Question about Hotpoint RA524 Electric Kitchen Range
RA 517302W I need to clean under my stove burners. How do I remove the stove top?
  • 3Lisa Jun 09, 2008
    I have a Hotpoint RA517302W small stove/range appliance. This is an older appliances, however it is in excellent working condition. But, I need to clean under the burners of the stove top.
    How do I remove the stove top to reach under the four burners? Thanks.
  • 868 Answers
I need the correct model number.If this is the model number than its not in the system (due to age)
Posted on Jun 09, 2008
How do I adjust the flame on a MGC5430 gas cooktop? Flames are too yellow and cause black soot on bottom of pans. Doesn't seem to have an air shutter adjustment
Is this unit set up for natural gas or propane? New stoves usually come with ORIFACES for both gasses. They would install between the on/off knob and the burner tube under the stove top. They may be tapped to the under burner area of your stove. If you lift your top stove cover you may find them. If you don't find them, you may need to purchase the correct applications for your stove. GOOD LUCK FRIEND.
Nov 28, 2014 | Maytag MGC5430 Gas Cooktop
How do i open top of stove to clean under the burners
You can but I wouldn't recommend it . It is relatively sealed clean, but I will tell you anyway... there are three screws each under each burner that hold the top down to the burners so if you have 5 burners there are 15 screws to take off...put them in a cup so you don;t loose them after removing the screws ..go to the front lip of the top ..take a butter knife and put between the seam near the corners ..you will feel a type of spring resistance push in to release spring pressure and pull up on the corner of left and right of the top and remove top.. You will be surprised how clean it really is.
Oct 05, 2014 | LG LRG30855ST Stainless Steel Gas Range
How do i open the top of stove to clean its lrg30855st
Turn off the gas. Lift off the burner cap and the burner head from all remove the torx screws under each of the five burner heads then lift off he top. The picture on these two pages of the manual show where the screws are and what the stove looks like with the top off:
http://www.manualslib.com/manual/705911/Lg-Lrg30855st.html?page=21#manual
http://www.manualslib.com/manual/705911/Lg-Lrg30855st.html?page=22#manual
Does model XFG371LVQ Whirlpool stove have air adjustment for top burners?
Remove the front panel to find where the gas injectors enter the burner tubes you will see they are cut away and have a screw holding an outer ring which is adjustable, open them up more to get more air in .
May 16, 2014 | Whirlpool Stove / Oven / Range Cooktop -...
I need to replace the trays underneath the burners on my stove. How do I remove the burner?
The stove top elements lift up a bit a the oposite side of the element leads leading out of the burner. The burners then pull out of the electrical socket. OUT SIDEWAYS NOT UP.
Jan 16, 2010 | GE Hotpoint 30" Self-Cleaning Freestanding...
Stove top burners won't light.
Susan, there is no pilot flame on the Spectra models of ranges. However, the possibility that the electronic ignitors have gotten soaked and are shorting out is quite likely.
You should disconnect the power to the oven and remove the burner grates, burner caps, and the burner assembly cores to expose the ignitor posts. Check to see if there is any remaining water there and clean off and dry the ignitors and burners completely, as they might have something on them causing them to short out against the stove top, rather than spark properly, as they should.
Once you've cleaned and replaced the stove top parts, restore power and try to light each burner, one at a time. If none of them spark or light, then you need to check to make sure you haven't tripped a breaker for the stove or a GFCI outlet that the outlet that the stove might be plugged into, somewhere in the Kitchen.
Hope you find this Very Helpful and best regards!
Sep 10, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Gas stove /electric starter won't click to start cleaned stove
Try cleaning the starter with rubbing alcohol and toothbrush. There might be soap or boiled over residue on the starter. If that doesn't work, try using fine 150 grit sandpaper and gentle clean the starter with it. This problems drove me nuts too. Good luck!
Mar 01, 2009 | Stoves Kitchen Ranges
How do you clean the un-removable burner tops
I have a MGR4452BDW. The burners turn 1/4 turn, then pull out. Yours should too.
Feb 23, 2009 | Maytag MGR4452BDW / MGR4452BDQ /...
Want to clean under stovetop
Hello
welcome to Fixya,
This stove has sealed burners and there is no need to lift or clean under anything except the burner caps.
You can not get inside the top and you can not lift the top like the old pilot stoves!
When you clean the burners and around rings do not spray or saturate the are and or the igniter element that creates the spark.I'll be back in a moment with your user manual.
first what is the complete model number of your range as written on the sticker in the door jam of the storage compartment down below. left side!
Huuum
Dec 15, 2008 | Frigidaire 24 in. FDB1050REC Stainless...
Hotpoint RA524 Electric Kitchen Range Logo
312 people viewed this question
Top Hotpoint Kitchen Ranges Experts
Dan Webster
Dan Webster
Justin Duby
Justin Duby
Ismael Rodriguez...
Are you a Hotpoint Kitchen Range Expert? Answer questions, earn points and help others
