Question about Toshiba 61H70 61" Rear Projection Television
Toshiba 61H70 Projection
Our neighbor wanted to get rid of his 2 year old rear projection. Having worked on these in college I thought I'd put my solder iron to work and get lucky. Well, I did get lucky but this set seems destined to the dump.
Does anyone out there know where I could send the boards or obtain refurbished boards for it?
  • lhcsmi Jul 24, 2008
    I am not a professional television repair person; I'm good at replacing boards and/or parts that someone says are likely the root cause of the video problem I have.
    Let me reiterate the problem with this set:
    No Video. Prior to this it had video that would come and go by tapping near the coax input area. We soldered many connections and had it down to a certain board then one day it went out completely. We get the blue screen and menu screen fine and volume, high voltage seems to be there, just not the video no matter which input we use.
    Which board should we replace or send in for service? Where would we purchase a board and/or send ours in for service? Which part(s) typically go bad in this model based on our no video issue?
    We would prefer to find a reputable company that does an exchange and/or repairs Toshiba circuit boards at a responable price. And ideally someone who has knowledge of typical parts that fail and/or mods in this model rear projection unit with details about which components to test with an volt / continuity or diode meter and which parts to purchase / solder in, etc. We purchased a real service manual and ideally we would like page numbers to review with hotspots to test / replace.
  • 4,234 Answers
Since the menu etc seems to appear correctly, there is no convergence problem. You will need to perform a couple of tests to help me isolate the problem:
1) Try using an AV input (Video 1 for example). Does the picture appear correct?
2) Select a known strong channel. Any picture at all or just blue screen?
The menu is generated late in the video path before all of the convergence etc. The AV inputs bypass all of the RF nonsense that is handled by the tuner. Once we narrow down the probable circuits, we can start looking for specific parts that may be defective.
Please try the experiments listed above and post the results.
Thanks,
Dan
Posted on Jul 25, 2008
  • ABRsvcs Jul 28, 2008
    Based upon your latest update, I think that the problem is more a connection problem than anything else. Look closely at the connections on the board with the tuner. You may find a poor solder connection close by the tuner itself. Resolder any connection that appears grainy or has a ring. Start there and let us know what happens. This problem should not require many parts if any.
    Dan
    Genius:
  • 2,035 Answers
Certainly, I can help you. I would recommend going to the following link and getting the service manual so you can see first hand disassembly instructions and testing procedures. Its only 10.99 and they email it to you shortly after purchase. The manual is a valuable resource as it will have part numbers in case you do need a new KD board or refurbished boards which is available on ebay . heres the link.
Posted on Jul 24, 2008
  • 2,326 Answers
Check this website to get the parts for your TV. I will find the service manual and give more instructions about the board that will need to be replace.
  • Jaime Hernandez Jul 24, 2008
    If you already have the service manual, it just a matter of locating where the video section of the TV and measure the voltages that appear in red and if you have an oscilloscope you can verify the waveforms as well.
    Base on how the TV was working before re-soldering, would suggest to check very carefully for shorts and even a connector not seated properly.
  • 796 Answers
Click here..
this could be helpful for you
Tip
Toshiba 61HX70 Manual Download
Download Toshiba 61HX70 Projection Television Manual
Models: 50HX70 / 55HX70 / 61HX70 / 55H70 / 61H70
Have you misplaced your Toshiba 61HX70 Projection Television Owners Manual?
Would you like a digital, searchable, pdf version of the Toshiba 61HX70 Projection Television User Guide?
Follow this link (& click FREE) to download a pdf version of the Toshiba 61HX70 Projection Television instructions.
I hope that helps.
_______________________________________________
Toshiba 61HX70 Service Manual Download
on May 10, 2010 | Toshiba 61HX70 61" Rear Projection...
Toshiba 61H70 projection TV. Perfect picture but the sound suddently stopped working. Tried all on screen settings and still no sound. Set is 8 years old but relatively few hours. Is it worth repairing?...
it sounds like the soundboard went out on the tv..its probably worth fixing but you have to know what you are doing if you do it on your own.it could be something more minor too but not sure
Feb 24, 2009 | Toshiba 57H81 57" Rear Projection...
