Question about Microwave Ovens
Philco Microwave oven
Dear Sir,
For the past few days my microwave is not functioning at all. When I switch it on the display dots are visible but the control panel is not working at all. However the light comes on when I open the door. If I disconnet the plug and leave it for a few hours and replug it, it works but now even that is not doing the trick.
I got my electrical connection checked up and there is no problem. I changed the 3 pin plug but even that didn't help.
Please advise.
    Top Expert:
  • Microwave Ovens Master
  • 76,846 Answers
More than likely the ovens control pad is defective, very expensive to repair, best to just get a new MW oven.
Posted on May 19, 2017
MicrowaveSvc
  • 9085 Answers
SOURCE: Microwave stopping working
In this one, the most likely causes are the inverter or magnetron, but it really will need an experienced troubleshooter. Due to the lethal voltages involved, I do not recommend that a person without training and experience ever work on these models. You should be able to locate a Panasonic-authorized servicer here: http://www.pasc.panasonic.com/WhereTo/FindServicer.asp?Pass=1 I would mention the exact symptom when you call so the technician can bring a new inverter with him when he comes out to repair it. Might save you having it pulled into the shop.
Posted on Sep 22, 2007
SOURCE: Goldstar MV154SJ Over the range Microwave oven
check the touch pad , and check the control panel...
Posted on Sep 24, 2007
MicrowaveSvc
  • 9085 Answers
SOURCE: Microwave turntable won't stop running
This is usually caused by either a bad door switch, but may instead be a loose door switch mount or a problem on the control panel.
Even though a door switch clicks, it may still be bad inside.
If you or a friend decide to look into it, we have critical information on safety, disassembly and door switches at our site, linked here on Fixya: http://tinyurl.com/yzjozk
Posted on Nov 19, 2007
SOURCE: samsung microwave oven (touch panel problem)
you can use the express button in touch pad,
Posted on Jan 20, 2008
tiway1
  • 100 Answers
SOURCE: dacor dcm24s.light, fan, and control panel work but turntable and heat do not
Most likely the bottom door switch. Dacor units are built by Sharp and that switch is a very common problem. You'd either need to check the switch with an ohm meter or remove the cover of the switch to see if it's burned inside.
Posted on Dec 23, 2008
How to reset microwave
there is no reset function to look over, check safety interlock door switch, Has lamp & control Display lit?
Aug 19, 2014 | Panasonic NN-H965 Microwave Oven
GE spacemaker microwave turns off during cooking and display goes black
Step 1:
Door Switch
If the microwave runs for a few seconds and then shuts off, a door switch might have failed intermittently. Check each of the door switches for any signs of overheating, arcing, or burning. Also check each of them for continuity. Replace any of the switches that is visibly damaged or that only has continuity intermittently
Step 2:
Main Control Board
If the microwave runs for a few seconds and stops there may be a short circuit in the main control board. Check other components first, these boards are often misdiagnosed.
Touchpad and Control Panel
If the microwave runs for a few seconds and stops the touchpad and control panel might be defective. There are several other components that can cause this problem, be sure to check any other components before replacing this board.
Touchpad
If the microwave runs for a few seconds and stops the touchpad might be at fault. This is not common. Generally speaking, if the microwave display is working and some of the buttons respond correctly but some don't, the problem is with the touchpad.
High Voltage Transformer
If the microwave runs for a few seconds and stops the high voltage transformer might have an intermittent short. This is not common. Check other components related to the microwave symptom first.
Thermostat
If the microwave runs for a few seconds and stops the thermostat might be defective. Watch our video on testing thermostat
Step 3:
Step 4:
Step 5:
Step 6:
use the DVOM tester and fix it. God bless you
Feb 08, 2013 | Microwave Ovens
Panasonic genius1300w cuts off after 3 seconds
see this causes and fix it. God bless you
Door Switch If the microwave runs for a few seconds and then shuts off, a door switch might have failed intermittently. Check each of the door switches for any signs of overheating, arcing, or burning. Also check each of them for continuity. Replace any of the switches that is visibly damaged or that only has continuity intermittently.
Main Control Board If the microwave runs for a few seconds and stops there may be a short circuit in the main control board. Check other components first, these boards are often misdiagnosed.
Touchpad and Control Panel If the microwave runs for a few seconds and stops the touchpad and control panel might be defective. There are several other components that can cause this problem, be sure to check any other components before replacing this board.
Touchpad If the microwave runs for a few seconds and stops the touchpad might be at fault. This is not common. Generally speaking, if the dishwasher display is working and some of the buttons respond correctly but some don't, the problem is with the touchpa
High Voltage Transformer If the microwave runs for a few seconds and stops the high voltage transformer might have an intermittent short. This is not common. Check other components related to the microwave symptom first.
Thermoprotector If the microwave runs for a few seconds and stops the thermoprotector may have tripped. This is a safety device to prevent the microwave from overheating. It can be tested for continuity to see if it's blown.
Thermostat If the microwave runs for a few seconds and stops the thermostat might be defective. Watch our video on testing thermostats.
Oct 09, 2012 | Panasonic TK-929SA Stainless Steel...
Set clock but time goes off
Touchpad If the microwave runs for a few seconds and stops the touchpad might be at fault. This is not common. Generally speaking, if the dishwasher display is working and some of the buttons respond correctly but some don't, the problem is with the touchpad.
Oct 02, 2012 | Viking VMOS200 Microwave Oven
MICROWAVE WILL NOT FUNCTION. DISPLAY READS DOOR.
Hi, The door switch is broken..
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Nov 24, 2010 | KitchenAid KBMC140HSS Convection/Microwave...
Hy i own a samsung microwave oven . for the past few days the keypad is not responding? what to do?
The keypad needs to be replaced...
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
http://www.fixya.com/support/r5508031-microwave_oven_basic_troubleshooting
heatman101
Aug 19, 2010 | Samsung Microwave Ovens
Night Light
Replace the touch panel. One or more buttons are failing.
Feb 03, 2009 | Frigidaire PLMV168 Microwave Oven
Sharp R-953M combination oven. Display not working.
We repair those for $39.95 mostly for US and Canadian customers, but in the UK you can contact Quality Electronic Repairs. I think they repair these.
Otherwise, you would have to replace the control unit, which consists of both circuit boards and the display.
Dec 24, 2008 | Sharp R-220HW Microwave Oven
Microwave Ovens Logo
480 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
