I have two computers for running a small business. Computer one connects to dial up and the router is used for wireless connection to the second computer. I had forgot my password to the original set up with the wireless so I reset the password on through www.linksys. Now my second computer no longer has internet access.
    President:
  • 1,944 Answers
Try using hiren's boot disc to recover your password.
http://www.hiren.info/pages/bootcd
Posted on Jun 09, 2008
I need help connecting a second computer to a Intellinet 5-port fast ethernet office switch. I have one computer up and running by setting up a new connection, how do i connect a second or third computer...
1.Log into router. Using either 192.168.0.1 ot 192.168.1.1 in a browser window that is ( internet Explorer or firefox)
2. Verify wireless router name( on the computer) >>> ( on/off) ( router status window)
3.Note router name you are connecting to.
4.. Check the laptop do ipconfig /all to see current IP addresses.
5. Set the laptop up in the router by WEP KEY or MAC address. This set up in the "security tab" in the router. using 192.168.0.1 or 192.168.1.1 to access through a browser.
6.Note router name you are connecting to.
7. try to log on to the internet.
This is for all routers to set up wirelessly.
Aug 26, 2010 | Computers & Internet
How can i set up a connection to a network with windows vista basic
There are several ways to do this you can use a router, wireless router or set up a direct connection. With a router all you have to do is connect your modem to the router and computers to the router. For a wireless connection you need a wireless card installed in your computer and a wireless router. You connect your modem to your router and set up your wireless connection with the software that came with your card or through windows wireless service. You can also connect two computers through their ethernet port with an ethernet cord. You plug coonect them with the cord go into control panel open network connections and to the left chose set up home or small office network. You will need to configure the computer with internet access as the host and the other as a guest. You can share any type of connection such as dial up, cable, dsl, and broadband.
Dec 30, 2009 | Microsoft Windows? Vista Home Basic...
Network setup questions.
You could program the MAC addresses of only the computers you wan't to be able to connect to the router. It seems like you could add the MAC of your girlfriends computer your business computer and any other specific computer you wan't to allow to connect and this would leave all your current securities in place. Here are instructions if this solution sounds like what you need. http://www1.linksys.com/support/troubleshoot/wireless/wireless_router_config/wireless_mac_filtering.html
Nov 21, 2009 | Linksys Wireless-G WRT54G Router
I get error 812 with the netgear wgt624v4
Error 812 is a dial up VPN error. If your not using a dial up Vpn network open control panel on your computer. Make sure you are in classic view, should be an option at top left of control panel to switch to classic view if you are not. Find internet options, click connections at top. The connections in the window are dial up connection, if you wish to use the netgear router its best to delete this click on each one in turn and remove on the right. When all are gone try and connect with netgear again. Your computer appears to be trying to use dial up and not your wireless router.
Hope this helps, any problems get back to me.
Owen
Oct 14, 2009 | NetGear WGT624 Wireless Router
2nd Computer in basement cannot access Internet
if your signal is low in there the best work around would be to lay a cat-5 cable up to the router, the wired connection would be faster and more reliable then a wireless, or buy another wireless router and put it closer to the basement than the first and wire the 2 routers togher with cat5 using the second router as a fancy switch.
Jul 02, 2009 | NetGear WGR614 Wireless Router
Forgot the Network Key
Ok, if her main computer is connected wireless, and still works, you may not have to reset the router at all.
Go here: http://www.nirsoft.net/utils/wireless_key.html
download it, and run it on her main computer. It basically finds the key that windows has already saved, and allows you to view it.
Let me know if you have any other issue. :)
May 28, 2009 | Westell Wirespeed VersaLink...
Wanting wireless hookup
1)Prepare your modem. Unplug the modem's power cord and place the wireless router unit next to the modem. If the router has antennas, make sure they are raised to their full upright position.
2)Reassign your networking cable. Unplug the cable currently connected from your computer to your modem and plug it into the port located in the wireless router. This port is usually colored blue.
3)Connect the router and the modem. Use the networking cable that came with your wireless router to connect the modem and router unit. The router port is typically colored in green.
4)Start up your modem. Plug in the modem's power cord and wait 1-2 minutes while it configures its settings and prepares to connect to the Internet.5
5)Start up the wireless router. Plug the wireless router's power cord into an outlet and wait 1-2 minutes to get it started. The router is ready when the 'wired computers' and 'modem' icons light up. These logos or icons vary by make and model of your router so consult the owner's manual if needed.6
6)Insert your installation CD. Use the wizard or assistant to check the configurations of your computer settings and launch your wirelessnetwork clip_image001.gif
Things You’ll Need:
  • Wireless Router unit
  • Networking cable (comes with router unit)
  • Installation CD
  • Modem
  • Modem power cord
Dec 02, 2008 | D-Link DI 713p (DI-713P) Wireless Router
Wireless internet
Basicly the wireless router needs to be connected into the internet, then you will be able to connect to it. You need to install the card and make sure it works in your device, then connect into the router and it should work fine.
Oct 27, 2008 | NEC MobilePro 900 Handheld
Belkin wireless router installation with a laptop that has an internal modem
Depending on the operating system that you are running, and if you have the appropriate wireless cards, you should be able to do this either with or without the modem. If you have the modem connected to one computer, and wireless cards on both computers, then your best option would be to just connect directly from one computer to the next. If you can tell me the answers to these few questions, I can help you get on the right path.
What operating system are you running? Windows XP? Vista? Macintosh?
Do both of your computers have wireless network cards? If not, then which computers have the wireless network, and which computer has the modem?
Feb 02, 2008 | Belkin Wireless Pre-N (F5D8230-4) Router...
Cannot get through internet via ethernet, I Appreciate your help.
You didn't state what kind of net connection you are using, dial-up, cable, sattelite.
If, for instance, you have cable, is the modem connected directly to one computer, or several, via router and ifso on the router is it "wireless" or cable connected?
If you are using anything OTHER THAN dial-up, I recommend, that you unplug the router AND modem, look for "resets" on both, sometimes the reset will look like a small resessed pin that must be pushed on with a pen or toothpick.(hold down for 30 seconds) Leave them unplugged...I would advise 5 minutes, then reconnect cables and power supplys and try again.
If none of this works and you have had electrical storms,(and sometimes wind damages cable if pole mounted) you may have surge-damaged routers/ and or modems. I usually have to reset mine after every lighting storm, and had to replace a damaged router twice. Sadly on another note, I would not recommend vista to anyone, I would however recommend XP media center for computers that have specs for it.
Hope this will help.
Dec 08, 2007 | Acer Aspire 5100 Notebook
Computers & Internet Logo
David Payne
David Payne
