Question about Whirlpool Dryers
Knocking coming from dryer. - Whirlpool Dryers
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 210 Answers
Most likely the noise is coming from your rollers. Could be a flat spot and when it heats up goes away or if it is constant could be a damaged roller. Check the joint on the drum as well.
Sgt 48
Posted on Jun 09, 2008
Kenmore he3 dryer front load knocking noise
Check the tensioner pulley that keeps the belt tight. It is next to the motor and the bearing may be shot.
Mar 08, 2014 | Kenmore Dryers
Bad noise coming from dryer,i changed the belt and still have a noise..help
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker
Jan 01, 2011 | Hotpoint TDC32 Electric Dryer
Dryer is knocking,on left rear side you can feel the knocking and when you press it knocks louder
ALWAYS UNPLUG YOUR DRYER BEFORE STARTING ANY REPAIRS
Your problem sounds like drum rollers have flat spots on them or in need of lubrication.
If you have a front loading machine,
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer.
Be REAL CAREFUL not to knock any of the wires off of the timer switch.
Then remove the top of the dryer.
Remove the front of the dryer. This will expose the drum and belt.
Remove the drum and belt and this will expose the drum rollers, idler arm
pulley and motor.
Now is a good time to check the belt to see the belt condition for wear.
Be sure to note the route of the belt, this will come in handy when you go
to reinstall the belt.
Check your drum rollers for flat spots or wear, if they have flat spots
or wear on them replace them.
If the drum rollers don't have flat spots or wear on them then they probably
only need lubrication. Lubricate the shaft of the rollers with a good grade
of machine oil such as 3 in One oil.
Reassemble the dryer, plug back in. This should solve your noise problem.
Please rate me
Dec 09, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Very loud noice coming from dryer. Sounds like belt
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Nov 23, 2010 | GE Profile DPSB619ED Electric Dryer
My dryer starting knocking, it knocks loud then gets a little slower then starts loud again.
Dryer2_bing.gif Repair Squeaks, Grinding, Clicking and Knocking Noise
http://www.fixya.com/support/r4416566-dryer_repair_squeaks_grinding_clicking
heatman101
Jul 09, 2010 | Frigidaire GLEQ2152ES Electric Dryer
My Gallery dryer has just developed a knocking sound. Like a clock ticking (knock-knock), (knock-knock), as the tub goes around.
The most likell cause of that would be one of two things. Both are fixed easily.
First check your belt, it may have crack developing in it or a chunk has come out it which will cause the knocking sound.
The second cause could be that a guide wheel has lost a piece out of it or the bearing holding the wheel is going bad.
Either way it is in the drive train of your unit and you will need to open it up and see what is thumping.
You can then order the parts by doing a seach for "appliance parts". Choose a site and then enter your model number. Most sites have exploded views and a parts menu for your unit.
Check a number of sites as there is no one site that always seems to have the best price.
I hope that this will help you to solve your problem!
Thanks for using Fixya!!
Heatman101
Dec 03, 2009 | Frigidaire GLEQ2152ES Electric Dryer
Drum
repl/ drum rollers that its should fix the knocking noise
Dec 30, 2008 | Kenmore 74602 Gas Dryer
Knocking sounds
Ususally knocking is a sign that the rubber belt which spins the dryer tub is old and has hardened. If the knocking sound gets quieter after you have run the dryer for 30 minutes or so, then the belt is the problem. As the dryer turns, it heats up the rubber belt and makes the belt more pliable. This quiets the knock. I have seen dryers work fine for years, knocking the whole time. Have the belt replaced if the sound bothers you.
Sep 07, 2007 | Maytag Atlantis MDG6400AW Gas Dryer
Dryers Logo
32 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
