Question about Saeco Magic De Luxe Espresso Machine
Bean and Grounds Bin Lights Lit
May Saeco deluxe was going along swimmingly, and then all of a sudden it didnt want to produce stream or hot water anymore. I used it a few more times just to make coffee and it worked fine, but since then the Bean and Grounds Bin Lights have come and and wont turn off. I have switched off at the mains, and when I turn it back on they come on instantly. I have opened it up to have a look, and its just a mess of wires! Any help would be appreciated.
  • Howser99 Jun 10, 2008
    Where do I find the boiler fuse?
    Thanks,
    Will have a look this evening and report back.
    Thanks
    Genius:
  • 1,665 Answers
Posted on Jun 10, 2008
  • 78 Answers
Sounds like your boiler has gone, check for a fuse, replace, Otherwise you might have to take to Tech to replace parts :(
Posted on Jun 09, 2008
  • Rhys Parker Jun 10, 2008
    Hi, this might be of help. It goes through a fwe trouble shooting options for you. Let me know how you go :)
    http://pdf.archiexpo.com/pdf/saeco/vienn...
Seams that my saeco incanto deluxe has a problem with the brew group possibly the boiler the grounds come out dry. If I do a rinse cycle the water still flows help? How do I clean the boiler?
Hi
Dosage lever or knob (small knob in the bean hopper) is to the max positive and the brew unit can not compress the coffee, so the machine dumps it into the dredge drawer to prevent breaking the machine. Reduce the amount by 1 click back from the full positive, and that should take care of the problem. Another thing that can cause this is the grind is too coarse or the grinder has come apart. The grinds should look like coarse sugar.
PS. It will usually work if the brew unit is clean, but when it is used once it will go back to dumping dry grounds.
Aug 19, 2011 | Saeco Incanto Classic Espresso Machine
Saeco Vienna Deluxe -- Coffee weak weak weak
When the coffee is weak, that is often because the water is not at adequate temperature.
Check if the coffee is in right quantity and pressed in the right way. If it is than it means that the water was not hot enough.
Check water temperature, if water is completely cold, the element mus be replaced, if water is hot, but not enough, then replace thermostate activating the pump.
Oct 13, 2008 | Saeco Vienna De Luxe Espresso Machine
Saeco veinna deluxe coffee machine. i took the
If the light is still then means that either the water tank is empty or the bean hopper is empty.
If the light is blinking then the Dump box, brew group, or drip tray not properly positioned or service door not closed.
So you can make a very good visual check one by one if they are in right position.
Good luck.
Apr 02, 2010 | Saeco Vienna De Luxe Espresso Machine
The bean grinder doesnt grind, only water comes out
If it is working before, probably the coffee chute is clogged up. You can remove the bean hopper and see where the coffee drop into the brew unit.If the chute is still attached just clean the blockage, if it is broken you will have to remove the grinder and replaced it.
Jan 17, 2010 | Saeco Odea-Giro Espresso Machine
My Saeco Incanto deluxe started dripping hot water from the steam spout outlet when coffee is brewing. It produces steam and hot water without any problems. It doesn't leak when it's in a normal state...
Either the grind is too fine and there is so much pressure that the pins in the steam valve are not working properly. First try to adjust grind a little coarser, it that does not work, then the pins in the steam valve need to be replaced.
Nov 20, 2009 | Saeco INCANTO DELUXE Espresso Machine
Saeco Magic Deluxe resets itself before completing brew cycle
Hi Try reprogramming the machine. Push and hold the button for the coffee you want, but hold it all the way through the process. Don't release the button until you get the amount of coffee you want for that button, then release the button. That should get you the same amount next time. You can do this for each coffee button. If that doesn't fix it, then you might need a new flow meter.
Jun 12, 2009 | Saeco Magic De Luxe Espresso Machine
Saeco Magic Deluxe - Coffee Cold,Lights not working
The thermoblock (boiler) element is burnt out and must be replaced.
Feb 10, 2009 | Saeco Magic De Luxe Espresso Machine
I can't get the coffee grounds plastic dispenser back into the
remove the used grounds container and place a folded piece of paper where the grounds container touches the micro switch ( that is in a slot in the left side where the container enters approx 8cm inside) and then restart the machine and the grounds container will now be able to enter, remember to remove the folded paper before inserting the container
Nov 18, 2008 | Saeco Vienna Deluxe
Brand New Incanto, Grinder Doesn't Work
If you look at the adjustment knob in the bean hopper, make sure it is in the middle i think it will be "8".
Make sure you not get any damp into the grinder.
Try to make 2-3 cup of coffee.
Let me know if i can help you more
Best regards
/Mirran
Nov 08, 2008 | Starbucks Saeco Italia Digital Barista...
Saeco Easy hums instead of packs grounds
I think the brewing gears has to be replaced.
Aug 26, 2008 | Saeco Easy Espresso Machine
Saeco Magic De Luxe Espresso Machine Logo
42 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
just-ice
83bj60
Level 1 Expert
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
