MW051 -U My F & P washing maching is doing the same having problems the water both hot and cold. both at start up only go in short birsts and after 15 secunds, the bowl turns only 3-4 centermeters or so it shuts down and beeps I saw the advise from Doctr who said the hall sensor is corroded. unplug the power lead, tilt the machine back & look underneath. unscrew that large white knob & the motor will basically remove. then you will see a small electronic card attached to the windings of the motor (hall rotor sensor). unclip it & unplug. it will be corroded. replace it & reassemble as it came apart. HOW DO YOU UN SCREW THE WHITE KNOB! - mine is very very tight, is it reverse thread? regards also on the Gold Coast Queensland Australia- where do I go for spare parts :) regards Craig :) Not filling properly with Hot or Cold
  • Patrick69 Jun 09, 2008
    Thanks
    Do you know anywhere in Australia to fix this
    President:
  • 1,294 Answers
Close your faucet valve on wall & unscrew your hoses to check screens on hoses & machine. Clean out well. See that the water pressure is good. Refit, check for leaks. If this is not the problem change your inlet valve, it is easily done.
Sites for spares:
RepairClinic.com (which is good)
espares.co.uk
AppliancePartsPros.com
Pl rate if helped..................
Posted on Jun 09, 2008
  • prem mathew Jun 09, 2008
    google> fisher paykel spares australia, or your city, whatever.
2 Suggested Answers
SOURCE: MW051 -U
hi craig Doctr here. there should be a hex head shape on the white knob. get you spanner or socket onto it. give it a crack. will have to check tomorrow about the thread. i can provide you with a new hall sensor. phil
Posted on Jul 10, 2007
Even when the machine is set to cold it pulls in hot
not sure on that one most machines are cold fill now,,think it is to do with the valves been closed , even though the machine is in a cold wash it registers a fault when any of the valves are closed
Nov 10, 2013 | Whirlpool Duet GHW9150P Front Load Washer
Cold/cold cyle wash water not cold
try to do cold cycle first without doing warm cycle first
Apr 12, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Soap residue fisher & paykel top loader
Agitator can be removed easy,Take out the fabric dispenser cup,
Reach down inside the agitator & undo the wing nut, left to undo.
Take out agitator & clean & the bottom of the bowl,
For a more better clean fill machine with hot to high water level & leave soak over night,Do heavy duty wash in the morning to remove scrud.
Feb 10, 2013 | Fisher and Paykel Washing Machines
Smart drive washing machine not filling properly?
sounds like you do have a solenoid problem undo hoses from back of machine check the filters are not blocked also check at the tap end to see if filter are cleare if all filters are clear most likely you will have to replace you inlet valves assuming there is no problem with pcb board.
Mar 29, 2009 | Fisher and Paykel GWL11 Top Load Washer
Washing maching won't rinse in cold water
hi is this hot and cold water piped machine? ie two connections on rear of machine for hot and cold pipes ? if so are your pipes connected properly on machine and the water supplies? if cold supply is connected to hot supply then wash inlet allows water in washer then washes in cold? but when rinse is due? the elec valve that has hot water pipe connected?? is failing to open allowing water flow of hot on rinse so advise recheck pipes for flow of water from both? when disconnected from machine if flow ok then possible valve blocked/faulty hope you can understand above? if you can give more info on your machine it would help to offer a remedy?
Nov 01, 2008 | Hotpoint Washing Machines
AEG WASHING MACHINE
fit hoses at random. put on a rinse cycle. if cold water comes in then hoses are correct. if hot water comes in, then reverse hoses
Aug 22, 2008 | AEG Lavamat 72640 Front Load Washer
Fisher and Paykel MW051 washing machine.
If you can stop it with your thumb there is NO DOUBT it is water pressure.. Pull the hose and check the tap direct, that will tell you if you have a plumbing problem of just a funky hose...
Good luck
May 08, 2008 | Fisher Paykel EcoSmart GWL15
Fisher and Paykel mw051-u
you need to replace both inlet valves.
Feb 03, 2008 | Fisher and Paykel GWL11 Top Load Washer
MW051 -U
Jun 18, 2007 | Fisher and Paykel GWL11 Top Load Washer
Gw709
yeh pete .your hall sensor is corroded. unplug the power lead, tilt the machine back & look underneath. unscrew that large white knob & the motor will basically remove. then you will see a small electronic card attached to the windings of the motor (hall rotor sensor). unclip it & unplug. it will be corroded. replace it & reassemble as it came apart. br phil . aussie
May 06, 2007 | Fisher and Paykel GWL11 Top Load Washer
Washing Machines Logo
69 people viewed this question
Top Washing Machines Experts
