Question about Sony KP-51HW40 51" Rear Projection Television
KP-51HW40 blinks 6 times
From what I got it is related to LOW B OCP/OVP (Overcurrent/over voltage)...+5V Line Overloaded or shorted on the A or B board. can I repace these boards or fix them do you know a price,part or what they look like so I can get a refrance.
Thankyou, Aaron
  • BryGuy2001 Jun 21, 2008
    Light On front of TV flashes 6 times.
    How can I repair it Bryan Thanks
  • fatalnutz Jun 22, 2008
    I have the same problem as well. Thought it was the bulbs but I opened up the back and they are good.
    Some help here? Anyone?
  • Sony Master
  • 8,617 Answers
You can go to the following link and leave your model number and the number of blinks your set is blinking and they will respond quickly they have any part you would need for your sony, and they respond quickly.
http://servicemanuals.vstore.ca/
Posted on Jun 22, 2008
Tv does not come on and the power light flashes 6 times
I'm not entirely sure what that means, but this website says: 6 times, Diagnosis: LOW B OCP/OVP (Overcurrent/over voltage). Possible causes: +5 line is overloaded. (A, B boards), +5 line is shorted. (A, B boards). Symptoms of the problem: No picture.
It sounds like it will need warranty work. You can always try unplugging it and waiting 5 minutes and plugging it back in.
Please don't rank me low, I'm not an expert here, just trying to be as helpful as I can.
Mar 08, 2011 | Sony KP-51HW40 51" Rear Projection...
Will only turn on for about 3 second with no picture and then turns off. Standby light blinks 6 times
For the KV30HS420, 6 blinks, pause, 6 blinks, etc. means "LOW +B OCP/OVP (overcurrent/overvoltage)" and the probable cause locations listed are as follows:
1. +5 line is overloaded (A, B, M boards)
2. +5 line is shorted (A, B, M boards)
3. IC504 is faulty (A board)
hope this helps John
Jan 11, 2011 | Sony FD Trinitron WEGA KV-30HS420 30" TV
Cutting off
Try the following to see what exactly the 6 light blinks mean.
To see the diagnostic screen, Press the following buttons:
Display, Channel, 5, Vol Minus, ( Not plus ) then Power.
This brings up a screen with a list of the problems and number of times they have occurred. This will tell you what is happening and see if it's worth fixing.
Also, have you tried unplugging the TV for a few minutes? if it's some kind of computer error, unplugging it will allow the error to clear and possibly allow the TV to work again. Just an idea to try in case the error code doesn't tell you.what is wrong.
May 22, 2010 | Sony KP-57WS500 57" Rear Projection...
Sony KP-51WS500 turns red ,shuts off, led blinks 8 times
Here are the fault codes for your tv and what components are affected:
  • 0 times, Diagnosis: Power does not turn on. Possible causes include: Power cord is not plugged in, Fuse is burned out (F6001) (G board). Symptoms of the problem: Power does not come on, No power is supplied to the unit, AC power supply is faulty.
  • 2 times, Diagnosis: B overcurrent (OCP). Possible causes: H. OUT (Q8024) is shorted. (D board), +B PWM (Q8035, 8038) is shorted. (D board) Symptoms of the problem: Power does not come on, Load on power line is shorted.
  • 3 times, Diagnosis: +B overvoltage (OVP). Possible causes: IC501 is faulty (G board), IC5002 is faulty (G board). Symptoms of the problem: TV has entered standby mode.
  • 4 times, Diagnosis: Vertical deflection stopped. Possible causes: +- 15V is not supplied. (D board), IC8003 is faulty. (A board) Symptoms of the problem: TV has entered standby state after horizontal raster, Vertical deflection pulse is stopped, Power line is shorted or power supply is stopped.
  • 5 times, Diagnosis: White balance failure (Not balanced) Possible causes: Video out (IC7101, 7201, 7301) is faulty (CR, CG, CB board), CRT drive (IC309) is faulty (A board), G2 is improperly adjusted. Symptoms of the problem: No raster is generated, CRT cathode current detection reference pulse output is small.
  • 6 times, Diagnosis: LOW B OCP/OVP (Overcurrent/over voltage). Possible causes: +5 line is overloaded. (A, B boards), +5 line is shorted. (A, B boards). Symptoms of the problem: No picture.
  • 7 times, Diagnosis: Horizontal deflection stopped. Possible cause: Q8035, 8038 is shorted. (D board)
  • 8 times, Diagnosis: High voltage error. Possible cause: T8005 is faulty. (D board)
  • 9 times, Diagnosis: Audio error. Possible causes: +- 19V line is shorted. (A, B boards), IC708 is faulty. (A board), PS701 or PS702 is opened. (A board). Symptoms of the problem: No sound
I have seen the tube divider pack cause this too, Take the front speaker grill off remove the 4 screws and the panel comes off. There is a pack with 2 red 2 green and 2 blue adjustments, Try turning the BOTTOM red one down 1/32 a turn and see if the symptoms change
Apr 03, 2010 | Sony KP-51WS500 51" Rear Projection...
Sony kp65wv700 tv blinks 7 times - Horizontal deflection issue is what manual is telling me. My question is what transistor/chips I need to replace and if anyone has done that to fix this problem...
Feb 26, 2010 | Sony KP-51WS500 51" Rear Projection...
replace the two mcz3001 ic's on the d or dz board, this is a common problem they have used this circuit for years, so the exact board number may be diffrent, but it will be located on the board with the flyback.
Sep 01, 2009 | Sony KP-53XBR300 53" Rear Projection...
No picture.red light blinks 6 times
I would need the model number in order to help you with the error code . Please respond to this same post. thanks
Jun 28, 2008 | Televison & Video
Kdf-55wf655 power led light blinking six times
Most Sony 6-blink codes for projection TVs follow this pattern:
Jun 13, 2008 | Sony Grand WEGA KDF-55WF655 36" Rear...
Tv just shut off and red light is flashing
Mar 07, 2008 | Sony Grand WEGA KDF-55WF655 36" Rear...
6 flashes
also check out this sony recall
http://www.hdtvoice.com/voice/showthread.php?t=31861
Jan 05, 2008 | Sony Grand WEGA KDF-42WE655 42" Rear...
Sony KP-51HW40 51" Rear Projection Television Logo
89 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