Tip
Toshiba 61H70 Service Manual Download
Download Toshiba 61H70 Projection Television Service Manual
Have you misplaced your Toshiba 61H70 Projection Television Service Manual?
Would you like a digital, searchable, pdf version of the Toshiba 61H70 Projection Television Service Guide?
Follow this link
(& click FREE) to download a pdf version of the Toshiba 61H70 Projection Television troubleshooting & repair instructions.
I hope that helps.
Toshiba 61H70 Manual Download
on May 10, 2010 | Televison & Video
Tip
Download Toshiba 61H70 Projection Television Manual
Have you misplaced your Toshiba 61H70 Projection Television Owners Manual?
Would you like a digital, searchable, pdf version of the Toshiba 61H70 Projection Television User Guide?
Follow this link (& click FREE) to download a pdf version of the Toshiba 61H70 Projection Television instructions.
I hope that helps.
Toshiba 61H70
Does it look like a 3D image?
Would you be able to post a picture of the TV with the mention lines?
Aug 16, 2008 | Toshiba 61H70 61" Rear Projection...
Tip
Follow this link
I hope that helps.
on May 10, 2010 | Toshiba 61H70 61" Rear Projection...
Tip
I hope that helps.
Tip
Toshiba 43H70 Manual Download
Download Toshiba 43H70 Projection Television Manual
Have you misplaced your Toshiba 43H70 Projection Television Owners Manual?
Would you like a digital, searchable, pdf version of the Toshiba 43H70 Projection Television User Guide?
Follow this link (& click FREE) to download a pdf version of the Toshiba 43H70 Projection Television instructions.
I hope that helps.
Toshiba 43H70 Service Manual Download
on May 10, 2010 | Toshiba 43H70 43" Rear Projection...
Tip
Toshiba 55H70 Manual Download
Download Toshiba 55H70 Projection Television Manual
Have you misplaced your Toshiba 55H70 Projection Television Owners Manual?
Would you like a digital, searchable, pdf version of the Toshiba 55H70 Projection Television User Guide?
Follow this link (& click FREE) to download a pdf version of the Toshiba 55H70 Projection Television instructions.
I hope that helps.
Toshiba 55H70 Service Manual Download
on May 10, 2010 | Toshiba 55H70 55" Rear Projection...
Open Questions:
Toshiba 61h70 Picture Problems Hello, I have a Toshiba 61h70 TheaterView HD Projection TV, and was recently having some slight convergence issues (red was out of alignment and could not be adjusted). So I researched and found that the IC?s (STK392-110) needed to be replaced. I initially purchased them on eBay, to later find out that they were cheap clones and did not work (they made the convergence worse, actually). I then purchased 100% Sanyo IC?s from a reputable dealer and replaced the IC?s again. Once finished, I then entered the service menu and adjusted the convergence alignment. Once the alignment was perfect, I hooked back up the TV antenna, the DVD player (composite), and the S-video from my computer. The convergence is fine, but now I?m having a totally different issue ? the video is ?scrolling?. The menus will show up fine, however any incoming video inputs will show up okay for a split-second, but will then flash and the picture starts to scroll in different directions. This happens with any of the video inputs. I checked and changed all the service menu items to factory defaults, however this had no effect. I have pasted a link below to a short video that illustrates the issue that I?m having. Please note that the video starts off with a black screen, showing the ?input? menu, and then I selected the ?TV input? and changed the channels. You will see the picture fine for a moment when the channel is first changed, but then the picture will start to scroll. Any ideas of what would be causing this? And how can I correct the issue? I?m not a TV repair expert, so I?m not even sure where to start. Any help would be greatly appreciated. http://s75.photobucket.com/albums/i303/hybrydmike/?action=view₪t=TV_Troubles.flv
Feb 27, 2017 | Toshiba 61H70 61" Rear Projection...
Toshiba 61H70 61" Rear Projection Television Logo
132 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
