Question about GPS
Raymarine Compatability Hi, Would you know if the Airmar-RayM E26008 & 9 (Shorty's) will work w/ the ST 60 Displays?
Yes. The shorty transducers that normally ship with the ST40 series instruments should be interchangeable with longer stem ST60 series ducers.
Posted on Jul 14, 2008
WHAT TRANSDUCE GOES WITH THE DS600X COLOR ..WHERE CAN I BUY ?
Hi
Airmar makes almost all of the transducers for Raymarine. From the Airmar FAQ section, your unit is listed. See the link below. Pretty much any marine chandler or Raymarine dealer should be able to order it for you.
Hope this helps
-Steve
Airmar FAQ What Airmar transducers are compatible with the Raymarine...
Feb 26, 2015 | Raymarine Ds600x Digital Fishfinder With...
St 6000 manual
The ST 6000 manual can be viewed/downloaded from the link below.
Hope this helps.
-Steve
Raymarine Retired Autopilot Manuals
Jul 01, 2013 | Raymarine Boating
Raymarine st 1000 displays 1000 (flashing and beeps) and the actuating rod will not move
Have the same problem, sick and tired of it. It is 18 month old, had repaired once 2 months ago by raymarine, some soldered joints came undone on the board, not working again! Used it 4 times since new out of probably 20 attempts. Every time I try to use some new problem raises. Possibly just my luck. Just ordered a new Navico st 32 heard it is better unit.
Jun 10, 2012 | Raymarine St1000 Plus Tiller Pilot
Remote on my Raymarine ST 4000 stopped working - how do i troubleshoot problem?
If the remote is the wire type ,check continuity of the wires in the cable ,specially at the bending places where the cable comes out of the connector and the control unit.,Cut away internally broken part of the cable,and solder again respecting the coulours ,or change the whole cable respecting the connections.
Jun 06, 2010 | Raymarine St 4000 Wheel Drive E12093
Raymarine "DSM connection lost"
Murray,
Has the DSM and the E120 software been upgraded to the latest software: 4.12 for the DSM and 5.52 for the E120?
Try this first. You can download the software off Raymarine.com and burn each to a separate compact flash card.
I have seen many problems like you are experiencing solved with this simple change.
If this doesn't solve the problem, the DSM will have to go back to Raymarine for repair.
Apr 19, 2010 | Raymarine Dsm30 Digital Sounder Module
I have a c80 the temp shows 114 the water temp is 70.Any help?
Maybe you have a ST 60 tridata display please look after the temperature if the temp is to high change the speedsonde for ST 60 this sonde is measuring the seatemperatur an over the seatalkconection C 80 becoms the information about temp
Jul 03, 2009 | Raymarine C80 GPS Receiver
Hi I have an Apelco 530 fishfinder/gps and need a through hull transducer kit. Apelco were taken out by Raymarine who advised me to contact Airmar who made the transducers. So far no answer but their...
Embedded
I was looking to see if I could find a replacement for the display and was able to confirm that the transducer is a single beam 120khz unit so I doubt that you've find a replacement for it ..as is .
The Airmar C-49 is the proper number for the connection line but like me I think your going to have to think about a whole new unit and or system . Been there already.
Best of luck.
Sir Isaac
Jun 22, 2009 | Raymarine Boating
i had face with similar trouble
I went to RayMarine Web site and got an ecopy of the manual. Inside there is a 3D Blow up of the inner workings of the Auto Pilot. There are a couple of shear pins inside on the clutch lever. It shows you how to disassemble the auto and replace the shear pins. Total cost was $0.20. It works GREAT now. No more problems. I was also was able to give the inner working a good cleaning and lube. I have a soft copy of the manual if you need it
Jul 24, 2008 | Raymarine St 4000 Wheel Drive E12093
GPS Logo
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
