Question about Goodman GMS90703BXA Heater
Blower moter will not start and run when running the air conditioner
The condensor will run but the blower will not start. however the blower works fine on heat. Help!
    Novelist:
    Champion:
  • 230 Answers
I would also check the "G" wire at the Thermostat and make sure that it has a solid connection. The other end screws on to a terminal in the furnace. Check this connection as well. This green(G) wire is what activates the 120v relay on the circuit board. You can test this by turning the thermostat to the off position and then jumping the 24v R terminal with the 24v G terminal at the furnace. if the fan comes on then the problem is in the thermostat wire or the thermostat itself.
Posted on Jun 15, 2008
  • 1,420 Answers
Check the wires coming from the blower motor. Find the one going to "Cool" on the circuit board. Make sure it has a good connection. You can also try and removing a wire that is now on "Park" and putting it on "Cool" and see if that helps. If it does, you have a bad motor. If nothing changes, I suspect a bad circuit board or fan relay on the A/C side of the unit. It may take a technician to diagnose, sorry.
Posted on Jun 10, 2008
Main blower wheel running. Why is no air issuing from the air outlets?
sometime the coil will freeze up. check the outside condensor & see if the larger line is iced up. if it is turn the fan on tsat to on or manual turn cool off or turn temperture high enough not to run. it might take 4 to 6 hours. to defrost.
Jul 31, 2015 | Heating & Cooling
Air conditioning condensor on side of house not working
sounds like you need to check your run cap it is silver in the outside unit and it runs the compressor and fan motor. Check on the capacitor what size it is and replace it for example 45+5 uf.
Sep 07, 2014 | Carrier Heating & Cooling
Condenssor fan moter not working
The condensor fan is usually a capacitor start capacitor run motor.To test i switch the unit on as normal then carefully flick the fan around in the direction of rotation (you may have to take the grill off) to do this,do not use your hand! If the motor starts to run it will be a faulty capacitor, do not leave it running for long as it will not run at full speed and will trip on thermal O/L or burn out.This is a common fault on AC split phase motors that use a capacitor for either starting or start and run.
Feb 03, 2013 | LG LS-L1210CL Mini Split Air Conditioner
My window air conditioner was making a loud squealing sound. now it won't start
you proberly tripped the reset at the plug if it has one I would start at the moter check both capacitors the start and run also check for a faulty moter
Jun 11, 2010 | Whirlpool Electronic Window Air...
Circuit breaker tripping from the air conditioner
moter or compresser pulling to many amps on start up you can purchase a hard start kit and also you can ohm out blower moter you could also have a direct short althoug not likly
Aug 09, 2009 | Dometic 57915531 Air Conditioner
71122 ac model starts but the fan does not blow any air .shuts off within seconds.
which fan shuts down? Outside condensor fan? Or blower inside? If its the outside condensor fan motor you probably have a bad run capacitor or a bad condensor fan motor
Jul 26, 2009 | Heating & Cooling
A/C FAN MOTOR SHUT OFF, BUT CONDENSER KEEP ON RUNNING
The condenser fan might be going out. It'll start when cool but shuts off as soon as it starts to warm up.
Jun 28, 2009 | Heating & Cooling
Goodman GMS90703BXA Heater Logo
272 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
