Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
Rca tv RCA D52W20 52 in. won't stay on turn it on and turns off 15 to 20 sec.
  • justcrewsit Jun 15, 2008
    no the lead doesn't blink, and the picture does do anything because it won't come on the light comes on for about 3 to 5 sec. and goes back off.
  • RCA Master
  • 8,617 Answers
When it shuts down and you try to turn it on again does the led blink/ If so how many times does it blink? let me know and I will try to help you out with the problem. Also let me know does the picture do anything abnormal just before it shuts down?
Posted on Jun 09, 2008
Rca 20f512 tv won't stay on
Here is a troubleshooting guide for you:
Flyback Transformer
must have supervision of a qualified service technician
Sep 23, 2012 | RCA 20F512T 20" TV
Tv won't turn on. It turned off after a few minutes and won't turn back on. We opened it up and replaced the fuse.Didn't change anything. A friend said that it just seems to not be getting any...
does the power light flash three times slowly then stay off? If so chances are its just the CP150, cp120 and CP114 capacitors. There is the RCA repair kit by that same name available from www.tvrepairworld.com which has the capacitors and the CD with repair instructions
Oct 25, 2011 | RCA HD52W56 52" Rear Projection HDTV
Power does not stay on
Faulty power supply/control board. Needs professional service, unless you have the experience.
Charlie
Aug 29, 2009 | RCA P61310 TV
Programing codes
Here is the link I just found the manual on for this remote control, which I needed the codes for myself: http://safemanuals.com/brand-user-guide-instructions-owner-manual/RCA go there type in the remote model RCR450 enter, click on the link that comes up and download the Manual in PDF form.
The codes for Sanyo are 1004, 1048, 1049, 1073, 1080, 1162, 1169, 1180 depending on which model you have.
OR:
1: Turn on the device you want to program ex: the TV
2:hold the button for the device you need to program in ex:TV
while holding down TV button hold down ON/OFF at the same time for 3 secs and the light should turn on and stay on.
3:click the ON/OFF button until the TV finally turns off may take many times but as long as the light stays on when your not pushing a button you still have codes to go through.
4:press the stop button and the device is programmed into the remote.
Mar 11, 2009 | RCA RCR450 Remote Control
Can somebody tell me how to program a RCA 312w universal remote control to a emerson tv I have the intruction but I can not understand them thak you.
This will work with any devise and the rca remote.
1. turn on the device you want manually
2.press and hold the devise key, while holding the devise key press and hold the on off key till it stays lit.
3. point it at the devise and press PLAY for 5 sec. until it goes off. If it doesnt turn off after 5 secs. press and hold play again for 5 secs. repeat till unit turns off.
4. After unit turns off press and hold Reverse for 2 secs. until unit turns back on.
5. After it turns on hit STOP. and your done. Hope this helps.
Feb 25, 2009 | RCA Universal Remote Control
I have an rca universal remote and a magnavox tv. cant find the instructions on how to program
try this, press and hold the tv button on your remote about 3 sec. light should stay on, then enter code, if it's a good entry light should shut off, then try to turn tv off. make sure your tv is on before trying this. If tv does shut off then you're done if not try other codes magnavox codes0062 0004 0009 0183 1133 0226 0288 0456 0008 0068 0075 0141
Feb 20, 2009 | RCA Universal Remote Control
RCA television 20" TV/DVD C231 new, no picture, only stays on 15 sec.
This happened to me. Unplugg the TV and let it sit idle for ATLEAST 20min.  Remove the rear cover of the TV. BECAREFUL NOT TO TOUCH THE TUBE OR COMPASITOR THERE MAY TIL BE POWER TO IT!  You should see a (3) prong wire that is black+white+and grey. That wire is most likely disconnected. You will see where it plugs into the board.
Dec 13, 2007 | RCA 20F510TD 20 in. TV/DVD Combo
My RCA tv turns on them shuts off
I think while shifting some loose contact problem might be there as you say it was working fine at mother house. or you can check plug or socket for loose. or call tech to fix it as it is not a serious job.
Sep 28, 2007 | Televison & Video
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
179 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
