Question about Whirlpool Estate TAWS750PQ 27-Inch Washer
Cold water dosn't come out
Estate by Whirlpool washer. Fixed once now cold water won't come out again?
Is it worth fixing?
  • chinalamb Jun 11, 2008
    thank you!
    President:
  • 1,294 Answers
Close your faucet valve on wall & unscrew your hoses to check screens on hoses & machine. Clean out well. See that the water pressure is good. Refit, check for leaks. If this is not the problem change your inlet valve, it is easily done.
Sites for spares:
RepairClinic.com (which is good)
espares.co.uk
AppliancePartsPros.com
Pl rate if helped.............
Posted on Jun 09, 2008
Washer will not rinse
you can put the extraction pipe /drain hose to ground level and water will drain then should open vacume switch thw programer is at fault as the programe sticks
Aug 18, 2012 | Estate Washing Machines
My estate whirlpool washer model# taws800jq1 water wont shut off when you start cycle
See this tubing:
If this tubing gets sediment in it OR vibrates loose OR gets pinched from re-installing the cabinet OR if the tube gets a hole in it then the pressure won't build up as the water level rises and the water will not shut down. The component that tube is attached to it the water level switch. The likelihood of it being bad is slim. Most of the time sand and sediment gets into the tubing and simply blowing it out and reattaching the the tube to the switch fixes it. Be sure to pump out water after cleaning and re attaching the tube to the water level switch. Service manual and more
Nov 08, 2011 | Estate TAWS800JQ Top Load Washer
My new estate washer with 4 water selections actually only has 2, hot and cold. The warm water setting fills with lukewarm water for a while then shoots in cold water for a while and back and forth. In the...
Yes, this is normal. All newer washer have auto temp control fills. This is to meet energy saving requirements. The less hot water used the more energy saved. Most hot settings on washers give out basically lukewarm water. The detergent made today is made to work well with cooler temperature water, so things will still come out clean.
Feb 01, 2010 | Whirlpool Estate TAWS750PQ 27-Inch Washer
At first the washer wouldn't fill up completely. Now the washer wont pull any water. Can this be fixed?
It could be a feewe things. Check to make sure the hoses are tightened down. It also could be the dial ( switch itself )
Nov 10, 2009 | Whirlpool Estate TAWS750PQ 27-Inch Washer
Whirlpool Estate Washer will not stop filling.
There is a fill switch that is not being triggered. Find out where that is. The dog hair could be the culprit. This switch is but cutting the tank fill. God Bless John
Apr 16, 2017 | Estate ETW4400VQ Top Load Washer
No cold water. I have hot, but not cold.
Turu off the cold water to the m/c, and hold hose into a bucket or something similar, turn water back on again, and see if you have a supply, if water there, then check the filter i the valve it it has one, and clean if req'd, reconnect hose and try again, if still no cold fill ,then the inlet valve is probably faulty, you will need to replace same.
Plz rate this solution.
Thanks.
Dec 25, 2008 | Whirlpool Washing Machines
Spin cycle not removing enough water from clothes
your manual states that it can be caused by cold rinses and or spin cycle not getting completed. please try to rinse in hot or warm and see if that does not solve your problem
Dec 20, 2008 | Whirlpool Estate TAWS750PQ 27-Inch Washer
Cold water won't come out on Estate washer by Whirlpool? Why?
HI THANKS FOR THE QUESTION . tHE PROBLEM WITH YOUR WASHER IS THAT YOU NEED A NEW WATER VALVE .tHANKS FORTHE QUESTION tHE APPLIANCE DOC
Jun 09, 2008 | GE WHRE5260E Top Load Washer
Maytag performa washer hot water runs continuously
Littleone.. please check your instructions.. some washers now dont need Hot water connection to them...they heat their own as part of the efficiency settings on the wash programmes themselves!
Regards Faggly
Mar 19, 2008 | Whirlpool Estate TAWS750PQ 27-Inch Washer
Washing Machines Logo
88 people viewed this question
Dan Webster
Dan Webster
Sal De GO PATS
