Question about Samsung Microwave Ovens
Microwave not working
A component which we not sure either diode or fuse or resistor tag named rg308 is open on both sides and it is groundig the one leg of megnitron and capicitor and megnitron points are also open so give us ur experienced answer
3 Suggested Answers
  • 3289 Answers
SOURCE: Ge microwave mod. #JVM1851BH06. i ohmed the
I'd say your diode is bad but your capacitor may be good. You need to test it further - as described below.
In order to get reliable measurements to make a determination about the condition of the components, each should have at least one lead removed from the circuit. If not, your meter will read the through the rest of the circuit - and not be limited to the diode or capacitor under test.
To check a diode: Set the meter to to the lowest scale (Rx1) and touch black (-) probe to the cathode of the diode (the end with a band around the diode body) and the red (+) to the anode lead to reverse bias the diode. The meter should indicate "OL" or high resistance. Reverse the meter probes so that RED (+) is on the cathode lead and black (-) is on the anode to forward bias the diode. The meter should read a very low resistance - approaching 0 ohms. Diodes should conduct in one direction only - and the other is should look "open" If it conducts or is open in both directions, it is defective. Zener diodes can be checked with an ohm meter, but need a variable voltage supply and are required to be in a circuit (instead of out of circuit like a standard diode) for accurate testing. A link to zener diode testing here.
To check a capacitor: Set the meter to the lowest scale (Rx1) and touch probes to capacitor leads. The meter should indicate "OL" or high resistance and show steadily decreasing resistance before increasing to OL or high resistance again. Swap probes from the meter on the capacitor leads and "OL or high resistance indication should change to an even lower amount of resistance thas before before returning to "OL" or high resistance indication. These are test result characteristics of a good capacitor under test.
I hope this helps & good luck! Please rate my reply - thanks!
Posted on Jan 27, 2011
MicrowaveSvc
  • 9098 Answers
SOURCE: The capicitor reads 2.0 meg ohms and increases to
With a normal meter, these are the readings a good cap and diode will show.
See these links:
http://www.gallawa.com/microtech/cap_test.html
http://www.gallawa.com/microtech/diode.html
(if it is NOT shorted or burned looking, it's probably fine)
If you still need help, please make a new post with that your full model number and symptoms.
Posted on Jan 29, 2011
Whirlpool microwave keeps opening high voltage diode
If you do not have any experience in the repair of microwave ovens do not engage in their repairs because it is one of the most dangerous household appliances and the consequences can be disastrous. According to your description, low voltage circuit (220V or 110V) works well (light, turntable...). Obviously the problem is in a high voltage (HV) circuit which is made up of the magnetron, HV diode (rectifier), HV capacitor and HV fuse or protect diode. Failure is in any of these components in "HV circuit" or sometimes in interlock switch assembly or PC Board.
First, you must be sure which diode is blowed, reactifier or protect diode.
To check magnetron following this procedure:
Discconect the mains supply.
Check that the capacitor is discharged (by resistor 100 ohm / 10W or more).
Discconect the magnetron.
Measure the resistence between the disconnected terminals (should be app. 0.5 ohm).
Measure the resistance between the supply terminals (both) and earth. The resistance should be infinite.
Dado
Mar 12, 2015 | Whirlpool MT4155SPS
How to replace fuse in magicchef MVPII microwave.wont heat.
If your microwave isn't heating, I don't think it is a fuse problem or issue. Investigate these three areas if your microwave won't heat
Power Diode
A diode is an electronic component that readily passes current in one direction only and blocks the flow of current in the opposing direction. If your microwave's diode has become defective, your microwave will not heat. Test the diode to determine if this is the cause of your problem. Replace it if it is defective.
Testing a diode
NOTE: Before you test your diode, make sure your microwave is unplugged, and that you discharge the microwave's capacitor.
Whether it is shorted or open, a defective diode will most likely show some sign of defect. Defective diodes will usually emit an electrical burning smell, signifying its defectiveness. Also, it may have split in two, or it may exhibit a burned crack, or possibly even a blistered spot.
A shorted diode is indicated by a loud humming noise from the high voltage transformer, and no heat produced when a cook cycle is initiated. Whereas little or no heat produced in your microwave, with an absence of a humming noise is indicative of an open diode. In either case, the diode has to be replaced.
With your microwave unplugged, and your capacitor discharged, use extreme caution to remove the lead that leads to the capacitor. You can leave the ground connection attached. The side of the diode that goes to the ground is usually marked with a dot, stripe, or arrow. Set your ohmmeter to R x 10,000 or higher. Touch the positive meter probe to the anode and the negative meter probe to the cathode to measure the resistance across the diode terminals. Remember that the cathode is on the side that goes to the ground, which is often marked by a dot, stripe, or an arrow.
A normal diode, that is a non-defective diode, will read anywhere from 50,000 to 200,000 ohms. Differences in microwave make and model account for this large range in resistance readings.
Reverse the meter probes and measure resistance while touching the positive probe to the cathode and the negative probe to the anode. Reversing the probes like this should result in a reading of infinity. Unless a bleeder resistor is present. The presence of a bleeder resistor would produce a reading of the value of the resistor.
High Voltage Capacitor
A capacitor is an electrical device which stores electricity. A defective capacitor may be why your microwave is not heating. The capacitor will have to be tested to determine if this is the cause of your problem. A defective capacitor will have to be replaced before your microwave will work again. Make sure you discharge the capacitor before you test it, though.
