Question about EliteGroup P4VMM2 Motherboard
Inno3D FX5500 256ddr tv-dvi 128b
I bought Inno3D FX5500 256ddr tv-dvi 128b for this Mother Board But it dsnt work.. Totally blackout in my monitor and blinking orange light.
  • 2 more comments
  • Steven141414 Jun 10, 2008
    Thanks.. it works but there's another problem. i completely installed the Video Card Driver but when i open my online game like Ragnarok the names and other letters there becomes blurd and it always hang after 5 to 10 mins. By the way my Ram is 512 mb 333mhz and my power supply is redfox 400watts. Hope do u have any idea why this happen. im currently using the built in video card and it has no problem with my game ragnarok.
  • zarmec Jul 05, 2008
    i have a nvidia inno tornado geforce fx 5500, the disk installer called not locate any driver in my cpu..and cannot proceed installation..my cpu is emachine with 512 ddr and 2,3 ghz processor..
  • Kadskilawen Jul 28, 2008
    Hello Good day i had also the same problem the the PC monitor only blinks when i insert my new 8X AGP Video Card need help!!!!!
  • copler19 Aug 16, 2008
    download the driver of geforce FX5500 ddr 256MB
How to download the driver of geforce fx5500 DDR 256MB(128bit)DVI+TV
Posted on Aug 16, 2008
SlangshingSTAR
Is theres any site that we can easily downloads this inno3d fx5500 256mb installer.. i lost mine and im in hardy to recover it!!!
Posted on Jul 11, 2008
I was also facing the same problem(orange light..stand by monitor during Booting ).. and after a long time I thought that the card is defective. But ITS NOT !!
Solve :
1.Open your CPU cabinet and check all your Hardware fittings (its really working !)
2.Eradicate ant old dial-up modem.
3.Change Ur BIOS settings: to AGP (MUST).
Now restart Ur computer.
YOUR ORANGE LIGHT PROBLEM IS SOLVED !!!
TESTED OK.
'eu
Posted on Jan 30, 2009
    President:
  • 2,351 Answers
Hi Steven141414, when adding an AGP video card in to the opened AGP slot, you must make a change in the bios for the motherboard to use the new AGP card. Do you still have you're motherboard manual? Please go to page 33 in you're manual.
If you no longer have you're manual, you can download it by clicking on this link: http://www.ecs.com.tw/ECSWebSite/Downloads/ProductsDetail_Download.aspx?detailid=272&DetailName=Manual&DetailDesc=P4VMM2%20%20(V3.2A)&CategoryID=1&MenuID=82&LanID=0
I understand you have no display currently. Please remove the AGP video card for now. When you boot you're system you should have video display. Enter the bios. Normally to do this you will need to press the delete key once every two seconds until the bios menu upends. (Just as you turn on the PC).
Once on page 33 you must change Primary Graphics Adapter to AGP. (Not to PCI)! Save & exit the bios after making the change. Press & hold the power button on the PC until the PC shuts down. Unplug the power cord from the PC. Using canned air, blow out any dust that may be in the APP slot. (Good time to blow out any dust within the PC, including cleaning the CPU fan). Than install the AGP card. Connect an additional power to you're AGP card if it requires it. Double check all data & power connectors within the PC (Good connections), before closing the case. Re-connect the power cord to the PC & power it up. Once windows has finished loading, install the AGP cards software. Lastly, check windows for any updates & install.
Good Luck!
Mike
Posted on Jun 09, 2008
  • Mike Peluso
    Mike Peluso Jun 10, 2008
    Steven, I would say it's the video card. New or used matters not. Since the onboard works fine but the AGP hangs & is blurred, than there is a problem with the AGP card. I have come across a lot of FX5500's from other users who all seem to have issue's with the card. May I suggest another AGP 4X video card? Any one of these 4x AGP cards on this link.
    http://www.tigerdirect.com/applications/...
