
Jul 02, 2008 | Hotpoint Aquarius WD640 Front Load...
H20 error messages
h20 is normally a water valve problem please check these regards jason
Jun 09, 2008 | Hotpoint Aquarius WD640 Front Load...
Hotpoint Aquarius WD640 Front Load Washer/Dryer Logo
1,125 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
