Question about Motorola Mobility RAZR V3
Keypad stays lit when you turn the power off
Whenever i turn the power off it powers down normal but then the keypad lights up and does not go out until the battery goes dead. Also the battery does not last very long any more. tried a new battery and no difference.
    Master:
  • 497 Answers
U dnt hav to wait for the batteries go dead..just remove the batteries..and the lights wud turn off..and abut the the batteries..i guess there is a malfunction..please check in wih ur moto service centre...all the best
Happy to help
Have a nice day!
tc
Posted on Jun 09, 2008
My 5828V do not go to sleep after I change the batteries a few days ago. Please help
Is the 5828V connected to an A/C adapter? If so the screen will stay lit - this is normal. If you do not have an A/C adapter - try an arm/away then a disarm and see if that makes it go to sleep. ... and if you don't have an A/C adapter - consider getting one as the keypad will then report on system changes - something you are missing with a battery only powered 5828V.
I know on the Ademco Lynx-Plus keypad / the alarm panel - the display will stay lit after you exit programming mode until you do an arm/away and disarm so it may be the same with your 5828V.
Aug 17, 2014 | Honeywell 5828V - Ademco Wireless Talking...
Whirlpool quiet partners II normal light flashing
CHECKING KEYPAD OPERATION
A rapidly blinking LED over one of the keys of the keypad (or sometimes a "dead" keypad/console)
To determine if the control or keypad is faulty, do the following test:
1. Unplug dishwasher or disconnect power.
2. Open the dishwasher door.
3. Open console and disconnect the keypad ribbon connection from the control (at P1).
Make sure all other connections are made.
4. Put console back together. Do not close the dishwasher door.
5. Plug in dishwasher or reconnect power.
6. Wait 5 seconds.
7. Close dishwasher door.
8. Monitor the control's response:
If the control is OK (no longer sees shorts with the keypad unplugged),
it will respond by turning on a Drain Motor for 2 minutes.
Check and/or replace the keypad if the control responds OK.
If the control is not OK (still sees shorts with the keypad unplugged),
then the drain motor will NOT respond and will remain off.
If no response, replace the control.
Dec 18, 2013 | KitchenAid 24 in. KUDI02IR Built-in...
Induction cooktop-flashing keypad
Refer to user manual or company support, the keypad is giving you a error message of some sort, and it is dependent on the make and model on what that error message means so by referring to the manual or posting it would further help you in figuring out what the issues
Jan 27, 2012 | Cooktops
I just bought a 6160 alpha keypad and installed it, I powered it up and there was no display. The armed and power lights are flashing rapidly. I tried pressing the No. 1 and 3 right after power up with...
Your keypad needs to be addressed. Within 30 seconds of powering up the panel, go to the keypad and hold down the 1 and 3 buttons. Most likely, Address 31 will pop up on the display. Push 1 then 6 then *(star).
Address 16 is the default address for the first keypad on the system.
Aug 20, 2011 | Honeywell Ademco 6160 Alpha Keypad Vista...
I have a Lynx system with a 5828 wireless keypad that I have connected a 5v transformer to it to keep the keypad lit always. The keypad does not stay lit always and it keeps going to sleep after 10...
It sounds like your 5V transformer isn't working. It could be the outlet it is plugged into isn't working, or the outlet is on a light switch that is turned off, or there is a problem with the keypad itself. The user manual says:
"AC-Powered Operation: When powered by the
optional AC adapter, the keypad remains active at all
times. If AC power is lost, the keypad reverts to
battery-powered operation until AC power is restored
On AC powered units you can get the status by viewing
the display."
The only way I know of to keep it active is by using the transformer.
Hope this helps.
Mar 22, 2011 | Ademco 5828 Wireless Keypad Lynx / Vista...
I need the Remote Master 562 code for a Nikkai DVD. It's not mentioned in the instructions.
Turn on your dvd player, press the DVD mode button, hold down P+ and V- for a couple of seconds until the power button stays lit up...then enter 0005 on the keypad...then, once again, press DVD mode, hold P+ and V- until the power light comes on, and then just keep hitting the power button...
when your dvd player turns off, thats the right setting, immediatly press P+ and V- to store the code...
Aug 23, 2008 | Televison & Video
Washer power
Sounds like you have a stuck or shorted keypad. I've seen this a lot on this model. Solution is to replace the keypad. Catriver.
Aug 04, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Won't run - normal light flashes
You may try removing power to D/W for a minute and reconecting. likely cause though is keypad (console). If a light above a pad stays on the pad is likely closed all the time. Normal is probably cycle most often used. you can test the keypad by removing power to D/W and accessing the control panel. remove conncter P-1 and using an ohmeter test resistance between 13 and 4 on the connecter coming from keypad. yes without very small clips or 4 steady hands it is a little tricky. in the field we use a breakout board. if you get any reading when not pushed pad is bad. you may find a manual inside the kickplate which explains the keypad sequence. it may be control but more likely keypad, even if test is inconclusive.
Jun 07, 2008 | Whirlpool 24 in. GU2500 XTP Built-in...
Humming Sound
Hello, that is actually happening when the light that is on in the keypad. When its lit up, u will hear a slight humm. Its known as the keypad hiss amongst people in the know. That is the part that motorola used that makes the sound. its a very common thing. It was the first time motorola used that type of LED in the keypad flex. Hope that helps. Only way around it is to turn off the keypad light.
Jan 23, 2008 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
