Question about Furuno NavNet vx2 1920C GPS Receiver
Furuno navnet 1723 C
I have the nav net 1723 and I was out on the boat this weekend and a friend was messing with the buttons when it was in radar mode and after that everything on the monitor was reading opposite. Objects were projected on the screen 180 degrees off. I tried to troubleshoot it but no luck. any help would be appreciated
    New Friend:
  • 132 Answers
Go into installation mode (hold menu during power on) find radar setup, go to next page, do heading alignment. also tune video, your unit was reset!
Posted on Jan 15, 2010
I have a Furuno Radome RSB0094-075 with a Navnet RDP 139 10.4" What I dont have is the antenna cable to connect the two units. What cable should i be ordering for this?? Thanks, Mike
That is a Furuno 1823C Radar -000-138-972 (10 meter Radar cable) $150.00 msrp from Furuno. Give their Camas Office a call or your nearest dealership. The Furuno number in Camas, Wa 888-834-9330
Nov 06, 2010 | Furuno NavNet vx2 1920C GPS Receiver
Ais and 1920c Furuno chart plotter
n the system setup, under “UNITS” I set BEARING to “MAG” (magnetic). This will cause the unit to display course / bearing information in relation to the Magnetic North and match magnetic compass readings. It is not the same as True North! One has to be careful with this setting. There are a number of areas where the earth's magnetic field is locally disturbed, sometimes very significantly. Your GPS may not account for it. - again, under “UNITS” I set “METRIC”.
Sep 02, 2008 | Furuno NavNet vx2 1920C GPS Receiver
Furuno radar
Your antenna seems to be mis alighned. Its ZERO point must be readjusted.
Aug 30, 2008 | Furuno Navnet 1834C/NT vx2 Radar C Map Nt
How do i reboot my furuno navnet......recently installed radar and system not recognising teh radar installatio. no count doen on radar page greyed out overlay icons on the screen
Press and hold the "MENU" button during power on. Release "MENU" after boat appears.
Go through the installation wizard. You must select the radar type, "B" is 1834.
May 21, 2010 | Furuno Navnet 1834C/NT vx2 Radar C Map Nt
My 1734c will not boot past the black disclaimer
You will have to get a software update and have someone reflash the unit or perform factory reset by holding down the alarm button when pressing the power button.
May 15, 2010 | Furuno Navnet 1834C/NT vx2 Radar C Map Nt
This is a bit of bummer. Usually (and I hope in your case too) it is just a software problem. As a navnet is basically a computer this can happen. First I suggest you unplug everything except power and start it up, just to see if something on the network port isn't messing it around. If it still gets stuck take it to your local Radio Holland office or another furuno certified service outlet to reload the software.
Mar 27, 2010 | Furuno Navnet 1834C/NT vx2 Radar C Map Nt
Can I use my furuno gps navigator to supply position data to my rdp-139 chartplotter and if so which wires need to be connected
Yes the output forom the Furuno GPS (like a GP31) will be yellow and green, hook these to theinput on the plotter blue (or black) and white. Use Data1 on potter as the input and select a nav source of "ALL" in setup menu.
Jun 05, 2009 | Furuno Navnet 1834C/NT vx2 Radar C Map Nt
Inverted display on newly installed Furuno Nav Net 1944C
hold menu during power on to gain access to Installation Mode In the Radar Set Up menu, you need to hit Next Page to access heading alignment.
Don't forget to Tune Video also.
Dec 07, 2008 | Furuno NavNet vx2 1944C/NT GPS Receiver
Navnet 500
I have been doing some research and I haven’t been able to determine if the Garmin has a compatible output for your Furuno. I can not recommend any service center particularly since I have no idea where you are located, but any good marine shop should be able to help you.
The Furuno uses NMEA Inputs for the GPS, and like I said I haven’t been able to determine if that Garmin uses that as an output. I would suggest that you inspect your installation to determine if there are any cableing between the two units. If no wires connect the two that you can be sure that the units are not communicating.
As far as the chartplotter goes you can buy data cards for them, either on-line or from a good marine supply store.
Apr 03, 2008 | Furuno NavNet vx2 1920C GPS Receiver
Furuno NavNet  vx2 1920C GPS Receiver Logo
268 people viewed this question
Top Furuno GPS Experts
Steve
Steve
Are you a Furuno GPS Expert? Answer questions, earn points and help others
