Televison & Video Logo
Posted on Jun 09, 2008
I have just purchase a samsung dvd-v6800 dvd/video player. I am unable to play some dvd's that are not region 4. Is there a solution for this? Thanks, Helen
  • Yupbaik Jun 09, 2008
    I can't play DVD's from Korea and US.
    How can I unlock the region code?
    Thanks, Yun
Yupbaik
Level 1:
  • Contributor 1 Answer
  • Posted on Jun 09, 2008
Yupbaik
Contributor
Level 1:
Answers
Questions
0
Helped
173
Points
0
I have just purchase a samsung dvd-v6800 dvd/video player too.
Could you please help me with setting up region free?
[email protected]
Thanks, Yun
REGION 1,DVD
Region 1 dvds are usually USA/Canada dvds and will play on any dvd purchased in those countries. You didn't state your location so I don't know where you are. Google your location for dvd region to make sure.
Changing area regions on DVD
please follow this steps and fix it. Merry Christmas.
Turn on your DVD player.
    • 2
Open the DVD player's main drive, also commonly called the DVD "tray." The region cannot be changed while a DVD is in the machine, so many DVD players require the tray to be open as an extra precaution.
    • 3
Push "Info" or "Setup" on your remote.
    • 4
Use the remote to select the "Region" option as indicated on your TV screen.
    • 5
Select "Region 9" to change the system to multiregion formatting. Regions 1 through 8 represent specific geographic locations and will not allow multiregion playback.
Hi, I have a samsung dvd/vcr combo player model number v6800 which I hacked to be region free. It now plays dvds with region codes regardless from where they originate (ie; 1 or 4), however, some of my...
If the dvds which are "all regions" are recorded from a computer, your dvd player may not play them. I assume the dvds which have a region code have been professionally prepared. Sometimes, the cheap dvd players will play anything while the more sophisticated ones will give you trouble unless everything is just perfect.
2helpful
2answers
I was just wondering if Magnavox Dvd/VCr combo MWR20V6 is a multi-region dvd player?
all dvd players are region free when you first buy them, they set the region themselves, after 5 dvd's have been played on them. So if you had a european dvd player and played 5 USA dvd's on it , it would lock to the USA region and you would be unable to play european dvd's on it. Exactly what a friend did many years ago when he bought a load of american dvd films from someone and played them on his brand spanking new dvd player :)
3helpful
Change region code on a samsung v6800
This is not promised to work but a known hack for your model of DVD player is...
Make sure the player is switched on, and is at the Samsung logo
screen. Also check the tray is shut and that there's no disc in the
player.
Now press the REPEAT button on the remote, followed by a five digit
code. This code is different depending on what region your player is
*currently* set to:
R1 - 29334
R2 - 38767
R3 - 56732
R4 - 76884
R5 - 53814
R6 - 24462
So for example if you have an R2 player, press REPEAT-3-8-7-6-7.
If you've done this correctly (and your player is compatible with the
hack), you should see a number at the top left corner of the screen
corresponding to the current region.
Now, pressing any number from 1 to 6 will change to the corresponding
region. Or, press 9 for auto-region mode.
Next, press OPEN/CLOSE to open the tray, followed by Standby (or DVD
POWER) on the remote to close it and put the player into Standby mode.
The next time you turn your player on, the new region will be set.
Don't forget that if you want to hack it again, you'll need to use a
different code, as listed above. If it's currently set to region 9,
use the code for the last *proper* region you set it to.
People have reported a problem with the codes given however another was posted (57538) try that one to!!
11helpful
2answers
Unlock code samsung dvd-v6800
i have done what you have write about region free for Unlock code samsung dvd-v6800 and i can not see nothing on my screen
Regional codes
you can buy or download a disc that you put into the dvd player and it will unlock it to all regions
3helpful
2answers
Samsung P480 dvd player- To Play all region dvds
how can I play *.mp4 files in samsung dvd player model no P480?
4helpful
I have Samsung DVD Video Combo
player.
*currently* set to:
R1 - 29334
R2 - 38767
R3 - 56732
R4 - 76884
R5 - 53814
R6 - 24462
If the above codes don't work try 57538.
Hope this helps.
7helpful
4answers
Region code for Samsung DVD-V6700
1. Make sure there is no DVD in the drive. The player must be empty. Turn on the player, (the Samsung logo appears)
2. Press the SUBTITLE button on your remote
3. With your remote enter the code: 76884
4. The current region is displayed on the top left corner of the screen. (e.g. 4)
5. Press 9 on your remote (Region free)
6. Again press the SUBTITLE button on your remote
7. Enjoy the Region free player
If your player is NOT Region 4 by default then you will need to Substitute the Numbers in Step 3 with the ones Below.
Region codes:
RC 1: 2, 9, 3, 3, 4
RC 2: 3, 8, 7, 6, 7 (or 5, 7, 5, 3, 8 )
RC 3: 5, 6, 7, 3, 2
RC 4: 7, 6, 8, 8, 4
RC 5: 5, 3, 8, 1, 4
RC 6: 2, 4, 4, 6, 2
For Example if your Player was Purchased in the USA ( Which is Region 1) then Step 3 would read :-
3. With your remote enter the code: 29334
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
