Question about Casio PRG-40T-7 Pathfinder
Casio G-shock watch 2688 battery replacement
Can I get a document showing how to change the battery?  Where do the three springs go?  How does the band come off (normal screw direction? It's real tight)  Thanks, anbk@cwnet.com
  • anbk Jun 10, 2008
    Thanks for trying, but the manual says to let a store do it because of the water seal washer.  So the manual doesn't show.  I've had the watch apart to see how many batteries were there and one spring sprung.  Don't see any place appropriate for it.
    Any other ideas?
  • sonetlumiere May 11, 2010
    Manual does not show how to get the "dam" silver plate off. have searched every where for this info but is must be part of the official secrets act
  • Casio Master
  • 13,433 Answers
Check the manual it should be covered there.
Use this page to download a copy of CASIO watch manuals in PDF format. To download a PDF file, enter the four-digit (or three-digit) module number marked on the back cover of your watch.
http://world.casio.com/wat/download/en/manual/
You will need a pdf reader on your pc, you will find all instructions in there.
If you don't have a pdf reader you can get one from
http://www.foxitsoftware.com/pdf/rd_intro.php
Posted on Jun 10, 2008
  • r2d2r2d2 Dec 03, 2010
    Areally lame answer. The manual says NOTHING about how to change the battery or spring placement. Any 3rd grader could find the casio website and pfd manual.
    You tube offers several great videos for this operation. Just enter "casio gshock battery" and you will find what you are looking for.
    I just changed my gshock battery with a genuine Panasonic ctl1616 battery I found on the internet with a google search for $12.95 including the little tweezers you will need.
    My watch needed a replacement at about 5 years. Its holding up great!!
    Good luck all.
G shock 2688. How do I turn the light on?
PDF]Operation Guide 2608 2638 2688 - CASIO.
ftp.casio.co.jp/pub/world_manual/wat/en/qw2688.pdf...
Jul 04, 2015 | Watches
Casio GW810D I have changed the battery, the display is now running but none of the buttons are functioning. Have I missed/lost something. Any help is appreciated.
you need to do this Shortcut the battery with AC contact. AC can be found on the sides of watch movement(very tiny). You have to use pointed tweezers: one end on battery+, another on AC contact for three secs
Feb 12, 2013 | Casio GW810D 1 Digital Shock Watch
While replacing battery in my Casio 2688, I lost one of the three springs. What can I do?
yes you can , if you get a spare old watch or go to watch shop and get spring loaded bar for watch strap snap it open you can use the springs off then
Dec 28, 2012 | Watches
I have a Casio 2688 atomic watch and lately it does not hold a charge for a long period of time. It will recharge and then quit within a day.It will hold a medium charge for about 24 hours at most, but...
You likely have a dead battery. Follow the instructions on this web site http://forums.watchuseek.com/f43/how-change-ctl1616-rechargeable-battery-41076.html
it is clear and covers most casio models. Watch closely for the springs when taking your watch apart. You can order the battery online (the best option) but most people that use a standard lithium battery seem to have no problem.
Nov 23, 2010 | Casio PRG-40T-7 Pathfinder
I went to Mexico the watch automatically changed an hour back. I am now home in the USA and I can't get the watch back to an hour ahead Casio G-Shock 2688 gw-330a
Thank you for contacting FIxYa.<br /> The G Shock in one of the most advanced watches, and also a very complex watch. Your best bet is to go to their website for support from them. Thank you and best regards.<br /> <a href="http://www.gshock.com/support/">http://www.gshock.com/support/</a>
Aug 25, 2010 | Watches
How do i get the atomic signal indicator to work on a g-shock 2688
Try the manual : - http://ftp.casio.co.jp/pub/world_manual/wat/en/qw2688.pdf
although, unless you're in North America, you probably won't get the signal the watch needs to synchronise.
Jul 30, 2010 | Casio G-Shock GW500A-1V Wrist Watch
Loose spring popped out from behind....now I have no sound!
this video will show you were the spring goes next to battery
Jun 14, 2017 | Casio G-shock G2300B-1V
I had the battery in my Casio G Shock DW 6800 replaced. Since then none of the beeps or alarms have worked. Is there a reset button he didn't press?
There is a reset button inside your watch, but I don't think that is the problem. Most likely, there is a spring that makes contact to the watch and the back of your watch case, and it fell out by the person replacing your battery. I would definitely go back to the place where you had the battery installed, and have them take care of the problem buy ordering you a new spring or have them pay for you to send it to Casio.
Apr 24, 2008 | Casio G-Shock GW500A-1V Wrist Watch
Casio 2688 Wave Ceptor - No Display
On the solar charge watches, they use a chargeable Lithium battery. It is NOT an off the shelf regular battery! It is best to send the watch to the factory service rep in your area for a battery change.
In many of these models the battery is using solder contacts to the circuit board. The person changing the battery will require the original spec battery, and be equiped to do surface type soldering.
When working on this watch, the factory service will change the seals and do a pressure water resistance test. The regular corner watch service store is not equiped to do this type of testing.
Normaly, the battery in solar watches should last more than 5 years. Some are going past 10 years!
Jerry G.
Feb 23, 2008 | Casio Wave Ceptor WV57HA-1AV Wrist Watch
Casio PRG-40T-7 Pathfinder Logo
4,452 people viewed this question
Top Casio Watches Experts
Kazim ERGUNEY
Kazim ERGUNEY
Ansel Alberto
Ansel Alberto
Are you a Casio Watch Expert? Answer questions, earn points and help others
