Question about IBM ThinkPad R31 2656 Notebook
IBM,lenovo ThinkPad R31
I orderd a IBM,lenovo ThinkPad R31 off ebay, the seller said the unit powers on and the fan runs. But it does not display anything on the screen. I ask him if he tested it on a external Screen but didn't respond yet. And no I haven't gotten it in yet to test it my self. What maybe the problem with the LCD Screen? I'm guessing it maybe the Inverter or the LCD Ribbon. If it is the Ribbon, Would a T40 Series Ribbon work on a R31 since I have a T40 Ribbon laying around.
Thanks..
Maintenance manuals for both systems are on www.lenovo.com/support, under the publications section. But without looking at it, I would say no, the cables will not work.
Posted on Jun 09, 2008
Why is my x201 lenovo thinkpad screen black. I am using an external monitor ok.
That means the connecting bus(cable) from the motherboard to the screen is damaged you can check it by opening slowly the screen of ur thinkpad if display comes at some place then the bus is damaged either replace that bus or the screen might be faulty you have to get replaced your thinkpad screen in this case
Jul 23, 2014 | IBM Lenovo ThinkPad X201 Notebook
Remove dent
IBM/Lenovo ThinkPad R61 Notebook PC >
Bottom Case Cover, (Base Enclosure),
http://www.ebay.com/itm/NEW-IBM-45N4073-Lenovo-Thinkpad-R61-15-4-Bottom-Case-Base-Cover-42W2231-/360642073440?pt=US_Laptop_Housings_Touchpads&hash=item53f7f15360
Keyboard/Palm Rest Cover Bezel,
http://www.ebay.com/itm/IBM-ThinkPad-T61-T61P-R61-14-1-upper-keyboard-palmrest-bezel-cover-42W2466-/400491727269?pt=LH_DefaultDomain_0&hash=item5d3f2ac9a5
Palm Rest Cover,
http://www.ebay.com/itm/Palmrest-Assembly-Cover-IBM-Lenovo-ThinkPad-R61-R61i-14-1-Laptop-/281030800308
Not advertising for seller nor website. Just examples.
Here is the free HMM from Lenovo Support.
It is the Hardware Maintenance Manual. The Service Manual.
Shows and details how to replace the above parts,
http://support.lenovo.com/en_US/detail.page?LegacyDocID=MIGR-67760
Also USE an ESD wrist strap, and have it's alligator clip attached to a good ground source.
Here is an average example,
http://www.radioshack.com/product/index.jsp?productId=2103245
For additional questions please post in a Comment.
Or click on Reply at end of solution, and post.
Regards,
joecoolvette
May 19, 2013 | IBM Lenovo ThinkPad R61 Notebook
Ibm thinkpad r31 windows vista video drivers
The OS will ,USUALLY, apply a generic driver to the Graphics Adapter, and most essential components. Not always, but usually, when it boots the first thing you do is Windows Updates. You may have problems with some hardware when doing a OS upgrade.It can be tricky. If, say, you jump from XP to 7, you may be able to use vista drivers. Your in luck, on the ThinkPad R31 support website Vista and Win 7 drivers are available, SEE: http://support.lenovo.com/en_US/research/hints-or-tips/detail.page?&DocID=HT072387 Go with Win 7, if you have that option.
Apr 03, 2013 | IBM ThinkPad R31 2657 Notebook
I want free driver and software update
to download the drivers for your IBM ThinkPad R31 2656 Go to this link: http://support.lenovo.com/en_US/downloads/default.page?
When you get there, Then scroll down and select Operating System", select your operating system It will then show all the drivers for your operating system...scroll down Hopefully this will help...good luck.
Aug 27, 2011 | IBM ThinkPad R31 2656 Notebook
My screen will get really dark after a while
Thinkpad R31 is a pretty old model so you should expect some screen fade over time. This is usually caused by a failing flourescent backlight. A new screen will fix the problem unless you think you are up for a direct light tube replacement. This is tricky work and you can shatter your screen if you aren't experienced enough.
Fortunately for you though, these screens are pretty cheap on Ebay.
Mar 07, 2010 | IBM ThinkPad R31 2656 Notebook
IBM R31 ThinkPad connecting to VISIO flat screen TV
So there are a few things you need to know, you will need a converter box from the Laptop to TV, but you would not need one for connecting your laptop to a monitor. These can be purchased online (ebay) or in stores.
Jun 17, 2009 | IBM ThinkPad R31 2656 Notebook
R31 screen lines
there could be a lose wire to you display card mine gets red lines some times and if i hit the right side a few times it goes away and it works fin after so idk if it will work 4 you but it does for me.
Jan 24, 2009 | IBM ThinkPad R31 2656 Notebook
Problem with japanese keyboard
Hello, hope this helps. Special characters in a friend's Thinkpad 2662 were helped by going into regional settings as described below:
http://forums.lenovo.com/lnv/board/message?board.id=Beta_OS&thread.id=369
May 03, 2008 | IBM 02K6212 for ThinkPad R31 Series...
Thinkpad 600E
Error 19990301 on a Thinkpad 600 usually indicates that the hard drive is not properly connected, and error code 19990305 signifies "no bootable device". So, it's the hard drive.
First of all, I would try removing and replacing the drive to see if that cures it. You can get the service manual from Lenovo at http://www-307.ibm.com/pc/support/site.wss/document.do?lndocid=LWIK-3SYPX2
If this doesn't fix it, the hard drive is faulty. However, small size hard drives (10 or 20Gb) which suit these older machines are very cheap on eBay.
Dec 18, 2007 | IBM ThinkPad 600E 2645 Notebook
DVD
I don't mean to disagree with my associate, but DVD players for R series (or T, A, etc) can be found for less than 20.00 US (Ebay is a good example)
For that matter, we've got at least a dozen at our shop which we sell for 25.00
Installation is very simple as well, just pop the old drive out, put the new drive in.
Good luck
Oct 30, 2007 | IBM ThinkPad R31 2657 Notebook
IBM ThinkPad R31 2656 Notebook Logo
231 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
