Question about Hoover F5912-900 Upright Steam Vacuum
Auto matic shut off
When the recovery tank is full the yellow float disc is supposed to rise to the top of the tank lid... it does not. other than that, the machine is working fine...
Ever since I hooked up the hose and attachment to clean some upholstery, now that I am back to cleaning carpet.. I have this issue with the yellow disc
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 310 Answers
Http://geeksquad.fixya.com/ThreadView.aspx?prdid=40664&thid=657597
Automatic shut off
Posted by clean mama on Jun 09, 2008
When the recovery tank is full the yellow float disc is supposed to raise to the top of the tank lid... it does not. Other than that, the machine is working fine...
Ever since I hooked up the hose and attachment to clean some upholstery, now that I am back to cleaning carpet... I have this issue with the yellow disc
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Hoover F5912-900 Upright Steam Vacuum. The yellow disc is supposed to act like a float when the water raises the yellow disks will let you know the water recovery tank is full, and not actually turn off the system. You may want to check with your local vacuum dealer to see if the yellow disk is broken or find out why it is not working correctly. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Posted on Jun 11, 2008
I just purchased a floormate. I can't seem to get it to spray cleaning solution.
Turn the cleaner off and then on again to determine whether the cause of no suction resulted from the activation of the automatic shut-off. There are two reasons a tank will automatically shut off. The first is if the recovery tank is full. Located on the lower front panel of the unit, the recovery tank can be easily emptied and replaced into position. To remove from unit, press down on the release button and pull the tank downward and forward. Lift up on the tank latch lid and take out the tank lid. Empty the tank. Also check the tank lid screen for debris and remove any found. To replace the lid, align the tab that corresponds to the front hole of the tank. Snap the latches on the back of the tank. Insert the bottom of the tank back into the cleaner and push in and up until it locks in place.
Turn the unit on again and check the suctioning action. The second reason automatic shut-off could take place is if the handle was raised to an upright position while the motor was running. Should this occur, simply turn the unit off, wait a moment for the shut-off to reset, and turn it on again to continue cleaning.
  • 2 Make sure the filter and filter lid are properly positioned in the recovery tank lid. The cause of the problem could be that the filter or the filter lid were missing or were not in the proper position.
  • 3 Check that both recovery tank and/or solution tanks are locked in place and are positioned properly. The recovery tank is located on the lower front panel of the Floormate, and the solution tank is located in the front top panel of the unit. To remove from unit, press down on the release button and pull the tank downward and forward. Lift up on the tank latch lid and take out the tank lid. Empty the tank. Also check the tank lid screen for debris and remove any found. To replace the lid, align the tab that corresponds to the front hole of the tank. Snap the latches on the back of the tank. Insert the bottom of the tank back into the cleaner and push in and up until it locks in place.
  • 4 Observe whether filter is dirty. If the filter is dirty, clean the filter by turning the cleaner off and disconnecting it from the electrical unit. Take out the recovery tank and lid. Remove loose debris from the filter by wiping clean with a brush or tapping the filter over a garbage can. After this is completed, the filter may be rinsed clean for additional cleaning and then air dried before returning the filter to the unit.
  • 5 Check that the nozzle is in the proper position and locked. Locate the nozzle underneath the suctioning base of the unit. Make sure the latches are out and line up the middle section of the nozzle with the opening of the cleaner. Hold the nozzle in place while simultaneously sliding the latches inward to lock in
  • Mar 07, 2011 | Hoover Floormate H3000 Upright Wet/Dry...
    My hoover steamvac wont **** up dirty water float
    Check your filter screen insde the upper tank. if your model has a wrap around filter try to pull it down about 1/2" to maximize air flow.
    Apr 15, 2010 | Hoover F7431-900 SteamVac Vacuum
    Automatic shutoff red ball in recovery tank rises to top when recovery tank is about 20% full.Thus we are only able to use the steam cleaner for about 2 minutes before having to empty the recovery tank....
