Question about Nokia N95 Cellular Phone
Nokia N95 Bluetooth
I can find Bluetooh on my menu but cannot work out how to find the other devices on bluetooth around me. Any suggesstions will be appreciated. Thanks Binny Hi, I have just upgraded (or should I say downgraded) my phone from the N70 to the N95, and even though my phone pairs to the inbuilt hands free car kit, it cannot connect with it. The N70 works fine, but the N95 just won't connect. I'm about to throw the N95 in the bin. I've contacted Nokia, but they insist it's my car kit. Looking at the amount of problems posted on the web others are having, this seems like a load of **** from Nokia. Is there a patch, or something than I can install on my phone to get the thing connecting properly?
  • 2 more comments
  • freestye4lif Jul 11, 2008
    can recieve music from other phones but cannot send through bluetooth.i need an assitance
  • shirley23 Sep 25, 2008
    I cannot pair my nokia n95 to my hands free device in my car, cannot see any other blue tooth devices
  • annette_599 Jan 04, 2009
    I am unablte to find any paired devices any advice?
  • zhengshengma Apr 23, 2009
    My Nokia N95 cannot be connected with my GLK350 with blue tooth
I have just spoken with 3 as I had the same problem with my Nokia N95.
The solution is:
Menu
select Tools
select Bluetooth
at top option blue tooth on - select right hand navigation button
it will say (no paired devices) select Options and select new paired device this will then seach for other blue tooth devices.
Good luck everyone
Posted on Sep 25, 2008
How do connect bluetooth to X3 nokia mobile.
Open the Bluetooth application from the menus on your device and do the following:
  • Bluetooth - Select On to activate Bluetooth.
  • My phone's visibility - Select Shown to all if you want your device to be found by other Bluetooth devices. If you select Hidden, your device cannot be found by other devices.
  • My Bluetooth name - Define a name for your device.
May 13, 2011 | Home
How can i connect bluetooth ce0681 to nokia n95
All these given solutions are not catering your problem unfortunately; because your problem seems to be the following "You are not at all able to find your bluetooth headset from your phone, pairing is a far off thing" right?
So, here is the simple solution that no one has given here and on other sites (I myself was confused, but finally found it out):
1. Turn bluetooth of your Mobile on.
2. Put it into "shown to all" mode.3. Now pick your bluetooth device, and simultaneously click on the multifunction key (The middle one that blinks) and the "+" volume key for around 6 seconds or more; you'll see that blue blinking light will become static (and it means that your bluetooth device is now "Searchable" by your phone).
4. Start "Pair new device search" from your Mobile, and your Phone will find the bluetooth device.5. It will ask you for a passcode, just enter 0000.6. Pair both devices now.7. The static blue light (Which became static when you pressed the middle multifunction key and "+" volume key together for some seconds) will now start blinking again (in a 3 sec interval approximately).
Your handsfree is now connected, do a test call and confirm.
In case you find any volume problem, then know that the default volume after connecting a bluetooth handsfree is at low level, so just increase it using your Phone's volume keys/ controls and it shall be all fine.
Vote up if it helps, it is the genuine solution of this problem though; I tested it several times. :)
PS: I'm writing this while logging off in haste, pardon any spell/ typo mistakes. :P
Jan 21, 2011 | Nokia N95 Cellular Phone
I want to transfer my files from pc to mobile via bluetooth
If you want to transfer files from pc to the mobile device. Make sure the pc has a bluetooth turn on. Most of the laptops have a built in bluetooh , but for desktop computers you need to purchase a bluetooth adapter.
Once you have the bluetooh turn ON on your computer. Turn on the bluetooh on your mobile device.
From your computer. Right click on the file that you want to transfer and select send to bluetooth. Click on search for bluetooth device and then select the name of your cellphone ( or name you assigned for the bluetooth on your cellphone)Once you click the name, just go next . You will get a message saying accept bluetooh file on your cellphone, just accept the file and your done.
kevin angell
Jul 03, 2010 | Computers & Internet
How do i delte bluetooth contacts on my n95 ? please help
MENU.EXTRA.BLUETOOTH.MY DEVICE.
>options > delete all
Sep 26, 2009 | Nokia N95 Cellular Phone
I can not pair a particular bluetooth device to my n95 8 Gb phone, but i was able to pair nokia's model. is there any reason why other type bluetooth devices won work with n95 nokia 8 GB cell phone? How...
jus change th settings of ur bluetooth on ur device an on th other device an try to pair it.. so tat u may recover tis prob... kindly rate me.... thank you...
Jun 30, 2009 | Nokia N95 Cellular Phone
Bluetooth problem
u can edit setting of your device.the setting is MY PHONE'S VISIBILITY turn it to HIDDEN.when uwany to recieve data bluetooth turn it to shown to all.and after use turn it to HIDDEN .it will help try it.
Jan 25, 2009 | Nokia 6600
Connection problem between a nokia n95 8gb and zumo 550
I have recently purchased a Zumo 550 and successfully copied across selected phone book entries from a Nokia N95 without the need to use any additional apps:-
1) Assuming the N95 and Zumo are paired via BlueTooth
2) In N95 Contacts - use 'Mark' / 'Mark All' as necessary to select the contact entries you wish to transfer to the Zumo 550
3) In N95 Contacts - select 'Options' then 'Send Business Card' then 'Via Bluetooth'
4) Select the Zumo 550 device from the list of paired Bluetooth devices
5) Contact data is transferred from N95 phonebook to Zumo 550 phonebook
Interestingly, Garmin don't seem to list the Nokia N95 as being a supported device on their website, but the above process worked for me!!
Feb 15, 2008 | Garmin zumo 550 GPS Receiver
To connect N95 with bleutooth headset LG HBM-550
1st switch on bluetooth for both devices!
2nd go to your bluetooth menu in your phone
3rd click on pair devices
make sure that your phone is visible to other bluetooth device
4th select the device and click on pair devices!
its done!
Dec 08, 2007 | Nokia N95 Cellular Phone
Bluetooth Icon not working
I had the same problem with my nokia n80.
The solution i found is:
with the remote go to bluetooth phone. then on the remoete av menu. now you can select bluetooth as it's not grey anymore. i would advise search device with a new pin and not the standard 0000.
Good luck.
Let me know if it worked. It did for me. (eu model)
Sep 23, 2007 | JVC KD-AVX33 Car Video Player
Nokia N95 Bluetooth
Almost there gizmo1. In fact one has to go through Connect, Bluetooth then you'll see two tabs. The selected tab has the basic bluetooth options (On/Off, Visibility, name etc) and the second tab shows the list of paired devices. Access this by pressing right.
Once in the list of paired devices Press OPTIONS (normally the left softkey) then "New paired devices". You'll then see what's around and you'll be able to initiate the pairing.
If you're simply looking to send an object, you can do this from the file manager or media library. In the media library select your picture or other object then once again through the left softkey (Options) you should see a "Send" option. Select that, the Nokia will then propose how you wish to send. Choose bluetooth. In the file manager it works in the same way.
Sep 20, 2007 | Nokia N95 Cellular Phone
Nokia N95 Cellular Phone Logo
473 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
