Question about Brother DCP 115C All-In-One InkJet Printer
Brother dcp 115c error code 50 unable to clean
Hi there... recently i got this error message and i cant get it out
brother dcp 115c error code 50 "unable to clean"
tried purge reset but it doesnt work.. please help thnxx
5 Suggested Answers
Mix-it-up
  • 832 Answers
SOURCE: Brother DCP-115C unable to clean
you need a new waist ink absorber box from a service partner which can be found at brother homepage of you country.
After replacing the box you have to do a reset.
search error 46 or unable to clean here in the forum. it has been written many times.
Posted on May 05, 2008
SOURCE: Unable to clean
unable to clean troubleshooting maintenance user guide
Posted on Jun 23, 2008
SOURCE: dcp115c brother unable to clean
BROTHER INTERNATIONAL
ATTENTION: CoDEC0012 "JOHN" email oblacks_pit@yahoo.com
UNABLE TO CLEAN?
1. TO ENTER MAINTENANCE MODE: PRESS MENU, MONO START, 4X ON ARROW UP (WITHIN 2 MINS)
2. USING ARROW UP BUTTON LOOK FOR THE FOLLOWING
a> 8 then press SET
b> 0 then press SET
3. USING MONO START, JUST PRESS IT UNTILL THE WORD "PURGE XXXXX" COMES PUT.
4. USSING ARROW UP BUTTON LOOK FOR THE FOLLOWING: "FLUSH"
A> 2 THEN PRESS SET
B> 7 THEN PRESS SET
C> 8 THEN PRESS SET
D> 3 THEN PRESS SET
THIS IS TO RESET THE PURGE COUNTER
5. USSING ARROW UP BUTTON LOOK FOR THE FOLLOWING
A> 0 THEN PRESS SET
B> 1 THEN PRESS SET (TO RESET UNIT)
C> 9 THEN PRESS SET
D> 9 THEN PRESS SET (TO EXIT MAINTENANCE MODE)
THAT'S ALL FOLKS JOHN
Posted on Aug 15, 2008
SOURCE: Unable to clean error on Brother DCP115C
MY bROTHER DCP-115C Always says Unable to clean see trouble shooting and routine maintenance at Users Guide, i want only a guide to reset my printer so that could be able to clean by itself
thanks,
Mr, Elpidio Concepcion
Posted on Jan 02, 2009
SOURCE: Printer unable to clean
the printer has a counter for the supposed amount of ink the absorber pad can absorb.
i have reset the counter using the following and now it works. In theory you need to get a replacement pad but i haven't been able to find one yet. My printer is now working fine
following is the solution to reset the counter for the old fault
> Brother DCP110c Reset Counter
> 1. unplug at side of unit, switch on while pressin menu2. Enter 8 press
> set enter 0 press set
> " by using the up arrow key & SET keys."
> 3. press the mono start key several times untill the purge count appears
> on the LCD.
> 4. enter 2 7 8 & 3 by using the up arrow key & set keys to reset the
> purge count to zero (like in 1)
> 5. press the stop/exit key to return to the initial stage of the
> maintanance mode.
> 6. enter 9 twice by using the up arrow & set key’s to exit from
> maintenance mode
Michael
Posted on Mar 09, 2009
DCP 185C ERROR 50
Sir/Madam
I Suggest You To Watch Clear Error 46 Unable to Clean on Brother Printers Without Number Pad To Fix Your Brother Printer Issue,In Case You Still Having Problem Then Follow Us For On :
Brother Printer Support
Jan 21, 2014 | Brother DCP 115C All-In-One InkJet Printer
Unable to clean
If the message is 'Unable to Clean: Error 46' I would recommend checking out this video.
If however you are receiving 'Error 4F' this is a mechanical issue and I would advise getting in touch with a printer technician or Brother themselves.
Aug 07, 2013 | Brother DCP 115C All-In-One InkJet Printer
Printer won't print
..if not mistaken, the error message is Unable to clean, which indicate you will need to replace the waste ink pad and reset the waste ink counter.. you will need to send to the local service centre to get it done..
May 24, 2010 | Brother DCP 115C All-In-One InkJet Printer
My printer brother DCP115C ''UNABLE TO CLEAN error code 50''
Machine error 50 is a error in Purge unit.You can't fix it by yourself and your printer need service.In most case the cost of repair is more than cost of new printer.
Nov 03, 2009 | Brother DCP 115C All-In-One InkJet Printer
Unable to clean message
printer brother dcp 115c .unable to clean. what must i do
Jan 19, 2009 | Brother MFC-5840CN All-In-One InkJet...
Unable to clean problem
turn the rpitner of then check there is not any paper jam.
also refix crtridge after clean it.
Jan 03, 2009 | Brother DCP 115C All-In-One InkJet Printer
Unable to clean message in brother dcp-115c aio
I saw on this site codes for another MFC to clear memory and reset the cleaning unit count code to zero. It worked on two of my brother mfc 820cw units. The third mfc 5840cn had unable to print error message 46- nothing at Brother. they want you to take everything to a repair shop.they don't help at all. Then the error went to 4F when I tried toclear the memory.As Iunderstand that message- it means I have to replace the printer head. Have no clue where or what it is. But I can read a manual as well as anyone and follow directions to fix it! Can't be worse than it is now! Good luck
Jul 22, 2008 | Brother DCP 115C All-In-One InkJet Printer
May 05, 2008 | Brother DCP 115C All-In-One InkJet Printer
Brother DCP 115C displays unable to init message tried the trouble shooter in manual still says it what should i do
press menu then start b/k-copy (mono) then fortimes arrow up button quickly after another. machine will switch to mainteance mode. press start bk copy.
What two digit error code does the machine display?
Post here again.
Mar 09, 2008 | Brother DCP 115C All-In-One InkJet Printer
Brother DCP 115C All-In-One InkJet Printer Logo
555 people viewed this question
CheckitRight
CheckitRight
Soulvisitor
Soulvisitor
Ron Dufek
Ron Dufek
