Question about Compaq Presario R3000 Notebook
My laptop turns itself of after 8 minutes - every time i turn my laptop on it lasts for about 8 minutes then turns itself off automatically how do i stop this? I am trying to find drivers for my laptop its a lavie NEC company, Model PC-LL5503D1Y. I lost my cd for the drivers and im finding all sorts of problems including crashing, not able to use my web cam or any usb port due to lack of drivers please help me.....
  • 2 more comments
  • abreram Jun 30, 2008
    My Averatec 3250HS had the problem that it seemed to get hot and then it would turn itself off. I also believe because of the increase in temperature. What I did was opened it up and then my son put silver compound between the CPU and the thermal element to make better thermal contact. They had separated and they were not making good contact. That solve the problem.
    The problem i have now is that I thought I would never need the CD and throw it away and now I dont have it and I need to reload the Windows OS and it is giving a hard time. Any help !! ??
  • anthonye Jul 14, 2008
    hi all, my laptop is turning its self off in between 30 mins to an hour. an the fan is constantly runnin... straight from start up!!..
  • aa85 Dec 26, 2008
    It is overheated after 10-20 min and turning it self down
  • Anonymous Jan 04, 2009
    my lap top turns off when im notusing it
May be you have tampered with the properties try this step
1 on the desktop right click and go to properties
2move to screensaver
3move to monitor power
4you see monitor setting and click on never turn off monitor.
Posted on Jan 12, 2009
Maybe your computer is overheating and turning itself off, happens to mine sometimes but not as often as 8 mintues.
Posted on Jun 09, 2008
I have Samsung 6272 when I charged the phone is full after 5 minuts I change the batter and charge but m problem not soluve ?
The very first charging-time of the battery should most-usually last 6-8 Hrs , and if you did not do the same i suggest you drain your battery to the bottom until it turns off by itself , then plug in the charger and leave it charging for 8 hours (meanwhile the phone should be turned off ) . should be fine after ;D
(in case you did everything as you should and encountered this problem long time after you using the phone , all you can do is replace the battery)
Dec 31, 2014 | Samsung Cell Phones
Computer turns on by itself
Some computers have an option in the BIOS or System Setup Menu to turn the laptop on at a particular time. It's a good feature for people who turn their laptops off at night because the first thing a computer does when you turn it on is to load all the startup software, then begin downloading and installing any updates it might have missed while it was turn off or start running a virus update or scan. That's why computer seem so slow when you first turn them on for about the first 10 to 20 minutes or so. So if I turn my computer off at night and I know my day gets started at 8:00am every morning, then I can set my computer to turn itself on every morning at 7:00am by itself. That way when I go to use it, it's good and fast.
Mar 19, 2012 | Computers & Internet
HOW DO I RESET THE THEFT SYSTEM IN MY 2004 DODGE NEON?
Let the car sit undisturbed for 10 - 15 minutes, then try to start it. Check the owners manual if you have it. Sometimes, on various cars letting them sit awhile will allow the system to reset itself. On others sometimes rapidly turning the key from off to on, without turning to start 3 to 8 times within 10 seconds and then on the last turn to the on position leave it there until the horn chirps, at that point turn the key directly to start, or turn off first and turn to start. If all this fails, a dealer can reset the system.
Aug 03, 2011 | 2003 Dodge Neon
My laptop turns itself of after 8 minutes - every time i turn my laptop on it lasts for about 8 ....
When the CPU overheats then it will shutdown (i.e. thermal overload) and won't boot up again until it has cooled down.If this is the problem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are cloggedwith dust.
Check the CPU fan to see if it spins freely, if not replace the fan. If the fan and heat sink is clogged withdust the remove the dust and make sure the vents are clear and dust free. Use acan of compressed air to do this.
Feb 13, 2011 | Computers & Internet
My laptop turns itself of after 8 minutes - every time i turn my laptop on it lasts for about 8 minutes then turns itself off automatically how do i stop this? My HP laptop keeps shutting itself off after...
Sounds like something to do with a power saving feature either from HP itself or from Windows. It could also be that for some reason your computer is overheating, which it than shuts itself off to protect the processor. I would try playing with your power saving features, and cleaning out the fans.
Mar 13, 2009 | Computers & Internet
hi,
Please check for the exhaust,is it coming properly and check the bottom of the Notebook is it heating ?
If heating then this is the issue with the processor fan.
If the temprature is normal then check in BIOS(leave the system in BIOS mode for 8 minutes) if then also it is turning off surely this is the heating issue.
If above mentioned is not working please revert.
Feb 09, 2009 | HP Computers & Internet
My laptop turns itself of after 8 minutes - every time i turn my laptop on it lasts for about 8 minutes then turns itself off automatically how do i stop this? I am trying to find drivers for my laptop...
check whether the hiberbnate facility is on or off as it is turning off after 8 min or so.
this can also happen due to overheating of the processor , it can turn off itself automatically
try to increase the ram on the system
http://www.driverfiles.net/Other/NEC/page,level2,866,3,resultpage1.html
Jun 09, 2008 | Computers & Internet
My laptop turns itself of after 8 minutes - every time i turn my laptop on it lasts for about 1minutes then turns... 1 Solution
do you hear any fans spinning? it sounds like possibly the laptop is overheating although that is very quickly. do you have any more information? what does it do when it stops? when did this problem start?
Apr 14, 2007 | Acer TravelMate 233LC PC Notebook
Compaq Presario R3000 Notebook Logo
171 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
