Question about Jenn-Air JCB2280HES Side by Side Refrigerator
Thanks for helping out on Gabby5's side by side
Thanks for the look see on Gabby's Side by Side. I was pretty sure that is what it was in your estimation but I only know refrigeration units from being a mechanic most of my life until I had no choice but to change course thanks to Rheumatoid Arthritis. I was working in a boat yard when I joined the Navy and anything that didn't float was handled by the mechanics shop. Learned a lot there. I was wrapping my head around propane refrigeration units when I found something more sensible to do than work on RVs.
Thanks again.
Worldvet
    Genius:
  • 1,073 Answers
You are welcome
Posted on Jun 09, 2008
My Kenmore Mod 596.516 is running, but all of a sudden stopped being cold. The vertical fan in the freezer compartment is running. The fan in the back is running. I am pretty sure the compressor is...
The fan is running means compressor is running, But the compressor just keeps on running.The problem is weak compressor.------- Click this link below and follow the troubleshooting:--
http://technoanswers.blogspot.com/2011/07/kenmore-side-by-side-refrigerator.html ---------- this will help.Thanks.Helpmech.
Jul 08, 2011 | Kenmore Side by Side Refrigerator
I want to recharge the ac but cant find the input fitting?
Go to autozone and ask for a can of: R134-A. Make sure to get a can with hoses and a gauge. Don't let the pressure build up to much. make sure you hook it into the right connection. Its the metal hoses right by the radiator. -------------- Its usally a pretty easy job, especially if you get one of the kits with the gauge in it. They can be found at autozone, etc. The connectors are pretty smartly done. This thing will only connect to a low pressure port on your car. You are looking for a blue or gray cap on one of the A/C lines with an "L" on it. ------------------ Locate the Low Pressure Side service port. It is usually on the driver's side of beside the engine block. Remove the black cap marked L. Look at the connector type to determine if your car uses R134 refrigerant. The R134 compatible systems have a quick connect valve on the Low Pressure Side. ----------------- Hope this helps.Thanks.
May 11, 2011 | 1997 Honda Accord
The water is hot and then in a few seconds it comes out cold. We moved into this house 3/2007 and had no problems like this until now. what can we do? Thanks Gabby
You do not say what size tank you have so I will assume it has two elements. You can test the elements for continuity by removing both access panels and using a multimeter to check them. (BE SURE POWER TO UNIT IS OFF) I suspect that one of your elements has failed.
Nov 29, 2010 | Water Heaters
Our refridgerator is not getting cold! it is staying at 60 degrees.. we tried cleaning out the back fan, and also tried resetting the temperature gauge but it keeps going back to 60 degrees and it...
Please double check your model number because that number is not listed. I am pretty sure it has a dual evaporator one for freezer and other for the fresh food compartment. Check behind the cover of the fan inside the fresh food compartment to see if the coils are icing over. Send me the correct model number will help me decide if it is something different. I will even send you a Service manual with the correctmodel number, Thanks, Sea Breeze
Feb 12, 2010 | Samsung RS267LBBP 26.1 Cu. Ft. Side by...
I have a 328i with air con, where do I find the heater resistor situated, is it on drivers side or passenger side? Thanks
I am pretty sure it is on the passenger side, as that is where the heater/ air conditioning air box is.
Dec 01, 2009 | 1997 BMW 328
1985 3.8 ford thunderbird have replaced plugs cap module on dist checked timing new fuel pump and still wont crank,any ideas?thanks
If you can't hear hum from fuel pump when key turned to on only, not start, check behind side cover panel in trunk on drivers side, for inertia switch. Has a button on top or side, push it in to reset. Pretty sure drivers side, but if not there, check other side (passenger) in trunk area, behind side panel.
Aug 08, 2009 | 1985 Ford Thunderbird
Side by Side fridge stops cooling and the works again !
soiunds like the defrost timer is bad, Unless your highly mechanically inclined I would go ahead and call out the service repair company and tell them to be sure to bring allong a timer fo your unit. Hope this helps and good luck.
Jan 09, 2009 | Whirlpool ED2FHGX Side by Side...
Jenn-Air JCB2280HES Side by Side Refrigerator Logo
63 people viewed this question
Top Jenn-Air Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
