Question about Toshiba Satellite A105 Notebook
Toshiba lapop keyboard
I have a toshiba laptop, my keyboard was working fine till yesterday, it now only lets me tye vowels, i done a full system reformatte but it is still the same, any ideas please.
  • lilly123 Jun 10, 2008
    i did manage to get the keyboard to work again the way it should, but it only lasted for a day and went back the same way again, i dont think it is the actual keyboard, may be i should ring toshiba.
  • 1,183 Answers
HI,
Try the following steps given on the Toshiba website
http://askiris.toshiba.com/ToshibaSupportSite/search.do?cmd=displayKC&docType=ex&bbid=bb54&url=&dialogID=41366755&stateId=1%200%2041362844
I suspect the problem is with the keyboard as you have already formatted the system. In case you have a USB desktop keyboard , try connecting it to the laptop and check.
You can loacte the toshiba repair centre from the following link
Thanks
Mandeep
Posted on Jun 09, 2008
My Keyboard and Touchpad are not working
Try installing your Windows again.A bit hard to tell, cause it can be allot of things that went wrong..
Oct 23, 2011 | Computers & Internet
I have a logik wireless keyboard and mouse and the keyboard will not connect to the reciever, it worked yesterday but doesnt now, what can i do
1. Gr8. remove the wireless connector from what ever system you are using
2. ensure the dry cells or battery are in good shape and well inserted behind the keyboard
3. re-plug the wireless cable back in either the usb slot or mouse port which ever that applies in your case.
4. wait till the device is recognised and ensure the lights on the wireless connector is litted
5. now press the button behind your keyboard to connect with your receiver
6. vois la there you go all set and done.
7. in short go through the procedure for installing your wireless keyboard
hope this works for you
Aug 10, 2011 | Computers & Internet
Hi... i have a Toshiba satellite pro model pc laptop. Unfortunatly by accedent my PC wetted as my kid urinated. my system is not power up till now.. i tried many times but it is dead.. not at all power...
When this happens, you should fully disassemble the notebook & thoroughly inspect its inside. Look for any traces of liquid on the circuit boards & on other components. On circuit boards, liquid damage appears in the form of whitish traces. These needs to be wiped off. This can be done using a tooth brush moistened with few drops of hand sanitizer liquid.
Check all internal connectors & make sure that no liquid seeped into them. Dry them if needed.
When you are done, re-assemble back the notebook.
If the liquid fell on the keyboard & you found out that the keyboard is no longer working, then you will have to replace the keyboard.
Mar 27, 2011 | Toshiba Satellite L500 Series Notebook
I have replaced my Toshiba 205 laptop's keyboard a few months ago and all was fine. Now some keys don't work while others work if you push for a few seconds. I reconnected the ribbon last night and...
There is not so much that could be done to repair a keyboard. Disassemble the laptop, check the ribbon cable connecting the keyboard to the motherboard. If the ribbon cable is loose, tighten it. If it is tight, replace the keyboard with a new one
Sep 20, 2010 | Toshiba Satellite A205-S4607 Notebook PC
Dell Inspiron keyboard issues
Try a USB keyboard. laptop keyboard faults are common, the only real fix is replacement, it isn't too hard, just fiddly.
Mar 02, 2010 | Dell Inspiron 1525 Laptop Jet Black
Lenovo lapop 8922
You need to replace the keyboard.
I purchase keyboards from:
http://www.sparepartswarehouse.com/Laptop,Keyboards.aspx
This manual is for the 89xx series, should give you enough info to replace the keyboard yourself:
ftp://ftp.software.ibm.com/pc/pccbbs/mobiles_pdf/42x3549_05.pdf
copy and paste the link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Nov 08, 2008 | Computers & Internet
Compaq presario v2405us can't boot up
I did not get if the keys are working. If not, check the keyboard ribbon. It might be out of place.
Else, it might be the hdd.
Oct 18, 2008 | HP Compaq Presario V2405us PC Notebook
Replace monitor?
how to take the monitor off the laptop and replace
Aug 19, 2008 | Toshiba Satellite A105 Notebook
Keyboard not working.
Press the FN+NumLock key - you have probably switch on NumLock???
If not, then the keyboard cable has probably come loose.
Look for some way to remove the keyboard. Sometimes a screw from underneath, sometimes two or three small catches at front of keyboard (small gaps in metal plate in front of space bar). Sometimes top plastic bar above keyboard slides sideways.
Keyboard cable uses goes into a header socket - to refit:
Switch off and remove battery and power first!
1. Prise up each end of the socket with a blunt knife - the outer part of the socket should move up a few mm
2. Push keyboard cable down fully
3. Push down each end of the header socket so it is flush with the lower part of the socket.
4. Test keyboard
Aug 16, 2008 | Compaq Presario Notebook
Toshiba Satellite A105 Notebook Logo
144 people viewed this question
Top Toshiba Computers & Internet Experts
Brian Sullivan
Brian Sullivan
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
