Question about Samsung BlackJack II Smartphone
My samsung blackjack 2 will not charge. the battery is now totally dead, will not turn on and will not charge even with the wall outlet charger or the computer usb charger. when the phone still had some charge in it and I would plug it in to the charger, it would constantly beep and red light would flash.
  • 4 more comments
  • lovestofish2 Jul 13, 2008
    my samsung blackjack 2 wont charge today. the red light will come on and stay for a while, but then change to yellow and blink on and off....wtf
  • Anonymous Aug 22, 2008
    This thing is a royal POS. I have the same problem.
  • caitann Sep 10, 2008
    won't charge. A yellow light flashes when plugged into charger. HELP
  • jolietjoey Sep 18, 2008
    Yeah, Mine does the same thing.Won't charge, the light goes red for a couple seconds after I plug it in, then flashes yellow.
  • Anonymous Nov 26, 2008
    my phone will turn on and i will get the attnt logo and then when i push a buttton it will just turn of, and shows goodbye
  • Anonymous Dec 01, 2008
    same problem here... ;(
If the Red Led stays turned on it is as simple as this.....the solder connecting your power on button to the system board in your phone has worn off..... you must pop the power button at the top of your phone off and you will be able to see where the soldering paste has simply worn off. At my job I have a soldering machine so it was not problem for me. I simply took pasted it back to the board with tin.....now this may require some work. just pop off the top section of you phone with a flathead screw driver and pop out the power button. look closely and you should be able to see where the botton has lifted from the little greenish system board..... Find someone to solder it, put it back together and it works like new.........SEE YA
Posted on Nov 18, 2008
Apparently this is just a bug with many of the Blackjack II's. I have the same problem and I have read on forums that many others have had the same issues.
Posted on Aug 02, 2008
Same problem with mine. I have even replaced the phone and the battery and the problem still exists. I had another battery software installed and it show that the phone thinks the battery is fully charged and just wont charge anymore, even thought the battery bar is not even full and the Windows Mobils OS says that is battery is not fully charged.
Posted on Sep 04, 2008
If your laptop has a bad battery, will the computer still be able to turn on when plugged into a power outlet?
If your battery is totally drained or dead, your laptop will not turn on even when plugged in to power outlet. The power from the charger don't have enough power to pass through the battery that is trying to charge. Remove the battery and you will be able to turn on your laptop when plugged in directly to wall outlet.
Sep 21, 2010 | Toshiba Satellite M35X-S163 Notebook
Samsung Blackjack
Did it last shut down after draining the entire battery? And are you trying to charge it through a USB connection? The USB charger only charges the phone if it's on (I know, that's stupid, but there you have it). You'll have to use a power inverter and charge it on a wall outlet if the battery is dead. If that's what you're doing, let me know and I'll try to find another solution for you.
Aug 21, 2007 | Samsung Blackjack SGH-I607 Smartphone
Samsung Blackjack II battery went completely dead and now the phone will not recharge. When plugged in, green recharge light will not come on.
Issue with either battery, charging port on phone, or charger. Attempt replacement of charger or different outlet first. Then battery replacement, about $50. Then phone replacement (hope you're eligible for warranty or have insurance if you don't want to upgrade).
Sep 28, 2009 | Samsung BlackJack II Smartphone
My Samsung Blackjack II won't charge.
Return to the carrier for warranty repair.
If you are out of warranty there are some options you can choose from
1. Get repaired
2. New phone
3. external charging source
The external battery charger runs about 20 dollars on ebay with an extra battery.
Check out the following link to find more about these options
Samsung BlackJack II Battery charging problems
Jul 02, 2009 | Samsung BlackJack II Smartphone
I dropped my Samsung Blackjack II (model SGH-1617)in water. I took batter out and let dry. It seems totally dead. Any suggestions?
You can try to put the charger into the phone (leave the battery out) and see whether it wants to start.
If it works, it means your battery is broken, but your phone itself still works. Then, you have to buy a new battery.
Jun 22, 2009 | Samsung Blackjack SGH-I607 Smartphone
Phone will not charge.
The charge port of the Blackjack starts to go bad and will not send the full charge tot the battery.
1. Get repaired
2. New phone
Samsung BlackJack II charging problems
Jun 13, 2009 | Samsung BlackJack II Smartphone
Black jack 2 wont charge or turn on
take out the SIM and micro sd and turn on the phone. then shut it off again, replace sim and micro sd then turn back on. DONE! **works on samsung jack too!!!
Apr 26, 2009 | Samsung BlackJack II Smartphone
There is a yellow blinking light on my Black jack
1. Get repaired
2. New phone
Apr 22, 2009 | Samsung BlackJack II Smartphone
Blackjack won't turn on
THe BlackJack phone will only charge while its turned on! If you allow it to go totally dead you cannot recharge it. You will have to get a new battery.
Jan 12, 2008 | Samsung Blackjack SGH-I607 Smartphone
Blackjack will not power up even after charging battery
the pins inside the phone where its plugged in could be messed up, that's whats wrong with mine but i found the phone and i don't have warranty or service for it, basically use it for storing info.
Samsung BlackJack II Smartphone Logo
1,846 people viewed this question
Top Samsung Computers & Internet Experts
phoenix chi
phoenix chi
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
