Can I stop the loud ringing my TV makes when its on?
  • JOHN TOPLISS May 11, 2010
    Do you mean a bell like sound or buzzing and does it come from the speakers(if you turn the volume down does it stop) or from inside the tv
  • 927 Answers
Good Day.
What you are probably describing is a high pitch squeal. One can correct it by finding out what part is creating this vibrationm, apply pressure to parts in the high voltage circuit with a plastic device, and apply a silicon to that part. Some times by securing (tightening) the screws on the TV's chassis can stop this.
CAUTION: One has to be very careful if you try this on your own. I would recommend that you call a factory authorized service dealer to repair this for you.
Comment; sometimes the part has to be replaced.
Good Luck.
Posted on Jun 11, 2008
NOISY FRIDGE
hi glenn ,most fridges make this noise but if your worried ring the place you brought the fridge from and get them to send an engineer to check it. good luck
regards
shaun
Dec 09, 2011 | Washing Machines
Loud static noise without warning
The audio may be randomly disconnecting or something. I know that when my TV has no signal coming in, that it makes a bunch of loud static.
Jun 04, 2010 | Tatung V20KQDX 20.1 in. LCD Television
My fans are very loud do I need to replace them
check the plastic rings behind the fan blades, check to make sure plastic rings is tight and the screws holding fan cage on. Then when putting the fan cage back together, make sure it is tight so it wont vibrate
Jul 20, 2009 | HP (219462-001) Cooling Fan
TV makes aloud ringing sound
does the sound come from the speakers are from the back of the set. there is a small number of cases where the is oscilation in a coil.. the way we counter this at the shop is we dampen the coil with some silicon, not sure this problem you have. ll007 is the number on the coil.careful this television generates high voltage and retains this even unplug
Nov 25, 2008 | RCA HD52W59 HDTV Projection Television
How do I make the sound loud all the time and not ascending to loud?
go to profiles
go to go to general
go to personalze
go to call alert type
and change it to ring and vibrate or just ring
if that dont work go to ring volume and press loud
then press back and activate
Jul 22, 2008 | LG Cell Phones
Loud ringing noise
it is due to no signal from the source.
Sep 29, 2007 | Apex Digital AT2008S 20" TV
HOW TO STOP VERY LOUD SCREECHING RING
Assuming there's nothing in the manual that tells you how to stop it. Is there a hole where the sound comes from? Block it up with blu-tack or sticky tape. Regards
Sep 25, 2007 | Canon FAXPHONE L170 Plain Paper Laser
HOE TO STOP VERY LOUD SCREECHING RING
I have the same problem. If you get an answer, please share with me. thank you....
Ringing noise
try changing the cable going out of tv to the system for audio, make sure the cable from tv/sat receiver is in audio out and in dvd player in the Audio In under the Video 1 bracket, then when you turn on the system click function button on the front panel it will show Video 1 on the LCD and that should work.
Aug 19, 2007 | Sony DAV-FC9 System
Televison & Video Logo
35 people viewed this question
Top Televison & Video Experts
Electro Med Services...
