Wireless network connection 2. not connected.
Hello
my wireless network connection is saying there are no availble networks in range. but there are. Im not sure why its called connection 2..
where is the first one?
The switch at the back of my laptop is switched to ON..
can you suggest i check something else?
cheers.
  • plumberry Jun 09, 2008
    the firewall settings look normal... i dont have a router, its just a switch on the back of my laptop. im trying to connect to my university wireless
  • dtcm08 Aug 12, 2008
    I am getting out of range when trying to connect to my secured wireless router. I can connect to a neighbors wireless without any trouble, but can't connect to my own secured one? please help. I was able to connect to my secured wireless before I moved about 2 months ago.
    Problem Solver:
  • 9 Answers
Check your firewall settings. Also what brand of wireless router/switch are you using?
Posted on Jun 09, 2008
Hello my wireless laptop does not connect to my wireless network it says "Windows is unable to connect to the selected network. The network may no longer be in range. Please refresh the list of...
make sure that the signal strength in that area is good...
normally this happens when the network range is very low... probably u will have to try connecting having the router kept more nearer..
Mar 17, 2011 | Computers & Internet
I have an older dell desktop with a pentium4 and runs on XP. It has a Dell truemobile 1180 USB Adapter that connects to wireless networks. Everything worked fine at the last house with 2-4 out of...
In the Network Connections window, right click on the USB adapter and select Properties. Select the "Wireless Networks" tab. In the Preferred networks area, select the name of your wireless network so that it is highlighted. Then press the Remove button. Click OK.
Windows should now inform you that it has located an available network. Try connecting into it now.
Aug 24, 2010 | Dell Computers & Internet
Can't connect to friends network
They are four reasons why your wireless would say "acquiring network address" and later changing into "Limited or no connectivity"
1) Invalid WEP/WPA Encryption key.
2) Mac Filtering, Your friends might have disallowed the mac address of your laptop or he it might be filtered.
3) Short IP range mentioned on the router (May your friend has specified a short ip address range for DHCP)
4) Invalid configuration for wireless on Windows Vista
To this problem, do this on your laptop
1) Start >> Control Panel >> Network and Sharing Center (Classic View) >> Manage Wireless network>> remove the wireless network by clicking and then right clicking on top of it and remove.
2) Now try to connect again to the wireless network, reenter the key and that should do it.
If this doesn't work, then probably you have to ask your friend about the 2 and 3 possible cause listed above.
And Thanks.
Mar 10, 2010 | Westell Wirespeed VersaLink...
I have a D-Link DWA 520+ wireless adapter card in my pc, and having trouble connecting to my BT Home Hub 2.0. when I search for wireless in range it shows my hub along with many others in the area ( I live...
Be sure you are using windows software or the d-link utility soft. Don't use both.
Also if you have security enable like a wep password protection.
Make sure you are using the right password.
i will be glad to help you let me know about it..
thks
uttam
Jan 13, 2010 | Cornerstone DLink AirPlus DWL-520+ 802.11b...
My computer was wireless then one day when i try to connect it says no wireless networks in range. my wireless button is on but i still can't connect how can i fix this problem
maybe theres a problem in the wireless network that you are connecting to, that why your computer detected no wireless connection in range if there no wireless network to connect to you will get this message there nothing wrong with the adapter or you are far away for the computer to pick up the signal its either way
Nov 20, 2009 | Computers & Internet
Is there a manual shut off switch to disable the wireless search mode on an Acer laptop?
I assume you want to stop vista from automatically connecting to wireless networks other than yours.......try this:
Open Network and Sharing Center, click Manage wireless networks, click on your "home" network & make sure that Connect automatically when this network is in range is checked. Now do the same for any other connection that is listed but uncheck the Connect automatically when this network is in range.
Go to Start > Network > Network and Sharing Center
click Manage network connections under 'Tasks'
Right-click Wireless Network Connection
Select Properties.
In the Wireless Network Connection Properties dialogue box, click the
Wireless Networks tab.
Select other wireless network like "Y5ZONE", "PCCW" and click Properties
Click Connection tab
Uncheck the box "Connect when this network is in range"
Hope this helps.....
Jul 21, 2009 | Computers & Internet
Nokia 770 internet settings....
hello there! thanks for using Fixya.com!
Setting up a wireless connection is easy. The Connection Manager searches for any wireless networks within range and displays their signal strength, and whether the networks are encrypted. The 770 supports both WEP and WPA encryption, so provided you know the network key, it can connect to any wireless network.
When it's out of range of a network, the Nokia can connect to your mobile phone using Bluetooth, letting you browse the Internet over GPRS.
Once you've exchanged Bluetooth passkeys with your phone, you have to manually enter your network provider's GPRS settings into the 770. This has the potential to be a real pain in the neck, but fortunately the 770's mobile settings wizard already knows GPRS settings for the major mobile networks, which takes much of the pain out of the process.
Loading Web pages over GPRS is far slower than over a wireless network, but it's quick enough to look up the occasional bit of information and certainly fast enough to send and receive e-mails.
Hope this will help you!
Feb 04, 2009 | Nokia 770 Handheld
My acer 4315 vista cant connect to the availble wireless network
Run in safe mode with "network" option - then open internet explorer - try opening a web site from favorites. If successful browse internet for a patch or update
Feb 04, 2009 | Acer Aspire 4315 Notebook
No wireless connection
sound like it. try disabling the radio and reenabling it .try reinstalling or hard resetting the router.
was there any storm in the area lately. maybe its blown.
Dec 20, 2008 | WiFlyer - Portable, shareable WiFi base...
Printer networking
connect the printer to the router install the printer driver choose network printer it will then go off and find the printer and assign an IP address and make it availble for printing
Feb 18, 2008 | Computers & Internet
Computers & Internet Logo
1,254 people viewed this question
David Payne
David Payne
