Question about Sharp Televison & Video
Sharp LC-32GD9E I have this 32" screen Sharp TV which is about 12 months old. On several of the channels, particularly on the British channel 5, I get very loud clicking and either no picture at all or a very broken picture. Since new the TV has always made inexplicable clicking noises, together with picture freezing, from which it soon recovers. This is the first time it has effected a complete channel. I have a smaller(24') Sharp LCD model which does not have this problem. Hope you can help. Regards. Brian Thompson
    President:
  • 1,284 Answers
Is this TV connected to a digital box or directly to an antenna? If its connected to a box then suspect the box first. If the box has been swapped with another one and still does the same thing, then the TV has a bad tuner and/or digital board. The tuner in most TV's is part of the digital board and must be replaced together.
Posted on Jun 10, 2008
TV only detecting channels 2-13 should be detecting 2-63
Go back to the initial set up procedure for your Sharp TV and do a search for active HD channels. They will be decimal numbers such as 13.1.
Jan 13, 2014 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
I just changed from Comcast Cable to Verizon Fios. Since the change I am unable to get a full picture on Fox News. There is a narrow horizontal picture with 1-2" black bands across the top and...
This is a function of your set-top box (STB), and has nothing to do with the TV. I know several FiOS users with the same trouble, and it's annoying but there isn't anything you can do to "fix" it. What is really strange is that the screen size can change even on the same channel, depending on the particular program being broadcast. It has to do with the aspect ratio of the programming from the provider.
Jan 12, 2011 | Panasonic CT-32G23 32" TV
Sharp Aquos LC-42D62U 42in hdtv lcd How do I get the channels to change faster? It's like a delay compared to my other hdtv
There is a 3-5 second delay between the channels when you change them on these particular tvs and there is no way to change that unfortunately.
Nov 02, 2010 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Varous tv channels do not have sound. It is NOT a
TO: rdh041: I don't have the solution to you problem, but we have the exact same problem with our Sharp AQUOS 20" LC tv. Different model than yours, but same age and same perplexing issue. Several channels suddenly have no sound. If you've found a solution, would you please post it? I'll do the same. Thanks.
Jul 15, 2010 | Sharp Aquos LC-20B6U/LC-20B6E 20 in....
Sharp LCD TV ad volume higher than program volume
It is a problem of the transmission of that particular channel or your channel provider. If this problem is common to all channels, complaint it to your service provider. Else complaint it to the responsible channel (Not actually necessary as others might have done it and they might be already trying for the fix). This is not a problem of your television set and need not worry about that.
Apr 17, 2010 | Sharp LC-32AV22U 32 in. LCD TV
Sharp 32 inch lcd tv won't reconginze channels when connected to antenna. Why? The screen now looks like a defragmenting on a computer screen.
You probably need to do a channel scan to find TV channels and progrma them to the TV memory. Using your remote control select Menu mutton and follow instructions for "auto channel scan"
Jan 17, 2010 | Sharp LC-32SB24U 32 in. LCD TV
32 inch Sharp Aquos is less than a year old... I changed that channel and the picture was green or gray... i changed it again and got a normal picture once but now all channels are looking blank with a...
Contact Sharp to locate the nearest authorized Sharp servicer. Sharp Aquos servicers have to give Aquos TV top priority. Sharp provides very good and fast serice on these sets.
Apr 26, 2009 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
New TV won't ''talk to'' old VCR
using the magnovox remote, reprogram the vcr's channels. set it up to use cable not air. when the vcr was unlugged it lost it's channel memory. don't buy new cables, you're getting a picture and sound so that means your rca cables are ok.
Jan 20, 2009 | Sharp Aquos LC-32D40U Television
No display on Sharp LC 32sh20u
blue screen,no video but has sound
Dec 18, 2008 | Sharp LC-32SH20U 32 in. LCD HDTV
TV gets stuck on channel, won't advance past channel 7.1
Try doing the Channel Search again. See if that helps.
If not, sounds like the Digital Board could be defective. Since this TV is brand new suggest calling your local sharp authorized service center to replace that board under warranty.
Mar 16, 2008 | Sharp AQUOS LC-32D43U 32 in. LCD...
Televison & Video Logo
152 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
