Mine as well! Any answers to this one?
I've heard replacing the batteries, clean the laser head off with a glasses cloth, mine sometimes does this when it's too hot. We use it for work and it sits in the car which isn't great. It only works perfectly at room temperature. If it's too cold it doesn't work either.
Did you ever find a fix for this? My Leica Disto A5 is doing exactly the same thing!
"Press and hold the "left arrow" key.
Press the "Setup" key and release both keys.
Display should say "Enter Special Key Combo"
Press and release the "OK" button
1. Press and release the right arrow button until the display says "System Configuration Menu".
2. Press and release the "OK" button.
3. Display should say "Hardware failure status". If not there already, Arrow Key over to "Hardware failure status",
4. Press and release the "OK" button.
5. Display should say "Hardware failure status: Clear. Press OK to clear".
6. Press and release the "OK" Button. Message changes to "Hardware failure status Cleared. Press Cancel to continue".
7. Press
and release the "CANCEL" button as many times as necessary, so that,
either the "Welcome to Photosmart Express" screen appears, or, the "Ink System Failure" screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
8. Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.
9. Wait
30 seconds for the power to get discharged and then plug the power
cable into the wall outlet first and then into the back of the printer
10. Turn
the unit on. The printer may display message "USE POWER BUTTON TO
SHUTDOWN THE PRINTER" followed by "PRESS OK TO CONTINUE". Press OK.
11. If the printer has already initialized, then go to the next step. If not, the printer will start the "ONE TIME INK
INITIALIZATION PROCESS". Allow this process to complete and do not
interrupt. Once the initialization process is complete, the printer will
print out a Diagnostic Page.
12. To verify printer functionality print a SELF TEST PAGE. If SELF TEST prints, then printer is ready for use.
NOTE: If the error is still there, or reoccurs replace the unit."
Procedure from http://www.fixyourownprinter.com