Magnetron
A defective magnetron is the third possible cause of why your microwave is not heating. Test your microwave's magnetron. Replace it if it is defective.
Testing a magnetron
NOTE: Before you test this component, make sure your microwave is unplugged, and that you have discharged the capacitor.
There are two tests to conduct in order to determine whether or not a magnetron has become defective. If you receive results other than what are detailed below, you will have to replace your microwave's magnetron. Each test is described for you here:
TEST 1: Locate your magnetron and label each of the wires attached to it so that you know which wires are to be replaced where. Set your ohmmeter to the lowest resistance scale. Take a resistance measurement between each of the magnetron's terminals by touching each probe to one terminal each. Reverse the probes and take a second resistance measurement. Each measurement should read less than one ohm.
TEST 2: Set your ohmmeter to its highest resistance scale. Touch one of the meter's probes to a magnetron terminal. Touch the other probe to the metal magnetron housing. Take special caution to not touch the two probes together. This could result in an inaccurate reading. This test should produce a reading of infinity - indicating an open circuit.
Read the tips on the below links on how to replace your microwave oven's diode and how to discharge the capacitor.
http://www.fixya.com/support/r7088355-replace_microwave_ovens_diode
http://www.fixya.com/support/r7088317-discharge_microwave_ovens_capacitor
I hope the above is helpful.
Regards.
Nov 13, 2011 | Maytag MMV5186A Microwave Oven
My viking microwave is not heating
Power Diode
Testing a diode
Magnetron
Testing a magnetron
Regards.
Oct 22, 2011 | Viking VMOS200 Microwave Oven
Microwave won't heat, EVERY thing else works
Power Diode
Testing a diode
Magnetron
Testing a magnetron
Regards.
Oct 14, 2011 | Whirlpool MH7140XF Microwave Oven
My microwave is not heating food. Its model is MW73C (digital). Its brand name is Samsung microwave TDS. I lost my manual. Please help me solve this problem..
Power Diode
A diode is an electronic component that readily passes current in one direction only and blocks the flow of current in the opposing direction. If your microwave's diode has become defective, your microwave will not heat and you will hear a buzzing noise. Test the diode to determine if this is the cause of your problem. Replace it if it is defective.
Testing a diode
A capacitor is an electrical device which stores electricity. A defective capacitor may be why your microwave is not heating but you are hearing a buzzing or humming noise. The capacitor will have to be tested to determine if this is the cause of your problem. A defective capacitor will have to be replaced before your microwave will work again. Make sure you discharge the capacitor before you test it, though.
Magnetron
A defective magnetron is the third possible cause of why your microwave is not heating, but you can hear a buzzing noise. Test your microwave's magnetron. Replace it if it is defective.
Testing a magnetron
Good luck.
Mar 22, 2011 | Samsung Microwave Ovens
Does not heat,code F-7 shows, Power not getting to magnetron or magnetron burt out. How do you get to this,must the unit be removed[its built in,] Thanks for all help. I did try shuting off the power which...
Power Diode
Testing a diode
Magnetron
Testing a magnetron
Good luck.
Mar 08, 2011 | KitchenAid Microwave Ovens
My microwave does not heat up any food at all but everything else works
Investigate these three areas if your microwave won't heat;
Power Diode
Testing a diode
Magnetron
Testing a magnetron
Good luck.
Feb 01, 2011 | Whirlpool MH1150XMQ Microwave Oven
My microwave dont heat and dont work the fan and the rotation disc, what is the problem??
Power Diode
Testing a diode
Magnetron
Testing a magnetron
Jan 14, 2011 | Emerson Black Microwave Oven
My Model NN-9859 microwave blew a fuse. I replaced the fuse and it blew again.I tested what I think is a diode HVR-1X4 ( from the main capacitor to earth) with a multimeter and it appears open circuited....
The component described is a resistor rather than a diode and is how the capacitor is grounded (to the chassis). It is possible to replace this, however it is a high voltage resistor (rather than your regular carbon film or wirewound ones).
The cost for the part will be around £5 ($7-10) and can usually be purchased from specialist electronic component supplies such as RS or CPC - your local microwave repair shop may even have some there!
Mar 20, 2010 | Microwave Ovens
No power
Simply use Safety. Unplug. Use Continuity Buzzer, Meter ( With Continuity Tone ). Can Use Meter if You Have & Watch, Check By AC Power Cord Fuse. Use a 500 Ohm to 5000 ohm Resistor on two Insulated clip leads with screwdrivers and Find the Hi-Voltage Capacitor ( Large Metal with Leads and a Diode on it. Short the Condenser from one side to another to BLEED any Voltage left Charged in the Condenser. Newer Microwaves have a Bleeder Resistor 10 MegOhms Built in. But Just do this for Backup/Sure Safety. Will Probally Just find a Blown 15-20 amp fuse ( Electrical Surge ). Any one of the 3 Door switches that DONT open-Close Smoothly Will Blow Fuse. ( Intermittent, Burnt, Skipping, Hanging up ). A Shorted Hi-Voltage Capacitor or Diode Will Blow Fuse. Open in Series Protection device may have opened because of Overload or Surge. These are Metal and loop in-Out AC Line and are Mounted ( Heat Sinked to Metal case ).
Aug 15, 2008 | Microwave Ovens
Microwave Ovens Logo
63 people viewed this question
Top Samsung Microwave Ovens Experts
William Miller
William Miller
Oscar Netto
Oscar Netto
Are you a Samsung Microwave Oven Expert? Answer questions, earn points and help others