    Steven, since my suggestion lead you to being able to get you're AGP card to display, that's considered a fix. It's not you're fault the AGP card is not performing as it should & not mine fault either. Rating an expert (me in this case) is all about status. No money, we don't get paid. We help people like you because we can.
    Again, Good Luck!
    Mike
They tried to steal my car they broke the ignition housing i have replaced it with the old key it dsnt want to start thy tried reprogramming it it shows a warning key sign on the desh board
The immobilizer is working then. You need to pair your key to the immobilizer or there will be no ignition. Probably only available at a main dealer.
Feb 24, 2017 | Cars & Trucks
Monitor totally blackout
Hello madelyntrist,
Monitor totally blackout may from inverter problem.
To make sure inverter or not, switch on than knock the panel smoothly. If you see flashing light on area knocked, that indicate inverter is ok.
If that still any questions, please let me know.
Mar 27, 2011 | BenQ DV2680 26 in. HDTV-Ready LCD...
My mother board is D915GEV when I connect inno3d Geforce 9400GL 1 GB video card to PCI-E slot and start my computer then computer does not boot neither it turn on the monitor. But in the same system if I...
It is possible that the 9400GL is not compatible with your motherboard. Might be possible that the max video memory is 512MB.
Maybe a BIOS update can solve this.
Sep 21, 2010 | Intel D915GEV Motherboard
No picture. Monitor blinks 4 reds. Tv would come on for a few seconds then turn off. Now nothing but blinking lights. what do I do. Thanks
You have may be broke the system cable, the dvi-d cable is broke...
In my pdp-5030hd have the same problem, probe changing the only the dvi cable and works perfect...
The monitor blinks 3 red and the 4 blinks still in red...
Now i will try to put in the dvi-d input another source like a pc...
You need always the Pdp03u box for control...
Sep 12, 2010 | Pioneer PureVision PDP-5030HD 50 in....
My samsung 2233 has been totally blackout. Using a light, I can read the word behind the black screen. To solve the issue, I re-install all drivers, monitor adaptors, anti-virus softwares, finally formated...
Hi:
Unfortunately, it isn't a Windows problem, but a monitor power or backlight failure. Your monitor's high voltage inverter board, or the backlight has failed. Often it is too expensive to repair, and cheaper to replace the monitor if it is out of warranty
Dec 03, 2009 | Samsung SyncMaster 2233BW 22" LCD Monitor
Blackout screen on computer monitor
Please try to check your VGA card placement to its slot, then check its cable connections, if still the same problem, try to connect your monitor to another PC & if it operates, then your VGA card is defective. regards
May 15, 2009 | Dell XPS Desktop with Intel Core 2 Quad...
Dell Monitor Not Working
well if the status of the LEd on the monitor is amber(orange) & the system is running on a on board video card & not a Add-on video card... it is a possibility the the integrated video card ot the mother board might have gone bad... either contact a local tech or the tech support for the computer...
also unplug the monitor cable from the system tower & then if you see that there are the bars moving which say monitor self test on... means tht the problem is with the video card or the mother board...
since the system is running on a integrated video card...
Jan 17, 2009 | Dell 828FI 15" CRT Monitor
No signal
Weegee, Unfortunately you are trying to mix two different video types: VGA is an analog video interface found on most computers (except for latest with flat panel monitors, which are usually DVI). Your TV DVI interface is digital (although there is a DVI-A, which is an anlog DVI interface, it is unlikely that your TV has this). So, what you are trying to do probably won't work. I assume your computer does not have DVI output (otherwise you wouldn't have bought the adapter), but some monitors have VGA inputs; does yours? What kind of DVI adapter did you get? Is a DVI-A? Check out http://en.wikipedia.org/wiki/Dvi for info on DVI interfaces.
May 12, 2007 | iLO 3200 32 in. LCD Television
EliteGroup P4VMM2 Motherboard Logo
3,682 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
