Question about Packard Bell iMedia SL 9553 (P660401806) PC Desktop
No sound I needed to take pc for new power pack. I did not do the disconnecting ,now there is a purple plug coming from the speakers (not a small male...larger more like a charger type plug) there is no sound I cannot see where this plug goes .any help appreciated
  • 1 more comment
  • tomsam123 Jun 09, 2008
    I forgot to say this is an old packard bell similar to SL 9553 PC
    Tomsam
    There is already one (Green) in the green socket and all the sockets are small males,green light blue and pink/purple.
    Tomsam
  • Anonymous May 12, 2009
    My cmputer just came back from the repair shop and the same thing, a purple lead with no where for it to plug in....hence no sound. I phoned them and he doesn't seem to understand?!!
Sound ic change
Posted on Jun 09, 2008
    Novelist:
  • 142 Answers
Try to connect it in the green socket (circular) at the back of your computer
Bad quality sound
Try plugging into a powered speaker set. The speakers in the laptop are very small.
Nov 15, 2014 | Toshiba Satellite 15.6" C855D-S5230...
No sound at all emitted through the speakers even though i see the spectral display of sound on the desktop player indicating that music is playing.
Do your speakers require power? If so are they powered? You can tell just by hearing static/noise when you disconnect the speakers connector and plug it back in.
If they are not powered, are you sure you are plugged into the correct port on the PC? It will have 2 half circles with an arrow pointing outward.
If none of the above work, try plugging the speakers into something else to see if they work, like a CD player, or cell phone (if you have a new one with RCA output). This will check and see if the speakers are actually working or not.
Oct 11, 2013 | IBM NetVista PC Desktop
How to add External Speakers to HP Omni 120?
If your speaker icon is missing go to Start > Control Panel > Hardware and Sound > Manage Audio Device > Sound. In Playback Check levels and configure speaker setup, like 2.1 or 5.1.
There is only one small green 3.5mm speaker output in the back. Number 5. That's it!
Anything else is on the Microlab side. They should chain togetherending up with that small male 3.5mm plug. GL11_15_2012_10_35_24_pm.jpg
Nov 13, 2012 | HP Omni 120-1125 20" All-in-One Desktop PC
Need a link for the directions on how to connect cables to the computer. serial #105255894
Connections
> Blue 15 pin or white 16 pin colour port is for monitor.
> 3 pin female port is for power cable for Computer Tower
>3 pin male power cable is for monitor
> Purple and green colour port is for Keyboard and mouse if they are ps2 (round connector) if usb then connect in any usb port.
>Small 3 colour ports Pink,Green,Blue is for sound.Connect only the Green colour cable coming from speaker to green port
>Connect the speaker Adapter cable to the wall socket for supplying power to speakers.
> RJ45 (Ehternet port-port which looks like phone connector but little bigger will connect Internet cable if you have internet.
Connect and Enjoy
Sep 08, 2010 | Systemax Tiger (SYXS-DC-1000) PC Desktop
No sound coming from my speakers
Possible scenerio's with the little info you gave.
1.You have a bad speaker thats blown or the wires are touching the chassis of your car.
2. You have a factory amp and you need to connect the blue wire to the amp turn on wire. And if it still doesnt work then you have to rewire it complete or maybe have to get a special car amplifier compatible harness so your aftermarket works with your amplified system in your car.
3. In certain Ford cars they crisscrossed the back speaker wires. To test this unplug your harness from the radio. VERY IMPORTANT( splice these colors of wires in the middle enough so you can use a 9volt small rectangular battery to make the speakers you want to test pop(harmless))
1. green = back left + speaker
2. green/black = back left - speaker
3. purple = back right + speaker
4. purple/black = back right - speaker
test green speaker wires first touch battery to the + and - and the speaker should pop if not you have already discovered the problem. Know this time pop the green + and the purple/black - on the 9volt battery if the speakers pop you have found the solution.
Just criss cross the the negatives of the back speakers. From the radio harness end attach green to green, purple to purple, green/black to purple/black and last purple/black to green/black. And all your speakers should work again.
Dont ask me why late Ford Models crisscrossed their speaker wires. They just did.
Apr 08, 2010 | JVC KD-G140 Car CD Player
I Do Not Know How To Connect Boston Micromedia To My Computer
The Boston Micromedia speaker set comes with two speakers (right and left),a subwoofer, and a complete set of cables to connect everything up.
1.) Position the speakers. The two small speakers typically are spaced equal distance apart on a desk/table top to the benefit of the listener. The sub-woofer typically rests under the surface, on the floor for example.
.) Connect the cable sets to the back of the two small speakers along with the speaker feet.
Note: the small speaker with the volume control knob will have three cables coming from it. This will be the "right" speaker. The other speaker will have a single cable and will be the "left" speaker.
2.) The cable ends will be color coded to match the jackson the sub-woofer. Match up the color coded cables to the respective colors on the subwoofer as follows:
(a) White cable end (left speaker) to white jack on sub-woofer.
(b) Red cable end (right speaker) to red jack
(c) Purple cable end (input) to the purple jack
(d) Green cable end (computer out) to the computer's microphone output jack.
Note: if any of the cables are too short to reach their jacks for whatever reason, an extender cable with a female and male end can be purchased relatively inexpensively to make up the difference in distance.
3.) Power up the system (plug in power cables to the sub-woofer and wall), play some music, and adjust the sub-woofer sound (control knob) to suit listening pleasure.
A nice little set of speakers, I had mine for some years now and continue to enjoy them. Good luck!
May 17, 2009 | Boston Acoustics MicroMedia Computer...
No sound
Try plugging in earphones to see if the problem is the speakers or the output from your computer. Also, your computer output may be low power output for powered speakers and your speakers are not compatable. You may also be plugged in to the wrong output on your computer.
JG in AZ
Apr 11, 2009 | Boston Acoustics BA7500 Computer Speakers
Seems to be no power to speakers.
Disconnect green speaker jack from computer and see if you get a green power light on speakers. If the speakers indicate they have power, your sound card or circuit is shorting out the speakers. If you still have no power to the speakers when disconnected from computer, then no green light means no power to speakers. Either you’re A.C. adaptor is bad or the speakers are shorted out. You have 2 options:
1) Replace A.C. adaptor.
2) Replace speakers.
If you buy new speakers, make sure that they have their own power source (A.C. adaptor).
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Jan 19, 2009 | Dell A215 Computer Speakers
Altec speakers
are these plugged in from the back, with a small power pack(black) that provides power for them? can you supply a model number from those speakers?
Apr 30, 2008 | Computers & Internet
No sound comming from speakers for monitors
it could be:
  • the sound has been muted,
  • you need to re-install the sound driver for the sound card or chip, un install first
  • make sure you have the speakers plugged into the green socket and it is turned on ,most speakers have a small light that comes on when the power is on
  • the sound card or chip has died.
good luck & please rate my efforts
Terry
Apr 05, 2008 | Computers & Internet
Packard Bell iMedia SL 9553 (P660401806) PC Desktop Logo
Top Packard Bell Computers & Internet Experts
Alun Cox
carey w mason
carey w mason
Are you a Packard Bell Computer and Internet Expert? Answer questions, earn points and help others
