Question about GE Washing Machines
Wont pump water out after the washer fills - GE Washing Machines
    President:
  • 1,294 Answers
Ref. to manual to locate filter of machine, clean out. Caution unplug from mains. If that does not work you may have a block in one of the pipes coming down from under the tub (front loader?). You hv to unblock by disconnecting pipes. Next to look into is your pump, last.
Posted on Jun 09, 2008
Washer machine front loader wont fill up and wont drain
it maybe that the pump winding is open circuit some machines use the pump winding as the neutral line for the water valves so if the pump fails they wont fill no point in it filling if it wont empty
Mar 09, 2014 | Indesit W 123 Front Load Washer
Washer wont fill but work fine through all other cycles.
My washer will not fill with water to the level that I set it on the panel.
Dec 14, 2013 | GE WBSE2090A Top Load Washer
Older maytag stackable washer and dryer combo washer fills , washes and spins but water wont pump out
check for the pump belt broken or off,clogged pump or sock or small item clogging the tub outlet to pump hose. the pump pulley may have become loose on the shaft also
Feb 28, 2013 | Maytag LSE7806A Top Load Stacked...
Ecosmart washer won't drain it filled with water, washed and nowwon't drain the water.
you need to vacume out all the water so you make it light, then dolly out the washer to some place you can drain it. now take off the front of the washer and locate your water pump, its attached to your drain line. take off drain line to water pump and see if anything is clogged in the pump. This is most likely what is wrong if it wont drain. hope this helps.
Feb 22, 2013 | Fisher Paykel EcoSmart GWL15
Washer filled and will not drain if I reset the fill capacity knob it will fill but not drain.
This washer has a belt. The belt drives the pump on this washer. The motor turns in both directions. iIn one direction the washer tub is locked and the tranny agitates. The water pumps out and the tub spins in the other direction. If that pump is locked up or the hose from tub to pump is blocked then it wont pump the water out. Lay the drain hose down towards a bucket and see if any water comes out. If not you got blockage. Once you drain it out tip is back and remove the belt (no tools needed) turn the pump both directions and look for signs of a failed pump. Manual and more
Jun 30, 2011 | Amana NAV8805EWW 3.3 Cu. Ft. Elustra Tub...
It wont cycle thru anything
There could be several reasons for washer not to fill .Fill washer with water and wait for the timer to get to the drain mode.Unplug the washer from the electric outlet.Open the case, and disconnect the water hose from the outlet of the water pump.If you get water pouring out from the pump, then plug that up and check the hose to the sewer. If that is clogged, then you have found the problem.Some washers have a self cleaning filter in that hose somewhere. Check that to be sure it is working properly.Reassemble hose from step 3.Plug washer back in. If it pumps out now, then you are done. If it doesn't, then the water pump is probably defective, so replace it.
Thanks for contacting Fixya.com
Nov 04, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Washer won't drain.
My washer fills up with water and goes thru the wash cycle but when it's time to drain, it just sits there and clicks.
Oct 17, 2009 | Tecnik TKL9260 Front Load Washer
Water wont fill washer. The water currently in
The pump is probably clogged with a coin. Pull off the hoses and check the pump. Make sure you put a pan under the hoses to catch the water
Jun 27, 2009 | Frigidaire Washing Machines
May tag washer spin cycle wont spin
check the pump ,,, if pump wont pump out the washer wont spin till it gets down so low / larryyb
Dec 05, 2008 | Maytag PAV2300 Top Load Washer
Washing Machines Logo
99 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
