Question about Rinnai RHFE-431FAIII 16,700 BTU Direct Vent Furnace Energy Saver Heater - Natural Gas
Replacing a Rinnai 403 FT
I need to replace my Riaani 403FT gas heater with a powered rear flue.
What new heater is <550 mm high and will have a rear flue at the same height?
Gday nelson. if you check out the specs on the rinnai range you will find another one that will go straight in. if you buy new it will come with a new flue kit. as far as recomended installation heights most of them are quite flexible. i installed a second hand 403ft yesterday with the centre of the flue at 140mm from the floor. recomended in the instructions were 240mm. a mate gave me the heater and i just had to buy a flue kit as the old one was already too short. if you messure your flue from inside and send me the specs i can give you a more difinitive answer.
Posted on Jul 12, 2008
E:01 fault on a rinnai energysaver 403FT
Rinnai 403FT sounds like a fairly old heater (probably about 15 years old???).
There is no E:01 in the instruction manual but a E:07 which is overheating. Could it be this number instead? If so it could be caused by too much dust inside (or the fan not working anymore, if that's the case... sorry but good luck to find the part...)
With gas heaters, the other basic question you should ask yourself is "when was the last time I serviced my heater??". It is recommended to get them serviced every 1 or 2 years.
It consist in having a licensed gas fitter to open it and clean/test everything inside the heater (yes, like your car).
9 out of 10 problems with a gas heater are solved with a simple service, I would suggest you get a gas fitter to check it out!
Apr 20, 2013 | Heating & Cooling
I have a rinnai 1001ft heater but i need the flue is there enyone that has one please
You should be able to get the flue kit from any Rinnai resellers.
There are many different flueing options existing for Rinnai Energysaver depending on where you wish to install it (by a licensed gas fitter only of course).
Depending on what flue kit you need for your own situation you could be looking anywhere between $150 to $800 (AUD).
Go on their website for a list of resellers.
Mar 19, 2013 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Error message e06 and e20 on rinnai energysaver 403ft
go to www.fitness.manualsonline.com or www. retrevo.com and download your instr.manual for to clear the errors .
God bless you
Jul 21, 2012 | Rinnai Heating & Cooling
Would like a manual for the rinnai energysaver 403FT we need to set our heater up so it goes on auto and how do we regulate the temperature and set time
The model number (403FT) has either been discontinued, changed or is incorrect. However, Model # RHE309FT closely matches the heater you described and has the timer and temperature features you are wanting to preset.
You may download and print the manual from the link below for future reference.
http://www.rinnai.com.au/images/stories/operating_instructions/Heating/Energysaver/CI_Energysaver_RHFE309_559FT.pdf
Hope this helps you and thanks for choosing FixYa. Cheers
Aug 15, 2011 | Rinnai RHFE-431FAIII 16,700 BTU Direct...
Rinnai heater 403FT. The heater works but the flame goes out and comes back on with a loud bang as if there is a build up of gas
I suggest you call for service. This "bang" could be a serious problem in the future - meaning the next time it tries to start.
Gary
Jul 04, 2011 | Rinnai Heating & Cooling
I have a Rinnai 403 ft heater but no EXTERNAL FORCED flue kit. where can I get one?
Since, your Rinnai Heater is Vent-free, it can not be converted to a Vented Unit. The design does not allow it. Even if you could, the efficiency rating would drop tremendously. Not sure that you'd want to do that, with the price of gas being what it is, now.
Apr 08, 2011 | Rinnai Vent Free Gas Heater/: 14,000 BTU...
Have inherited a Rinnai energysaver 1001 FT gas heater - need an exhaust manifold
Found a link to the service manual for starters
http://www.rinnaisales.co.nz/tradesmart/rinnai2/pdfs/service_info/225.pdf
The flue system looks very similar to some current models. I'd go to Rinnai direct and try and get a list of local service agents who can order the bits in. The flues are very tricky to order because there are so many different bits depending on where you need it to run so order carefully.
Jul 30, 2010 | Rinnai Heating & Cooling
Is my Rinnai Energysaver 403ft obsolete?
You may be able to help me with my 403FT.
I have nothing coming up on my control panel no lights anywhere.
The power supply is all good so it has to be within the heater.
Can't see a fuse able link.
Apr 05, 2010 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Can you vent the Rinnai 551F vertically through ceiling?
This unit can be vented through the roof but requires a specialized flue system-do not use an existing flue connection. Call a contractor - have them check and see if the unit can be modified to a vertical flue- it will require the existing piping to be replaced--Not a job for a do-it yourselfer
Nov 01, 2009 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Rinnai 403 FT
who did you talk to at rennnai?
let me know i deal with them on a buisness leval.
Mar 27, 2008 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Rinnai RHFE-431FAIII 16,700 BTU Direct Vent Furnace Energy Saver Heater - Natural Gas Logo
253 people viewed this question
Top Rinnai Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
vance jones
Are you a Rinnai Heating and Cooling Expert? Answer questions, earn points and help others
