Question about Zenith D52WLCD 52" Rear Projection HDTV-Ready Television
Orange projection lamp on. Picture is a bluish green, no true white.
Bluish green hughs. Adjusting tint/color no help. Can't get a white white. Orange lamp on and picture getting worse. Single mom and husband with stroke in wheelchair. Need to fix myself economically. Thanks so much Terry
  • mcctee May 11, 2010
    Is there a Zenith trouble shooting flow chart to get an idea of what causes various problems ? Anyone please reply, I've been search the web with no luck. Many Thanks
    I don't have the ability to pay money online (identity theft) to get some diagnostic help. Is it just the philips consumable lamp to replace, or maybe chips, burnt resistors, blown fuse or the whole light engine. Where can I find the answer Please reply. Thanks
If you are in warranty contact Lg electronics since they own Zenith. I was having similar difficulties and they are sending me a replacement tv even though I am out of warranty by 3 years.
Posted on Jun 23, 2008
The color on my tv is turning green. It's not totally green but it's becoming green. No matter how I adjust the colors it remains the same with too much green. You can't see the true colors...
It is very common for the color of the lamp to change as it nears the end of it's life. Depending on the bulb itself you may see yellow, green, or blue shifts (I have even seen red/orange). This is due to the diminishing output of the bulb and while you can make some adjustment you will eventually hit the point of failure. The bulb could in fact last several more weeks or even months depending on your use and environment. It is probably a good time to start searching for a replacement now so you can replace it as soon as it dies or just replace it now if the color is too bad to be worthwhile.
May 23, 2011 | Philips Magnavox 9P6034C 60" Rear...
Too much red, orange and pink in the picture, little or no green, some blue. No amount of adjusting color, tint or brightness helps it just gets worse. Even turning color off completely leaves it brown and...
mike, mine is doing the same thing - by chance do you use
dish network? I think it's them because both of my t.v.'s are doing the same thing and at the same time...
Sep 05, 2010 | Dynex 20" Digital TV
Orange tint on the picture all channels
You might fix this problem by adjusting your color, contrast and brightness settings.
Apr 07, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
THEN SEEN HAS A LITE GREEN TINT TO THE BOTTOM PART
Sounds like your main control board or the color wheel.
Dec 29, 2009 | Panasonic PT-50LC14 50" Rear Projection...
I can adjust the colors, it looks to orange.
The CRT coolant needs replacement. You can get the phillips CRT coolant at www.tvrepairworld.com the kit contains the coolant and the CD with instructions
Nov 26, 2009 | Philips Magnavox 9P6034C 60" Rear...
Blue tint on rear projection tv
If this is a crts model , then one of the crts had blown, if it is a lamp rear projection, then it is a fault on the video circuit.
Mar 14, 2009 | Pioneer SD-P50A5-K 50" Rear Projection...
On my Philis 51PW9303/17F projection TV, the colors are weak. Adjusting the color and tint have no effect on the color intensity or hue. I was given this set and it was worked on. THANKS Mike
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Dec 30, 2008 | Philips 51PW9303 51" Rear Projection...
Picture is orange tint in television
Check the cable connections in the back, if it's a High Definition TV from your cable box, you will have three cables, red, green and blue. If one of the cables is in the wrong spot or is not connected (loose) you will lose color in the picture.
Dec 17, 2008 | Hitachi UltraVision CineForm 55VG825 55"...
Color is weird.
Component Video Jack was loose.
Dec 14, 2008 | Sony KP-48V45 48" Rear Projection...
Zenith D52WLCD 52" Rear Projection HDTV-Ready Television Logo
123 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
