Vulcan column electric heater
My aunt has given me her movable 15 column heater. It has a fan and a 24 hour clock but I need a manual to operate it. Where can I get one from?
The name plate says the manufacturing no. is 7377LG
  • bigbrownhand Jun 13, 2008
    I have also tried unsuccessfully to find an instruction manual for a very similar heater.
SOURCE: need fan for vulcan gas wall heater serial no. 1003129019
found a supplier using the Google search engine. Thanks any way.
Posted on May 15, 2009
  • 3 Answers
SOURCE: Vulcan Oil Heater not operating correctly
If the red light comes on when starting, this means that there is continuity in both exhaust heating and igniting elements and the heater cutout is also working.
The most common problems with this heater is coke & soot build up in the bottom oiltray and clogging the bottom air intake holes, to remove this the heater box has to be dismantled.
Posted on Jun 18, 2009
  • 53 Answers
SOURCE: Vulcan Quasar 40 wall furnace - electronic display problem
Have a gasfitter bypass the clock. The clock is the source of the problem. You will then have a manually operated heater.
Posted on Oct 08, 2009
SOURCE: fan does not work
http://docs.google.com/viewer?a=v&q=cache:YD3okKRc2I0J:www.americanwaterheater.com/support/manuals/Pol-March2000.pdf+Vulcan+gas+glo+gas+heater+service+manual&hl=en&gl=nz&pid=bl&srcid=ADGEESjhk6UzCP25N_K8wnNncjckZO62rh_N_ax-LUHRffL6o9xuy6FxjRN6PY5jPKX6y2L8XQ_fG4YFdcpCA6Jw59ltNACBymKTTjiY2BaUBKYm8LsGLb5QGAJYJaX2Ld_8ZdTuotnp&sig=AHIEtbQiJznkaXb6qf85geWYr_N5b0uSIw
Above is a service and installation manual, it has all troubleshooting info inside.
Basically, if your fan doesn't go, it can be: A: The Fan, itself, Check. B: The controller for the fan (Thermostat) Check.C: The Power isn't getting to the main boards. Check.
Posted on Jun 08, 2010
  • 74 Answers
SOURCE: Looking for Heat Pump Manual (need P/N), no
4 ton carrier product
Posted on Jul 03, 2010
The hot water recirc pump in my new house was equippped w/ this timer. There was no user manual, but it was set by the installer to run the pump during awake hours and shut it off during sleep hours. ...
1) Open link below so we are talking about same type of household system
http://waterheatertimer.org/Water-heater-recirculation-system.html
2) 15 minute interval is misleading.
Pins located on timer dial divide 24-hour day into 15 minute intervals.
You set timer pins and decide which 15 minute intervals you want ON-or-OFF. Do this by moving pins inward or outward with your thumb or ink pen. To check settings, manually rotate timer dial clockwise and listen for pump turning on-off..
Set timer pins for 4 consecutive 15 minute intervals, then timer runs for 1 hour.
After pins are set, then manually rotate dial to set current time.
Dial rotates as time passes, and pins click a lever that turns pump on-off.
3) 5-year Life span. Like all things plumbing, if you have hard water or sand-n-dirt in water lines, then pipes clog. And pumps clog.
Once motor begins to slow down, it overheats and burns out.
Water softener can keep sediment out of lines, but shortens life of water heater.
http://waterheatertimer.org/Clean-sediment-out-of-water-heater.html
4) Real question: do you need a circulation pump? Do you need hot water at your faucet? Can you schedule hot water use, or does recirculation pump have to run several hours per day?
Recirculation pumps causes water heater to run more, the pump consumes 25+ watts depending on pump, and water savings claims of 15,000 gallons per year are fabrication.
Realistic water savings is 700-2000 gallons per year, assuming several folks in the home use water sporadically across a full day, and each time water is used people are waiting for hot water. It also assumes that you never want cold water at the tap and that refrigeration ice maker line prefers hot water to cold.
5) Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, fixya expert speaks with you over phone while you work on pump/timer or any do-it-yourself project.
We are always less expensive than a service call.
Dec 18, 2010 | Taco 265-1 / 563-2 Combination Analog 24...
HOW DO YOU TURN THE LITTLE GREY BOX OFF COMPLETELY? HOW DO YOU BY-PASS THE GREY BOX?
The timer is a 24 hour type, designed specifically for use with electric water heaters.The simplest way to keep the water heater on 24 hours a day is to remove the "trippers". The "trippers" are the movable black and silver metal clips that are held on the edge of the time dial with thumbscrews. Unscrew the thumbscrew on all the trippers and remove the tripper for the time dial.
Just below the time dial, you'll find the manual switch lever. On some models, it pokes through an opening on in the door / front cover - on others it can only be operated by opening the door. Move this manual switch lever to your choice of on or off position. The switch will not longer be operated automatically - and will stay in the position you have chosen until you or someone else changes it.
Please rate this reply - good luck!
Dec 07, 2010 | Intermatic WH40 - Water Heater Time Switch...
I need instructions for how to set a 24 hour mechanical General Purpose timer. My model #15075
GE 15075 manual:
http://www.jascoproducts.com/support/manual-downloads/applications/DocumentLibraryManager/upload/Plug-In-15075-Manual-eng.pdf
GE 15075 is a plug-in timer.
Before you plug it in, set the timer so you're not bent over at the receptacle.
Rotate dial until current time lines up with triangle located on inner dial.
There are movable pins located around the dial.
These pins cause the timer to turn on and off.
Pins out = timer on
Pins in = timer off
plug in your lamp and the timer turns on and off.
After power outage, set current time again.
Oct 25, 2010 | Electric Eyeware Ge 24 Hour Electric...
Fan does not work
Jun 08, 2010 | Heating & Cooling
I want a programmable timer that can, eg, switch on a single phase electric motor for 10 seconds every hour. It may be 9 secs or 11 secs.
You need a programmable interval timer.
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#ET70
Intermatic and Tork make digital timers with interval settings that can be set for specific short-duration with 1 minute minimum.
(Or set to pulse bell ringing with 1-127 seconds.
10 minutes is 600 seconds)
For example ET70115 single-channel timer.
The timer would be set for 24-hour operation, and then programmed for Pulse, and then set timer with 24 programs, with 1 program for each hour.
Mechanical cycle timers from Intermatic:
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#cycle
1) Talento 1 hour cycle timer/ each tripper represents 1.25 minutes
2) Model C8835/ each tripper represents 15 seconds.
To operate these timers certain hours of the day, add another timer in-line.
The in-line timer could be digital, but remember digital timers are not protected from power surge and tend to have more problems, and do not have replaceable clock motors and trippers.
Apr 08, 2010 | General Electric GE 24-Hour Timer, 2-Pin...
Oct 05, 2009 | Heating & Cooling
Vulcan quasar40 keeps turning off we think it has a timer stuck on please help
Probably a bad clock, they **** out from all the heat up there. Have a gasfitter or electrician bypass it. (2 wire plug behind fan lever) - unplug it, cut off from the loom going up to clock, crimp the ends together on the plug you have just cut off, plug it back in. Your heater is now a manual with no dodgy clock.
Jul 16, 2009 | Vulcan Heating & Cooling
Instructions for Sunbeam clock model # 882-495
Move the second button from the left to set, enter the time in 24 hour format via the HH and MM buttons, then move the button to start. The far left switch, on/auto.off is for the chime. Set to on for 24 hour alarms, set to auto for no chime from 11pm til 6am, set to off, to turn it off.
Mar 29, 2008 | Office Equipment & Supplies
Heating & Cooling Logo
119 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
