Question about Lexmark All-in-One Printer with PictBridge
Lexmark x3550 printer
My new printer will scan copy but it wont print from pc
  • Norman Marks Sep 24, 2008
    my printer does everything but scan
  • 48 Answers
The issue which u r facing is" Communication issue"
Make sure u have installed the lexmark printer software...or else download it from the lexmark website( the s\w for ur operation system( Xp or vista(32bit or 64bit))...
If s\w is installed...
Check the USB cable..try different port...
Clear all the docs in the printer folder...
Remove the power adaptor and replung..restart computer..
When u unplug and replung the usb cable doesn ur computer give a pop up "found New hardware" ?
U can also try...
Uninstalling the s\w....disconnect the USB cable..reinstal the s\w and connect the cable when it prompts to...
Posted on Jun 18, 2008
My printer prints black or color. I have a new black cartridge #23, but my color cartridge is empty. Every time I try to print a page from my jump drive the color cartridge empty warning comes up and it won't print it in black. I've been trying for 3 hours to print this mess for class. My computer is dell with Windows. I don't have microsoft, I have wordpad. What do I need to do? This project is due tomorrow!
Posted on Sep 24, 2008
I got it hook up to my laptop and i wanted to print out 1 or 2 pictures. And it wont print.
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer. Reboot your pc. Unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer. Then try to print again once the computer fully recognizes the USB connection.
If that doesn't help, try the steps below:
1. Disconnect the printer from your computer.
2. Rebrick (pull out power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds).
2. On your computer, go to Control Panel > Printers and Faxes.
3. Delete the Lexmark print object.
4. Reboot your pc.
5. When your pc turns on, reconnect the printer.
6. Wait until your pc fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, then try to print/scan again.
Aug 19, 2011 | Lexmark X3550 All-In-One Printer
My Lexmark x3550 only prints one page of multiple pages. I've checked my print setting and it all looks correct. I'm also having problems scanning and copying. It's a fairly new machine as I hardly use...
Try to reset your printer factory default settings. Press Settings button -> Defaults -> Set Defaults -> Use Factory -> press Check. You will be asked to setup your printer settings like you're setting it up the first time - set the time and date, etc. When done, unplug and replug the printer into the power outlet to refresh the printer.
Apr 13, 2011 | Lexmark X3550 All-In-One Printer
Lexmark 6675 won't download application list
Look back there and try to inspect the "pick wheel" that pulls the paper from the automatic document feeder. Is it turning? trying to pull paper? if so, it could need cleaned. Make sure there isnt any little peices of ripped paper blocking any openings or sensors.
Sep 22, 2009 | Lexmark X3550 ALL-IN-ONE InkJet Printer
I just bought a new lexmark copier, scanner, fax,
This should give you a good explanation of what ocr is.,6959,204816596_1268319518_0_en,00.html
Jul 07, 2009 | Lexmark X3550 All-In-One Printer
Lexmark x3550 will not scan 'Downloading Application List" and "
Had the same problem. Installed the most recent drivers. OK now. Good luck. - Kakou
Feb 05, 2009 | Lexmark X3550 All-In-One Printer
Lexmark 3550
Uninstall entire lexmark program and reinstall from lexmark web-site.
Jan 22, 2009 | Lexmark X3550 All-In-One Printer
Lexmark x3550
Changing print cartridges Changing print cartridges Removing a used print cartridge
  1. Make sure the printer is on.
  2. Lift the scanner unit.
    The print cartridge carrier moves and stops at the loading position, unless the printer is busy.
  3. Press down on the cartridge carrier lever to raise the cartridge carrier lid.
  4. Remove the used print cartridge.
Note: If you are removing both cartridges, repeat step 3 and step 4 for the second cartridge. Installing print cartridges
  1. If you are installing new print cartridges, remove the sticker and tape from the back and bottom of the cartridges.
    cartridge_tape_remove_one_2.jpg Warning: Do not touch the gold contact area on the back or the metal nozzles on the bottom of the cartridges.
  2. Press down on the cartridge carrier levers to raise the cartridge carrier lids.
  3. Insert the black cartridge or the photo cartridge in the left carrier. Insert the color cartridge in the right carrier.
  4. Close the lids.
  5. Close the scanner unit, making sure to keep your hands out from underneath the scanner unit.
    scanner_unit_close_2.jpg The control panel display will prompt you to load paper and press button_select_0.jpg to print an alignment page.
    Note: The scanner unit must be closed to start a new scan, print, copy, or fax job.
Jul 22, 2008 | Lexmark X3550 All-In-One Printer
Lexmark X1185 won't scan.
I believe you have to push the scan button in order for it to scan and save. The copy buttons will only print either a black copy or a color copy.
Sep 12, 2007 | Lexmark JetPrinter X1185 All-In-One InkJet
Lexmark All-in-One Printer with PictBridge Logo
98 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
