Question about Olympus SP-550 UZ Digital Camera
Drained batteries I have a FE210 digital camera the batteries go dead after a few pictures yet when I check the batteries they era good. purchsed 4 aa size batteries-had 25/30 shots. bought 2500mah batteries, charges fully-- had 20/30 shots or half an hour of camera operation and battery shows empty on screen. tried a couple of times but in vain. the empty batteries are inserted in other digital cameras, its running fine. checked the camera with olympus authorised repair agency, they say camera is at no fault. i am confused and cannot use it properly. can anybody help?
  • 57 Answers
Digital cameras do use a lot of power to operate. Somethings can make the batteries die faster. Even if the batteries may have worked in other cameras after ou used them in yours could just be that the other camera requires less power to operate then yours. Turning off and on the camera or simple viewing them can use more power then usual. Try and avoid this to see if it last longer. Also, try and see if there is an auto shut of to save power when you leave the camera on. If you have an eye piece use that to take pictures instead of the display this will also save on power consumption. Also, when you know that you won't be using the camera for awhile meaning you are storing it then remove the batteries. Some electrical items even if the camera is off they can still be draining the batteries.
If these don't help then I would have it looked at especially if you are under warranty.
Posted on Jun 10, 2008
I got the kodak easy share 143 model camera coming brand new off of ebay yesterday,,,but it keeps saying my batteries are half drained, then dead after a couple of photos. Then if they're dead it...
Alkaline batteries just don't have the power for more than a few pictures in today's power hungry digital cameras. Some batteries may also have reached their shelf life at the store, and though brand-new right out of the package may even have problems just powering startup of the camera. The one's that came with your camera are just to show you that the camera works, but as you've discovered, they'll only last for a few pictures. Digital cameras that use AA's for the most part should only be used with modern rechargeable batteries. If you read the camera's instruction manual concerning batteries, you should see the same recommendation.
Modern rechargeable batteries have over 5 times the power density of alkaline batteries (that's right, they last up to 5 times longer than an alkaline battery. And you can recharge them over and over!). Keep in mind rechargeable batteries will save you much money in the long run over alkalines, AND they'll last for at least 100 pictures per charge (and probably many many more). You'll be very pleased with their performance, and may be angry with yourself for not buying them sooner. When at the store, look on the package for a power rating of at least 2500 mah.
Jun 26, 2011 | Kodak Cameras
Draining rechargable batteries;
Carry spare alkaline batteries - just in case...
Does the same symptom happen with alkaline batteries?
Lithium Ion batteries are 1.2volts
Alkaline are are 1.5volts
Rechargeable Alkaline batteries are 1.5volts
Perhaps you should switch to Rechargeable Alkaline batteries if the symptom goes away when you use alkaline batts...
Sep 17, 2009 | Samsung Digimax D53 Digital Camera
Cost for AA battaries for Olympus FE210
A 4-pack of rechargeable Energizer AA batteries is available at Walgreens for $12.99.
Sep 08, 2009 | Olympus FE-210 Digital Camera
How can i set the shutter speed of olympus fe210 digital camera?
Is this a point and shoot camera? If so, you can't set the shutter speed.
Aug 13, 2009 | Olympus FE-230 Digital Camera
Kodak Z1085 IS - drains battery even when camera is not on
the camera takes 1.5v to operate it
anything less the camera will shut down
recharge batteries are only 1.4v so at full
recharge it won't last long
The best batteries are litheum that have the right
volts and capacity to keep the camera going.
try turning or the camera stablizer setting...
might save your battery power.
Mar 17, 2009 | Kodak EASYSHARE Z1085 IS Digital Camera
Only a whilte screen appears when i turn on my camera(fe210)
lcd screen may be broken... or batteries not making good contact
Nov 25, 2008 | Olympus FE-210 Digital Camera
Olympus FE210
Yes you can still upload your pics to your PC. Go to Olympus' web site and download the software for the FE210.
Oct 21, 2008 | Olympus Camedia C-350 Digital Camera
BLACK SCREEN, OLYMPUS FE210
You must go to a camera technician. There are some parts inside that already been loosen. That's what happened to my camera before.
Feb 16, 2008 | Olympus FE-210 Digital Camera
Drained batteries
Stop using this camera (Olympus FE-210), warn all your friends and relatives about this piece of junk, send the camera back to Olympus COD. Take the money you save from not buying more batteries for this camera and buy a decent camera from a reputable manufacturer.
Feb 02, 2008 | Olympus FE-210 Digital Camera
S2 suddenly draining batteries rapidly
I have the same exact problem. I just now read a possible solution: try opening the battery compartment door and then closing it again to "trick" the camera into thinking it just got new batteries. There is definitely something wrong with the way the camera senses dead batteries.
Jul 28, 2007 | Canon PowerShot S2 IS Digital Camera
Olympus SP-550 UZ Digital Camera Logo
124 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
