Question about HP 500VA UPS System
500 VA HP UPS HJU89111
Sir actullay i have some technical problem in my UPS Model No. HJU89111 i am a diploma holder in electronics can you help me to solve this problem.i'll wait of your answer thanks
Yasir Raza
Do not turn on even connected to the power outlet.please help!
check the batteries,make sure ups run on battery before input mains.report
Oct 02, 2015 | APC Back-UPS RS BR500CI-AS...
Can i use a surge suppression stripe on my UPS
Not recommended. I asked APC technical support before.
Apr 20, 2014 | APC Back-UPS ES 350 - UPS ( external ) -...
Pro 650va
hi i am rehan frm karachi 03312504748 ap k ups ki battari kharab he
Jul 24, 2013 | APC Back-UPS CS 350VA - UPS - 350 VA - UPS...
How many systems support for 1 KV UPS
1 KVA UPS will provide you good back up with 2 pcs simultaneously without any power fluctuations.
May 24, 2010 | Liebert 1 KVA UPS MODEL RT1000-60...
No Output from UPS ACP BE650R backup
I too facing the same problem ?
If supply is switched off UPS also shutting down.
But the battery is fine. Back up is not comming.
Any body help me in this regard.
Apr 18, 2010 | APC Back-UPS ES 350 - UPS ( external ) -...
WHAT IS THE AMMOUNT OF POWER CONSUPTION FOR A UPS OF 30amphs and a model of R5500XR
That UPS is rated for 5000 VA and 4500 Watt.
It will power appliances at 100% for a bit less than 5 minutes (5 minutes correspond to 31.25 Ah, not 30), but "typical" endurance time is around 15 minutes.
Maximum power consumption is around 4600W, which is for a completely flat battery being recharged while at the same time powering 4500W (100%) of utilities.
Detailed specs here:
http://h18000.www1.hp.com/products/servers/proliantstorage/power-protection/rackups/r5500xr/specifications.html
Nov 05, 2009 | HP R5500 XR (326529-b31) UPS System
Durning an electrical storm the ups shu toof and now does not work is there a switch or fuse that needs to be replaced vern
No electronic equipment should be uswd during electrical storms. There is always a fuse at the back of the device. Unscrew it and check the glass viol for a broken wire inside. If yes, then replace it with the same specification viol. If not then the damage is serious and needs professional help.
Aug 16, 2009 | TriPro Power Tripro Maruson Technology UPS...
Does the 3M 8647 Projector requires a UPS for proper shutdown
look at the amount of va the projector can handle and then decide from there on
Feb 06, 2008 | 3M MP 8647 Multimedia Projector
UPS 1800VA
You can increase the capacity of the batteries from the original equipment, but you cannot put more load onto the UPS. Your runtime may be increased, but you may have trouble fitting the car batteries into the case. Some UPS's have external connectors for external battery packs. Find one of those and add the batteries to it. Make sure that you maintain the DC voltage which the UPS requires. It may be 12 volts or 24volts. Two 12 volt batteries in Series.
Oct 16, 2006 | HP (A2997A#002#017) UPS System
HP 500VA UPS System Logo
235 people viewed this question
Top HP Computers & Internet Experts
Thomas F. Schneider
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
