Question about Fisher and Paykel DGGX1 Electric Dryer
F&P DGGX1, drain backed up, control boards got fried.
With all the rain we've been getting, my drains ran backwards last Friday early morning. I've been so busy cleaning up that today when I went to start a load of laundry, I was surprised that the dryer, a Fisher Paykel DGGX1, would not power on. Closer inspection found that there was standing water in the exhaust area, which I drained. Took the front panel off the dryer and instantly smelled that "burnt electronics" smell.
Can anyone point me in the right direction to order parts? (or tell me that I'm better off just replacing it?)
Thanks a lot in advance!
  • JHoover Jun 09, 2008
    Could you be specific with why?
  • 87 Answers
Replace it
Posted on Jun 09, 2008
Why has my dishwasher stopped working completely?,
Sounds like it isn't getting power. Check the circuit breaker that controls the circuit the dishwasher is wired into.
Aug 31, 2014 | Whirlpool 24 in. DU915PWP Built-in...
Electrical problem on 1996 Dodge Dakota
It will drain at a rate of 21Watts X 2 = 42Watts at 12Volts = 3.5Amps. If you have an 70 Ah battery that is 20hours to totally flat from fully charged.
May 27, 2017 | 1996 Dodge Dakota
Water leak after rain, rear floorboards soaked? HELP!
a couple things to look at if it has a sunroof the sun roof would have drain hoses that run down in each corner next you need to look at the cowl this is the section in front of the windshield that has a drain on it as well if you find nothing there the next step would be to remove the seats and carpet and sit in the car while running water over it either way you should remove the carpet and make sure it is dry all the way threw or mold will start to grow and you will never get ride of it not good for your heath other key spots to look at is if the windshield was ever replaced it could be a poor seal
Jun 14, 2012 | 2008 Toyota Corolla
Maytag, model MDB7100AWB, acts spuratic!? 4 days ago it hummed most fo the evening, I just thought it was the fridge. There was water sitting in the bottom when I opened the door - and the humming...
probably the drain pump, access is underneath and to the right of pump housing, the drain hose connects to main housing and the drain motor is right and just behind where hose connects. open door part way for easier access. and use shop vac to remove as much water as possible, then have 2 or 3 bath towels to clean up if you try on your own. local parts house will have drain pump if you take model # with you
Dec 20, 2011 | Maytag MDB7100AWB Dishwasher
Were is the main fuse for a 1988 ford pickup.The truck started and ran fine.The battery drained and stupid me put the battery in backward.Now does not crank and when I jump the wires to get it to crank it...
Sounds more like a burnt fusable link, check wires for burnt spots. may also have burnt up starter. also the computer could have been fryed.
Sep 13, 2011 | 1988 Ford F 250
Motor does not fire but did this morning before i took it out
well most likely you fried the control module .hooking battery up backward even for a couple seconds will do it .
Mar 08, 2010 | Boating
Water accumulates on the front and rear driverside floor boards
do you have a moon roof. That would be the only thing with drains.
Look for water stains, trails. Could be roof ditch moldings or even sealer skips in windshield or back window. Could b a/c drain if you are running a/c
Jan 08, 2010 | Saturn L300 Cars & Trucks
FIsher Paykel DD6031, motor needs replaced, Is it worth it?
dont bother repairing the Unit the Timer is Fried, Its worth about $350.00 W/ Labour, I'd buy a new one Personally. Goto ajmadison.com they have fantastic deals.
May 14, 2009 | Fisher and Paykel 24 in. DD603H W Built-in...
Bosch SHU9915 Does Not Drain
faulty controls..the signals are apparently getting there, but the machine is intepreting them oddly..may need a new control board behind panel
Mar 09, 2008 | Bosch SHU9950 Dishwasher
Fisher and Paykel DGGX1 Electric Dryer Logo
59 people viewed this question
Top Fisher and Paykel Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Craig Butler
Craig Butler
Are you a Fisher and Paykel Dryer Expert? Answer questions, earn points and help others
