Question about Aiwa AV-DV75
Speakers stopped working.
Well I use my av-dv75 for surround sound on my Xbox 360. Up to this point I had full surround and bass. I turned it all on the other day and noticed that only the left front speaker had any considerable volume output. The sub has also stopped working. I can get the sub to make noise by touching the connector wire so i know it's not blown. The rear speakers also make static but no actual game sound. The front left and right work perfectly still. What would the problem be? This all started without anything on the unit being changed... just happened. And I don't ever turn it up past 15.
  • aaron irving May 11, 2010
    Connecting the wire to make a noise is a bad thing, but is it full volume when you do this (I assume you mean connecting directly).
    Does the unit have multiple inputs? (aux in or l/r stereo in?) If so it may be worth trying them if you have the cables... that way you can see if it passing sound through properly to the speakers...
    At a guess it sounds like there is a problem with the amplifier, loose wire/burnt out internal connector etc. since one speaker works and you claim the others don't work.
  • 979 Answers
More than likely you have blown outputs, as the sound you hear when you touch the leads to the terminals is the DC offset of the power supply being routed through your speakers...accordianman
Posted on Jun 10, 2008
New Yamaha AV Receiver and Tannoy Speakers muffled weak bass only
Maybe some wire is faulty... Try to disconnect everything and connect each speaker one by one, first trying only radio tuner and then trying to connect the TV and other devices. Using that you can isolate the fault into the specific component/wire.
May 26, 2010 | Yamaha Rx-v365 A/V Home Theater Receiver
How do I get my Panasonic sa-pt670 to play all the speaker. watching tv and with ps3
Does you Tv set have optical out? If so might I suggest running HDMI into your television set from the PS3, then run an optical audio line out from the tv into the optical line in on your HTIB
Feb 24, 2010 | Panasonic Home Theater System System
Only front and center speakers work, not surround.
If by white noise do you mean the test tone generated by the receiver? If so, this is actually pink noise and it is internally generated by the receiver. I would make sure either in the menu or on the remote that you haven't accidently turned off the surrounds and double check the wiring to the surrounds. Good luck.
Feb 15, 2010 | Aiwa AV-DV75
Not getting true surround sound
The only way to get Dolby 5.1 audio out of the Xbox will be via fiber optic cable from the Xbox to a Dolby Digital amplifier - which will output a decoded 5.1 signal to a 6 channel amplifier and 5 speakers and one sub-woofer. I doubt the Logitech speaker system has a Dolby 5.1 decoder built in with the amplifier for under $100, but I can't say for sure. If the Logitech has a an optical (or TOSLink) input, connect it to the Xbox and follow the instructions below.
To configure your audio settings, follow these steps:
  1. Start the Xbox 360 console without a disc in the disc tray.
  2. In the System section of the Xbox Dashboard, select Console Settings.
  3. In the Console Settings area, select Audio.
  4. In the Audio Settings area, configure settings for analog output or digital output:
    • Analog output settings:
      • Dolby Pro Logic II: Select this setting for stereo systems or Dolby Pro Logic II-compatible systems.
      • Mono: Select this setting for systems that do not support stereo output. Note If you have connected to Xbox LIVE and downloaded any AutoUpdates, the Mono option will not be available.
    • Digital output settings:
      • Digital Stereo: Select this setting to use digital stereo output.
      • Dolby Digital 5.1: Select this setting to use Dolby Digital output.
      • Enable WMA Pro: Select this setting to enable WMA Pro pass-through if your receiver supports the WMA Pro format.
Note You must use one of the following cables to support digital output:
  • Xbox 360 Component HD AV Cable
  • VGA HD AV cable
  • S-video AV cable
  • Advanced SCART AV cable
  • Japanese HDAV D-connector AV cable
Additional info:
http://www.dummies.com/how-to/content/hooking-up-xbox-360-sound.html
Sep 28, 2009 | Audio Players & Recorders
Xbox 360 and bose surround sound no video
If your TV is HD, you should definitely be connecting the component video cables (green, blue and red) from the 360 to the TV (the 321 will not do video pass-thru from component cables). -Make sure you have a picture at this point. (TV switched to whichever input you connect the 360 to)
You can get an RCA extension cable for the audio portion (red and white) to connect to the 321 for audio. You could also connect an optical audio cable to the 321. An optical cable must be assigned from the system menu to work..
Let me know if this helps.
May 31, 2009 | Microsoft Xbox 360 Pro System Console
Will not turn on
Page 23...
There may be a short circuit in the speaker terminals.
Disconnect all speakers and try it. If it works troubleshoot each speaker one at a time. Shorted wires are indicated.
© Disconnect the AC cord, then correct the speaker connections.
May 04, 2009 | Aiwa AV-DV75
HTS-GS1 Surround Sound System cannot be utilized for tv.
Check Your TV audio setup,many TV makers out there would like you to turn off the tv speakers in order to use the external speakers.
Joe
Feb 03, 2008 | Pioneer HTS-GS1 Theater System
Broken receiver
I bought my AV-DV75 from Best Buy about 10 years ago and it still works. However it did stop working a while back. I don't know why. I alsmost threw it away. But I unplugged it for a couple of days, then plugged it back up and it came back on. It is still working. Maybe that will work for you.
PS
my center speaker quit working recently. If you decide to sell your AIWA speakers will you please email me?
Aug 14, 2007 | Aiwa AV-DV75
Vizio L42HDTV10A sound problems
In my case, turning the surround sound OFF is what fixed the problem. The bass contibutes most to the perception of the location of a sound. If surround is ON without surround speakers connected, the internal TV speakers can only take the place of what would be the front speakers in a surround system. So turn surround OFF and set your bass preference wherever you want it. That worked for me.
May 29, 2007 | Vizio L37 Television
AV-DV75 center speaker works surround speakers do not
If all others had been fine before this problem arose, and you are sure that you haven't changed anything in your amplifier's channel selection menus, the problem might be deeper to solve! Try these out; 1-If the amplifier has a test menu to check out all channels plugged in, activate it. You must be able to get sound, which is like rustle, from each speaker. 2- Check your plugs, cables etc. be sure that there isn't any short circuit 3- Grab your amplifier's remote control and find the "channel selection menu" that allows you to increase and decrease volume levels for each speaker independently.
Apr 15, 2007 | Aiwa AV-DV75
Aiwa AV-DV75 Logo
223 people viewed this question
Top Aiwa Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you an Aiwa Audio Player and Recorder Expert? Answer questions, earn points and help others