    Your cleaner should have a foam sock around the float cage in the recovery tank. Remove the foam sock and rinse it out with clean water. If these are very dirty, they may cause the airflow to be disrupted, causing the float to raise prematurely.
    Oct 29, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
    Hoover steamvac not picking up water
    you don't have the recovery tank lid on correctly.
    Jul 19, 2009 | Hoover F5866-900 SteamVac Deluxe Wet/Dry...
    My hoover steam vac is not releasing the cleaner
    http://www.hoover.com/pdfs/manuals/F5914900.pdf this is the manual for your model
    Godbless
    Problem: Clean solution won’t
    dispense
    Problem: Brushes/brush indicator
    won’t rotate during floor cleaning
    Possible cause
    Possible solution
    • Not firmly plugged in
    • Plug unit in firmly
    • No voltage In wall plug
    • Check fuse or breaker
    • Blown fuse/tripped breaker
    • Replace fuse/reset breaker
    Possible cause
    Possible solution
    • Recovery tank full/automatic
    shut off engaged
    • Remove and empty recovery tank
    • Blockage In tool on end of hose
    • Remove tool and clear blockage
    • Recovery tank lid not on
    correctly
    • Make sure lid is on securely
    • Recovery tank front panel not
    replaced after stair or upholstery
    cleaning
    • Replace recovery tank front panel
    (page 14)
    Possible cause
    Possible solution
    • Solution tank not firmly in place
    • Make sure tank is securely locked in
    position
    • Solution tank empty
    • Refill tank according to instructions for
    surface being cleaned
    correctly
    • Make sure lid is firmly in place
    • Pump needs to be “primed” (when
    using tool)
    • See “Before using tool” section, p. 13
    Jun 15, 2009 | Hoover SteamVac F5914-900 SpinScrub...
    Loss of suction
    Make sure the recovery tank lid is on correctly. Also make sure the float on the receovery tank lid is down.
    May 24, 2009 | Hoover F7431-900 SteamVac Vacuum
    Auto-matic suction shut-off didn't resume once tank was emptied
    look on the bottom of the tank and there should be a fitting on there take it off and clean..there should be some hind of float inside the tank.turn it right side up and tap on the tank the float might be stuck
    Apr 07, 2009 | Kenmore 25512/ 25513 Progressive Canister...
    Recovery tank not filling
    The tank has an automatic shutoff float (red) that will stop the suction if the water level gets too high. this can also happen if the tank is not level or clean as the float can bounce around and jam at the top. I've actually had this one happen). I would make sure the float is down during the cleaning and see if the suction comes back. if not, please provide more details and we'll get 'er fixed!
    Feb 04, 2009 | Hoover F5866-900 SteamVac Deluxe Wet/Dry...
    Recovery Tank red float disk rising to top when no water is in recovery tank
    When you put the filter back on, you must have put it all of the way to the top. There needs to be about a 1/4 in. gap from the top of the filter to the top of the lid.
    Mar 18, 2008 | Hoover SteamVac F5914-900 SpinScrub...
    Hoover will not suck carpet shampooer
    the most common problem is the recovery tank. Most often the square piece of plastic that attaches to the side of the recovery tank is not snapped in-- it comes loose when you dump the tank. Take off the lid, pull the clear plastic sqare (about 4 inches by 5 ) that is attached on the OUTSIDE of the recovery tank and snap it back into place.
    2nd make sure the rubber rim is clean and free of debris
    3rd attach the lid with the hinges on the back first then snap down the lid
    4th make sure the yellow float is down on the bottom (this is inside the filter inside the recovery tank)
    5th put the recovery tank in the machine FRONT FIRST (where the two round peices of plastic are)then back, snap the sides back to lock the tank in place.
    If these things dont work....make sure your not clogged with debris on the top (but I am sure you would have seen this before doing all the rest!)
    May 04, 2007 | Hoover SteamVac F5914-900 SpinScrub...
    Hoover F5912-900 Upright Steam Vacuum Logo
    100 people viewed this question
    Top Hoover Vacuums Experts
    Gerry Harvey
    Gerry Harvey
    Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
