Question about GE WHRE5260E Top Load Washer
Cold water won't come out on Estate washer by Whirlpool? Why?
We have had problems with our Estate washer by Whirlpool just after the warranty ran out. Now, about 3-4 years later, the cold water won't come out again. What's going on and is it worth fixing again?
  • 943 Answers
Posted on Sep 12, 2008
I have an Estate 8cycle 2speed washer that won't fill unless the temperature selector is set to Hot/Cold. Any ideas on what I need to check first?
I bet If you switch the water hose around it will fill on cold and not hot. Reason I think so is that hot fills and doesn't use the cold line. So either you got a bad cold valve or a blocked screen. Also Try to run the hoses into a bucket and see if they run well to eliminate the water source.
Jul 29, 2013 | Washing Machines
Water won't shut off on my Estate washer
check clear tube that is inside machine.1st take off shell of machine look for clear tube about 1/4 inch sometimes comes off,it pushes over nipple to load size water fill knob.if it came off the water will keep on flowing and over flow.if that's the problem just put a dab of silicon on nipple and push tube back on.
Feb 20, 2012 | Estate TAWS800JQ Top Load Washer
My new estate washer with 4 water selections actually only has 2, hot and cold. The warm water setting fills with lukewarm water for a while then shoots in cold water for a while and back and forth. In the...
Yes, this is normal. All newer washer have auto temp control fills. This is to meet energy saving requirements. The less hot water used the more energy saved. Most hot settings on washers give out basically lukewarm water. The detergent made today is made to work well with cooler temperature water, so things will still come out clean.
Feb 01, 2010 | Whirlpool Estate TAWS750PQ 27-Inch Washer
Hot and cold water mixup
Switch the lines and grin and bear it!!
Jun 20, 2009 | Whirlpool Washing Machines
No cold water. I have hot, but not cold.
Turu off the cold water to the m/c, and hold hose into a bucket or something similar, turn water back on again, and see if you have a supply, if water there, then check the filter i the valve it it has one, and clean if req'd, reconnect hose and try again, if still no cold fill ,then the inlet valve is probably faulty, you will need to replace same.
Plz rate this solution.
Dec 25, 2008 | Whirlpool Washing Machines
Spin cycle not removing enough water from clothes
your manual states that it can be caused by cold rinses and or spin cycle not getting completed. please try to rinse in hot or warm and see if that does not solve your problem
Dec 20, 2008 | Whirlpool Estate TAWS750PQ 27-Inch Washer
Cold water dosn't come out
Close your faucet valve on wall & unscrew your hoses to check screens on hoses & machine. Clean out well. See that the water pressure is good. Refit, check for leaks. If this is not the problem change your inlet valve, it is easily done.
Sites for spares: (which is good)
Pl rate if helped.............
Jun 09, 2008 | Whirlpool Estate TAWS750PQ 27-Inch Washer
Maytag performa washer hot water runs continuously
Littleone.. please check your instructions.. some washers now dont need Hot water connection to them...they heat their own as part of the efficiency settings on the wash programmes themselves!
Regards Faggly
Mar 19, 2008 | Whirlpool Estate TAWS750PQ 27-Inch Washer
GE WHRE5260E Top Load Washer Logo
229 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
