Question about Samsung Televison & Video
No picture when cables connected
Hi I have a Samsung rear projection tv and I am trying to connect my set top box with high def cables through the dvd input but there is no picture. What can I do.
  • Christa Dening
    Christa Dening May 11, 2010
    What's your tv model number, and what kind of high def cables are you using? What do you mean by dvd input? Do you mean that the cable box is going through your dvd player?
    Novelist:
    Champion:
  • 203 Answers
Go into menu on cable remote and open up 480p,480i,720 and 1080 . I think on some of those 1080HD only works on one of the two component inputs. The other is only rated for 720. Usually it has this info on set at input. Hope these suggestions are helpful.
Posted on Jun 10, 2008
I cannot turn to channel 3 anymore to receive cable service.
Do you have a Hi Def box? If so, connect component cables from the box to a input on TV. Also try to change channels manually on set.
Nov 11, 2013 | Panasonic PT-47WX49 47" Rear Projection...
When I turn on the TV, the picture is fuzzy. After five minutes, the picture is clear but any words are out of focus even the menu for adjustments is out of focus. The convergence for red is clear but...
Below are some troubleshooting tips for a TV that has a fuzzy or blurry picture;
If your Plasma or LCD TV picture is blurry or fuzzy there are several things that may be causing the problem. It's worth running through the following list before seeking service. You may find yourself saving the full cost of a TV repair.
Make sure you are using the appropriate cable box for your TV. If you have a high-definition TV you should also be using a high-def channel box from your cable provider. Watching standard definition channels on a high-def TV can make the picture look distorted and fuzzy.
Not all cable channels are broadcast in high-definition. When you stretch a standard definition picture to fill the full frame of your wide-screen TV it may look distorted. You can try changing your TV display settings to show standard-def channels at their native resolution. This will create black or gray bands on either side of your picture.
Ideally all of your video components will be connected to your TV with HDMI cables. Your next best option will be component video cables. If your cable box does not have HDMI capabilities, contact your cable company about upgrading your box to one that does include HDMI.
Make sure there is no glare on your TV from a window or other strong light source. This can significantly degrade the quality of the image you are watching.
If your TV has digital noise reduction, try turning that feature on.
You can adjust your TV's sharpness and picture modes to see if that improves picture quality.
Try plugging the power cord into a different electrical outlet and/or surge protector. You may be receiving electrical interference through your power cord.
Trying moving any nearby electrical devices away from the TV. They may be creating interference that can degrade the picture quality.
Let me know if the above helps or not, so that I can direct you further on what do next.....
Best regards.
Apr 14, 2011 | Zenith IQB50M90W 50" Rear Projection...
When cable hooked up picture ok a little blur but when dvd or ebox hooked up picture is great. what can be done
It's probably because your standard cable has lower resolution than your DVD player or Xbox console. If you're going through a cable box and can eliminate that (depends on your TV and cable system) that might help, otherwise you would have to upgrade to hi def cable to have comparable resolution... hope this helps.
Jan 17, 2011 | Samsung HCM5525W 55" Rear Projection...
I have a High Definition ready TV, I'm trying to hook up an Epson High def box to it ,I have it all programed in but there is no High def picture. I went and asked the cable company and they said the High...
HERE is what you are looking for I presume.......DVI to Component correct??? if this is not it, pls be more specific in regards to the connection on the converter box.....'
GOOD LUCK AND PLS RESPOND TO THIS POST!!!!!!
Feb 24, 2010 | Zenith R50W46 50" Rear Projection...
No picture - only sound
Ok, on a hi-def tv, you must have a converter box capable of receiving Hi-def. If you are using a converter box from a satalite or cable tv service, try getting a Hi-def box. Also try hooking a vcr or dvd player to the tv in the non high def ports to varify that this is the problem. If you have any question please let me know, I hope this helps, good luck.
Sep 23, 2009 | Philips Magnavox 51MP392H Rear Projection...
Powersurge made my HD setting revert to low def.
Your TV plays High Def material through either Input 4 (uses component cables R,G,B) or through Input 5 (Uses DVI cable).
Today most equipment uses HDMI cable for High Def or it may have a component (RGB) output that you can use. The DVI hookup is best, so you need a HDMI to DVI cable or Component Cables (Red, Green, Blue). You need some source that OUTPUTS High def (ex. 1080i) either through HDMI or component cable. You need to either connect the component cable(R,G,B) from the source to the Input 4 on the TV or connect the HDMI to DVI cable from the source to the Input 5.
You need to set the AV source on the TV to AV5 (if you are using the DVI input) or AV4 (if you are using component cables).
If you want to play Highdef source like Blue Ray then you can just connect the output of the blu ray player to your Tv using either the HDMI to DVI cable or component cable (Red, Green, Blue) and set the TV input to AV5 (for HDMI/DVI) or AV4 (for component).
But if you are trying to get Free High Def from an antenna then you will need to have a component that can OUTPUT high def. The $40 converter boxes don't do this - they simply convert the Digital signal to Analog (non high def). What you need is a High Def TUNER that OUTPUTS High Def. I was looking for one for this same reason and ordered the centronics ZAT 502 HD. But it cost about $80. Then I saw that Tivo had an upgrade deal where I could upgrade my existing Series 2 Tivo to Tivo HD for $99. It has a High Def Tuner in it. So I cancelled my order with Centronics and got the Tivo. In any case if you want Over the air HD you will need a High Def Tuner that will OUTPUT 1080.
Jul 02, 2009 | Philips 55PW9363 55" Rear Projection...
Hi-Def?
Yes, it is HD TV ready but you must have a set top box from your cable or dish company that provides a Hi Def signal. The inputs must also be connected with the YRB cable. Only certain channels on my box are HD. The screen is so large that HD isn't nearly as impressive as some of the smaller models but it is still HD. I also have the 53FDX10B.
Mar 03, 2009 | Hitachi 53FDX01B 53" Rear Projection...
Hooked up a hdmi/dvi cable
try using the red- blue- green high def connections
Dec 08, 2008 | Hitachi 57F500 57" Rear Projection...
No full widescreen on HD broadcasts
Do you know what the aspect and resolutiuon settings of the cable box are? What brand of cable box is it?
Nov 27, 2007 | Samsung HLP4663W 46" Rear Projection HDTV
Colors Off with High Def Comcast Cable
check your cable connections between tv and box, especially the red connector, try unplugging and plugging back in the cables.
Jul 09, 2007 | Sony Grand WEGA KDF-55XS955 55" Rear...
Televison & Video Logo
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
