Question about Gaggia Classic Espresso Machine
Coffee spurting everywhere!
I have a fairly new Gaggia, however for some reason the majority of times that I try and make a espresso, the flow of water is very eratic and the coffee spurts everywhere instead of coming out in a nice flow. I am using espresso coffee and not over filling it with coffee. What am I doing wrong? Does anyone else have this problem? You're help would be most appreciated.
Many thanks
  • karenradd Sep 05, 2008
    I am having the same problem. We have had the gaggia for 2 years now. The first espresso comes out perfect, but when I do more than one cup, the coffee spurts out everywhere. I recenty descaled the machine thinking that was the problem but it still does it. I dont know what to do.... Hope someone can help.
Unlike the other person offering a solution I have experienced this problem like you when making the first cup. I found that sending a blank shot of water through first does the trick before putting the coffee grounds on. Hope this helps.
Posted on Nov 01, 2008
Coffee only comes out in spurts (not the usual free flow) and tastes watery
How to resolve Saeco Odea Go Issues - YouTube
? 6:29
https://www.youtube.com/watch?v=lRl_D5lBm5s
Apr 27, 2011 - Uploaded by slashtiger1
This video will explain how to resolve the 'dripping coffee' issue and similar ... I am a ******** espresso ****** and my machinehas been down for several weeks. ... and doing the steam outprocess, it still was not pumping out coffee. ... only to brew with the smallest quantity of water, you could try cutting ...Missing: spurts ‎usual ‎free ‎tastes
Jan 12, 2016 | Saeco Magic Comfort 103467 Espresso...
Why does my baby gaggia have good steam but no flow for espresso?
turn on as if to make a coffee and then the stemer. Some time it's to do with drawing the water from the tank. Otherwise I'd descale it, that will defo fix it.
Nov 18, 2014 | Gaggia Baby Espresso Machine
Gaggia Titanium. . coffee not hot even though
Remove the filter holder and brew some water into a small plastic cup and check temp, it could be the thermostat for the coffee temp is damaged.
Apr 29, 2010 | Gaggia Coffe Deluxe Coffee Maker, Espresso...
Hi, Our Gaggia machine will not disburse water through coffee dispenser. Sounds like its operating normally till water flow should happen. Then the motor slows down to nothing. Have descaled to no effect....
Try this press the button for ground coffee then when it lights up press the coffee brew button, if water flows normally then the grind on the grinder needs to be adjusted coarser, if no water then the screen on the brew unit is blocked.
Sep 07, 2009 | Gaggia Syncrony Logic 74884 Espresso...
Brand new Gaggia Syncrony Compact will not pump water. Red light no. 27 flashes, and machine makes sounds as if trying to pump.
Open the hot water valve, if it flows for a second and stops, then pusi in on the knob if that works, call up support and ask for a new stainless steel valve for your machine.
Aug 01, 2009 | Gaggia Syncrony Compact Coffee...
The coffee has started spitting out, spraying
The group seal gasket needs to be replaced.
Jul 15, 2009 | Gaggia Baby Espresso Machine
Gaggia Classic Spurts Everywhere
Hi there if your coffee is spurting out the sides it is because the group gasket is worn or has gone hard through use and now needs replacing. Basically when you twist your coffee handle on it doesn't always form a perfect seal and so the pressure causes the coffee to spurt out the sides. If you are not sure where to get parts get in touch with David at coffeeservice@live.com and he will be able to sort you out.
All the best
LaPavoniBoy
Jul 13, 2009 | Gaggia Classic Espresso Machine
Gaggia Classic Espresso Machine Logo
438 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
