Question about Miele 24 in. G665 Built-in Dishwasher
Miele g665 dishwasher
My dishwasher goes through the cycle over and over again, it does not switch off. It had been running for a week when we discovered the problem with it
  • 21 Answers
Wow... one week is a long time. Those dishes has to be very clean or at least worn out by now.
From what you are discribing, it appears you have a timer control module that is malfunctioning. You might try that first. If that still doesn't do the trick, check the fill valve sensor/seliniod
Posted on Jun 10, 2008
Does the Miele G665 dishwashers have a heat element as no heat is coming from my dishwasher
If it like other Mieles, it has an element to heat water if required to reach cleaning temperature, but does not have a drying element. Even then, it should give off some heat in the drying cycle and be hot after finishing.
Nov 17, 2014 | Miele 24 in. G665 Built-in Dishwasher
Wanting new inside racks for the Miele G665 current ones are starting to rust
That is not that hard to fix and you can easily buy the parts yourself online...
Here is a tip that will help you with the online buying...
How to Buy
Appliance Parts Online
heatman101
Dec 21, 2010 | Miele 24 in. G665 Built-in Dishwasher
My miele G665 SC is not draining all the waste water away at the end of the cycle, i've taken the filter part out of the bottom and it's all clear and even run a cycle without it, is there another filter...
Check for any kinked hoses and check the drain spigot under the sink where the drain hose connects into the u bend. Usually this is where food gets trapped due to the spigot not being drilled out large enough. This then causes a blockage. Also check the non return valve under the filter and make sure the drain pump can turn freely.
Hope this helps.
Jul 02, 2010 | Miele 24 in. G665 Built-in Dishwasher
Where do I put salt into a G665 model
Salt and rinse aid are low if the indicator light is on.
Salt is placed in a compartment in the bottom of the inside of the dishwasher. It has a round approx 10cm diameter screw cap.
Rinse aid goes in under a flap in the inside of the door near the powder dispenser
Dec 02, 2009 | Miele 24 in. G665 Built-in Dishwasher
Miele g665 sc
i think its daft as well but nearly all dishwashers have this feature. you have a leak somewhere to cause this
Jun 26, 2008 | Miele 24 in. G665 Built-in Dishwasher
Miele g665
Peter,
where is the water coming out at? Are you using the proper detergent? if the machine is too full of water and a fill float valve is stuck open, water sometimes overflows.
Check to make sure the fill valve is working, then check to make sure pump is operating. (you will know when you turn the machine onto the rinse cycle.)
Mar 17, 2008 | Miele 24 in. G665 Built-in Dishwasher
Miele no heat
The last I checked, the G660 will not work for the G665. If you look under Applicances in your phone book, you will see several appliance repair places. Most of them can get you universal kits to replace this. I however caution however that you should really let a tech look at your dishwasher. Something tells me that boards got shorted out by mistake without realizing it.
Mar 10, 2008 | Miele 24 in. G665 Built-in Dishwasher
Dishwasher element?
dispenser is not linked that will be the solinoid valve on the dispenser. the heater could be open circuit or on the side of the wash motor is a pressure switch that is common for blocking so it will not put the heater on.
Feb 12, 2008 | Dishwashers
Miele 24 in. G665 Built-in Dishwasher Logo
342 people viewed this question
Top Miele Dishwashers Experts
mpservices
Mike
Are you a Miele Dishwasher Expert? Answer questions, earn points and help others
